BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > confused about windows open/close coding
      09-06-2017, 05:32 PM   #1
rak299
Drives: 2017 440i xdrive F32 6MT
I have a 2017 F32 and the coding has never been changed. As I would expect, if I press and hold the unlock button, the 2 windows and the sunroof will open.
If they are open and I press and hold the lock button, I would expect them to close after locking the doors, but they do not. When I look at the coding reference I found here, it looks like both open and close are not active by default. This is confusing to me. However, the most important thing to me is that the mirrors should not unfold when I unlock the doors, either by the handle of by the fob. At night, I park very near a concrete wall. I back in most of the way using the mirrors, but then I need to fold in the mirrors before backing up the last 6 feet. If the mirrors unfolded, the one by the wall would be damaged.
      09-06-2017, 05:40 PM   #2
Billfitz
Drives: '15 328iX GT
My windows close when I hold the lock button down. Leave your mirror coding alone, since you fold them before locking the car. They won't unfold when you unlock the car, they will once you reach a set speed, 6 MPH as I recall.
      09-06-2017, 05:46 PM   #3
rak299
Thanks. Did you have to change/code anything to get the windows to close when you hold the lock button?
      09-06-2017, 10:22 PM   #4
Billfitz
I didn't do a thing. I can't say if what works on my '15 F34 will work on your car, though.
      09-06-2017, 11:09 PM   #5
rak299
I saw something indicating that newer U.S. cars no longer close off the FOP. The change results from fear of a lawsuit if a closing window or sunroof injures someone stupid enough to hang a body part out of a window
      09-07-2017, 03:15 AM   #6
Dang3r
Schmollbraten
Dang3r's Avatar
Drives: RS 5
Same here in Germany, they must have changed the coding from the 435 to the 440 and I havent took a look into the specs until yet. For my 435 I set all limitations offline and were be able to operate windows and sunroof my way.
On the other hand its a matter of your insurance: If you change the coding and someone got harmed caused by this, you would charged for this and got surely no further support.
RS 5 - ZX12R LE - GPZ750 Turbo
I///M the infidel, your BMW-dealer has warned you about
Bobs' not your uncle and Trump is not my president!
      09-07-2017, 03:42 AM   #7
Almaretto
Almaretto's Avatar
Drives: Coded '16 F10/F15 MSport
If you do not want them to auto-unfold, fold with interior mirror button.
Once you fold with CA/keyFOB, they will auto-unfold.
      09-07-2017, 08:48 AM   #8
Billfitz
Another instance of trying to idiot proof, which is fruitless, as God keeps creating better idiots, despite the best efforts of said idiots in self-culling the herd. It makes no sense anyway, you're not likely to have someone in the car hanging out the window when you're out of the car locking it.
      09-08-2017, 11:11 AM   #9
zole2112
Modder of everything I own
zole2112's Avatar
36
Drives: 2013 335i Xdrive
I had to code my 2013 BMW 335xi F30 to close the windows and sunroof with the key fob. The mirror folds, I haven't really paid attention but I think the mirror unfolds when I unlock.
2013 BMW 335xi F30 N55/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 5/ Fuel=60/40 E85 & 93 oct/Stage 2 LPFP/CATuned coilovers/Megan Racing Swaybars/Powerflex Rear Subframe Bushings/Dual aFe Power Mach Force Mufflers/Resonator Delete = POPS & BURBLES!!
Coming soon - Trebila Tune, Speedtech 7670, PI and stage 3 fueling
      09-08-2017, 11:41 AM   #10
rak299
Thanks. I am looking at the F30_coding_reference v1.7 from this forum. Does this mean I should expect to currently see KOMFORTOEFFNUNG_FB set to "aktiv" and and KOMFORTSCHLIESSUNG_FB set to "nicht_aktiv"? (reference shows both default as "nicht_aktiv".) I assume I would want to change them both to "aktiv".
Thue?
Thanks again
      09-08-2017, 02:58 PM   #11
Almaretto
Almaretto's Avatar
Thue?
Thanks again
It varies by firmware how they are set from factory. But...
Set all _FB (Keyfob) to aktiv if you want it to work. _PA for Comfort Access.
