BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > LED rear indicator
Vorsteiner
      09-10-2017, 03:23 AM   #1
amsbmw
Drives: 3 series
LED rear indicator
Has anybody bought and coded rear led indicator bulbs ? I've fitted mines for a couple months and occasionally get a rear indicator failure and it starts flashing double the speed ( normally when a bulb is out) but the indicator is still on.
I have coded the below and still getting errors
Rear Turn Signals:
All of the codes listed can be found under the REM module.
3061 FRA_H_L_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold bulb checks for Rear Left Turn Signal.
3061 FRA_H_L_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm bulb checks for Rear Left Turn Signal.
3061 FRA_H_L_IS_LED -> aktiv : Setting Rear Left Turn Signal type to LED.
3061 FRA_H_R_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold bulb checks for Rear Right Turn Signal.
3061 FRA_H_R_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm bulb checks for Rear Right Turn Signal.
3061 FRA_H_R_IS_LED -> aktiv : Setting Rear Right Turn Signal type to LED.
      09-10-2017, 08:52 AM   #2
Rick4345
Rick4345's Avatar
Drives: 2017 M2 6MT LBB
Rear Turn Signals:
Did you look under FEM_BODY also? I believe that has to be changed also.
      09-10-2017, 09:49 AM   #3
amsbmw
Drives: 3 series
Rear Turn Signals:
I have not, just the codes that are above. Do you know which options it is under the FEM_BODY
      09-10-2017, 09:59 AM   #4
oceanview
oceanview's Avatar
Switzerland
87
Drives: 335i F31 RWD Autom.
I coded as OP. Works fine. Coded in January, no error ever since.
335i F31 RWD in SB | Sport-AT | M-Sport | DHP | 18" M-Perf Brake orange | 20" 405M | Quaife LSD | Cyba 3.5" Carbon tips | Rear M-Diffusor | Wiechers Strut Bar
Former drives: Volvo 144S '69, BMW 318iS E30 '90, BMW 328i Touring E36 '96, BMW 330i Touring E46 '01
      09-10-2017, 10:20 AM   #5
amsbmw
Drives: 3 series
Which bulbs did you buy?
      09-10-2017, 01:42 PM   #6
oceanview
oceanview's Avatar
Switzerland
87
P21W BA15S 50Watt CREE LED CANBUS error free
https://www.carlights.ch/led-1/tagfa...ct-11782967127
Those are white LED. Dealer didn't have amber on stock. We need to have orange/amber for turning light. But as I have amber rear cover glasses they work fine.
      09-10-2017, 10:11 PM   #7
Rick4345
Rick4345's Avatar
Rear Turn Signals:
Looking at the cheat sheet it shows the same changes you made under FEM_BODY and REM.
      09-12-2017, 05:13 PM   #8
oceanview
oceanview's Avatar
Switzerland
87
Sorry double post. Somehow can't delete it from the mobile App
