BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 6WB coding tread
      09-13-2017, 03:33 AM   #1
chp10
Drives: F31
6WB coding tread
Hi,
because some of us installed already the 6WB Kombi i would like to start this tread. Here you can share your experience and findings with us.
Some of you asked me for the compass function. This can be found in section
3003 FZG Ausstattung -> Kompass Graph Enable -> set to aktiv.
I found also Motorleistung Enable which should show the engine power used (only workingin sportmodus). Unfortunately it is not working in my car. Maybe someone can try it and confirm. As it seems it is working at least for the F10 series cars.
In my 2013 F31 is still the HUD not working, i guess a coding mistake (resolution, wrapping...?), so if someone can help me would be nice.
      09-13-2017, 02:45 PM   #2
hanselfransel
Till now i did not get engine power display work in my F30, so same as your car
      09-14-2017, 06:33 AM   #3
sbinshihon
Drives: X5 35i M Sport
Code to enable the additional Digital Speed display in alternative unit.
DKombi -> 3000 Anzeige_konfiguration, 32 -> Digital_Tacho_Enable -> mph_kmh (default: keine_anzeige)
      09-16-2017, 04:22 PM   #4
dengus
Drives: 320D f30 2013
Hi! Sorry if I hijack, Im trying to do the 6wb retrofit but so far I have no luck!
I have try everything I could imagine and everything I have read but no luck, I can't see Dkombi , only Bkombi...
I have read and delete Bkombi from svt, I have swap fibre on connectors, I have try diferents esys....
Any ideas?
      09-16-2017, 06:26 PM   #5
hanselfransel
I can do it for you via teamviewer now at the moment
      09-17-2017, 04:46 AM   #6
dengus
Thanks, but I just see it...
It's anything I should look at?
      09-21-2017, 04:20 PM   #7
dengus
Hi all!
I have retrofitrd 6wb to my 2012 F30 and it seem to work everithing apart from that on kombi dosent show sport+ mode, it does on NBT.... this dosnt botther me much but one thing i cant solve is that the time and date dosnt save. I put it and it dosent get fix.
I have try to change dates on FA, i have try codding diferents CAFD to nbt and kombi with no luck!
Any ideas? Anyone has experienced this?
Thanks.
      10-13-2017, 09:39 AM   #8
xnap
Drives: F30
Hi All,
Just installed the 6WB on my 2016 F30. Everything is fine except the navigational display that I used to get on my 6WA does not show up? Anyone can advise what additional coding needs to be done up?
Help appreciated thanks!!
      10-13-2017, 02:21 PM   #9
chp10
Drives: F31
as far as i remember you have to activate fpk coming road map bmp.
also look if you set in the HU_NBT Kombi CIC to high.
      10-13-2017, 07:51 PM   #10
xnap
Drives: F30
Thank you so much.. may I know what is "activate fpk coming road map bmp"
and which module section is "HU_NBT kombi" ?
Sorry for being such a noob.
      12-08-2017, 06:10 AM   #11
chp10
Drives: F31
Did someone found a solution for the HUD issue? Mine is still not working. Sometimes it is starting up but after a couple of seconds it turns off again.
Another problem with the 6WB is that the navi advise does not disappear. It stays until the next advise. Have anyone the same behavior?
THX
      12-09-2017, 07:22 AM   #12
sdjro
Romania
Drives: BMW F32
From what i understand the steps for coding after replacing in fa 6wa with 6wb are :
a)inject cafd for dkombi
b)vo code dkombi
c)vo code nbt
but how to tell wich cafd to use ? i selected the one wich is same with my i step but i still have trouble setting the date.
      12-09-2017, 08:59 AM   #13
chp10
Drives: F31
exactly what i did already.
      12-13-2017, 11:04 AM   #14
sdjro
Romania
Drives: BMW F32
My 6wb cluster is working except i can not set the time and date on nbt, does any one know what is wrong?
      12-13-2017, 12:59 PM   #15
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
FDL Code HU_NBT => KOMBI_CIC = kombi_high.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      12-13-2017, 03:17 PM   #16
sdjro
Romania
Drives: BMW F32
Thank you Shawn! you're the best as always!
      Today, 10:51 AM   #17
zaynn786
Drives: F30 XDrive 320d
Just bought a 6wb unit from ebay - don't think it's new. Can someone direct me to the compete guide to code the new cluster?
