BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Reverse Default To Top View
      09-12-2017, 08:08 AM   #1
kern417
Drives: 2018 440i
When I put my car in reverse, iDrive defaults to the rearview camera. Is there a way to make the default camera in reverse be Top View/Surround View (with or without coding)?
Things that don't work:
1. Pushing the iDrive controller/camera button doesn't flip between rear camera and top view cameras. I have to go to the left, scroll down, and uncheck the box "Rearview Camera" every time.
2. Say I uncheck the box and reverse into a parking spot but don't like my alignment. If i inch forward and then go back in reverse for a 2nd try, it goes right back to the rearview camera <--- especially annoying when someone is waiting behind you.
3. (6MT Only) Park with shifter still in reverse and turn off the car. When I start the car with the shifter still in reverse, it shows the top view camera still. But if i go into neutral and back to reverse, it reverts to the rear camera.
I have a 2018 f32, but it seems like some 2017s may experience the same setup from the factory. Discussion started in this thread: http://f30.bimmerpost.com/forums/sho...php?p=22182196
      09-15-2017, 12:33 PM   #2
kern417
Drives: 2018 440i
bump
      09-15-2017, 08:06 PM   #3
Almaretto
Almaretto's Avatar
Drives: Coded '16 F10/F15 MSport
It is set by firmware. Some remember preferred view and others do not.
      09-15-2017, 09:23 PM   #4
kern417
Drives: 2018 440i
there's no way to adjust the native coding? or look up which firmware I have?
      09-15-2017, 09:26 PM   #5
Almaretto
Almaretto's Avatar
Not that I have seen. I know you will make many happy if you find solution.
You can easily check firmware with E-sys, but I have no idea which ones support. My F010 does; my F015 used to before last update.
      11-29-2017, 09:59 AM   #6
marcu
marcu's Avatar
Netherlands
Drives: 440i Coupe 2018
Anyone have an update on this?
2018 BMW 440i Coupe, High-Exec, MPPSK, HUD, Dig dash, touch-nav
2014 BMW 335, High-Exec, MPPK, MPE, HUD
2009 Alfa 159
2005 Alfa 156
      11-29-2017, 10:38 AM   #7
kern417
Drives: 2018 440i
A BMW Genius confirmed that the reverse camera became standard on LCI models because of US regulations that require reverse cameras on all new vehicles after 2018. With the changes to meet NHTSA requirements came a programming change to default the reverse camera view. I'm not sure how that affects other regions.
I have started selecting the PDC button when i'm in a parking lot or getting ready to park and i just scroll over to hover on the reverse checkbox. When I go into reverse i can quickly press the idrive controller to switch to top view cameras. It's a hassle but a lot better than sitting in the middle of the street while fumbling through menus.
      01-08-2018, 11:21 AM   #8
MattTheCarNut
Drives: F30 340i
OMG- I'm so annoy my 2017 340i defaults to rear-camera view in reverse EVERY SINGLE time.
Has anyone discovered coding to fix this?!? I want surround view on alllll the time....
2017 340i Alpine White over Oyster Leather. Extremely beautiful. B*tch to keep clean.
****Please Note: I had a 2014 428i. Then a 2017 M3. Then a 2017 330i b/c the M3 was mental. The 330i was horrible. So I now have a 2017 340i, which I particularly like (for the moment).***
      01-08-2018, 03:18 PM   #9
macs
Drives: f31
There should be this option somewhere as my LCI always starts remembering last status, top or rear cam. Unfortunately I don't know where.
      01-09-2018, 09:55 AM   #10
kern417
Drives: 2018 440i
This only works when pressing the PDC button or approaching an obstruction from the front. Like when I'm pulling into a parking spot forwards or into my garage, it starts up in the last used view (top view). But if you shift into reverse, it automatically defaults to the rear camera.
      01-09-2018, 02:37 PM   #11
macs
Drives: f31
Mine do this with reverse gear also
      01-10-2018, 09:29 AM   #12
kern417
Drives: 2018 440i
Are you located in the US? If you could find the setting it would be GREATLY appreciated.
Even if I shift into reverse and manually turn off the rear camera so that the top view cameras are shown, when i shift to 1st and back to reverse (without moving anywhere) it automatically changes back to the rear view camera. No matter what it won't stay in top view.
      01-15-2018, 11:35 AM   #13
KLez
Drives: 435d xDrive
Same problem for me... and i hate it.
BTW: I am from germany... and the default rear-view behavior is exactly the same.
I feel with you kern417
