      09-07-2017, 03:40 AM   #12453
Almaretto
Almaretto's Avatar
Drives: Coded '16 F10/F15 MSport
Originally Posted by 37psi View Post
Can someone share the link with me for esys? Thanks
Originally Posted by F30TomUk View Post
Hi Shaun, would really appreciate if you could forward the links onto me, thanks.
Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links
      09-07-2017, 06:25 AM   #12454
Surg_Capt_R
Surg_Capt_R's Avatar
Bermuda
1928
Drives: F80 - M:- CP
Thanks
      09-07-2017, 10:27 AM   #12455
Almaretto
Almaretto's Avatar
Thanks
      09-07-2017, 11:56 AM   #12456
Crasherr
Drives: 2013 F30 328xi
Can I please get the latest link please Shawn, Thank you
      09-07-2017, 12:53 PM   #12457
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
PM sent.
      09-07-2017, 01:16 PM   #12458
rob10k8
Drives: 2015 435xi
Just picked up a 2015 F32. Can't wait to try this!
      09-07-2017, 02:59 PM   #12459
F30TomUk
Drives: F30 335i
Thanks Almaretto!
      09-07-2017, 03:00 PM   #12460
Almaretto
Almaretto's Avatar
Thanks Almaretto!
      09-09-2017, 06:35 AM   #12461
ramonE90-NL
Netherlands
18
Drives: bmw F30 320iA
Is it possible to add lane change warning, and blind spot detection in the hud? I dont have the buttons for it. But maybe it can be set to always be on?
      09-09-2017, 04:22 PM   #12462
Almaretto
Almaretto's Avatar
Lane change but not blind spot as far as I know. Though, I think it looks crowded and I coded off.
      09-09-2017, 08:48 PM   #12463
davejack
davejack's Avatar
Drives: F22
Hi,guy!
Could you take some coding cases you done as example to share with us,just like these:
BMW F15 X5 FDL Coding HUD Head-up display
BMW F Series Sport Display Coding Guide
You would better to post with pics,so that we can imitate your posts.
      09-11-2017, 08:42 AM   #12464
rob10k8
Drives: 2015 435xi
Anti Dazzle
I was looking through this thread couldn't find any details around enable the anti-dazzle feature. Is there somewhere I can find that?
I'm new to the forum, so not sure if I can accept PMs yet....
Rob
      09-11-2017, 10:26 AM   #12465
Almaretto
Almaretto's Avatar
Rob
NGHB only work on Pre-LCI F3x. Is that what you are trying to code?
      09-11-2017, 01:11 PM   #12466
rob10k8
Drives: 2015 435xi
I think so... New to BMW, so those are new terms for me, but I think I found what they mean. My F32 is 2015, I believe that is pre-LCI?
      09-11-2017, 01:22 PM   #12467
Almaretto
Almaretto's Avatar
How-To PDF.
      09-11-2017, 01:41 PM   #12468
rob10k8
Drives: 2015 435xi
Thanks!
Rob
      09-11-2017, 01:43 PM   #12469
Almaretto
Almaretto's Avatar
Thanks!
Rob
      09-12-2017, 10:01 PM   #12470
acevesf
Drives: 2017 430i Gran Coupe
Hey all I recently picked up an ‘17 f36. Is the first post still up to date and accurate? Is that the same cable I need to order?
      09-12-2017, 10:05 PM   #12471
Almaretto
Almaretto's Avatar
Originally Posted by acevesf View Post
Hey all I recently picked up an 17 f36. Is the first post still up to date and accurate? Is that the same cable I need to order?
Info is dated. You can get any ENET from Ebay, Amazon, or Bimmergeeks.
      09-13-2017, 09:01 PM   #12472
Texasdoc1
Drives: 2016 328i
Originally Posted by Texasdoc1 View Post
OK, looking at all the coding options, I *may* want to change a few other things....
So, is this the parameter that I change? Change this to "aktiv"?
FEM_BODY, 3040, CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK
FEM_BODY, 3090, TEMP_LEHNE_FTUFE_*_FRONT to a lower HEX value? FEM_BODY, 3110, ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN.
How do I tell which headunit I have? 6NH, 6NK, or 6NS, what is NBT, or CIC?
I have a 2016 with NAV.
Thanks in advance? Can't wait to get my cable from Amazon.
(By the way, not ANY E-SYS cable from Amazon will work. Purchased "Eximtrade OBD2 to ENET for F-Series..." one, had to return it. It was wired completely wrong.)
Since nobody responded to my previous post.... I went ahead and tried to connect. Following the "Getting Started Coding" Parts 1-3.
Psdzdata 3.62.3.000 (deleted old, copied to C:\Data)
Launcher 2.7.1.135 (Car Series F030) Runs fine.
E-sys 3.27.1 (Target F020 - not direct) Finds the VIN, Click Read, Loads.
Expert Mode, Click Coding, Click the Read button, FAList shows up.
Instructions say to click "Read (VCM)" under SVT Actual. My button says "Read (SVT)". Click it anyway. It loads lots of stuff in the SVT window.
Now instructions say to click CAS, CAFD_xxxxx. I don't have that. I'm looking to change FEM_BODY, so I click on CAFD____ under FEM_Body and click "Read Coding Data". I get an error stating :
FEM_BODY [40] [Kxxxxxx]
readCPS o.k.
CAFD_00000794_014_040_122 Fehler:
File for "cafd_00000794-014_040_122" not found! [C012]
What am I doing wrong?
      09-13-2017, 09:16 PM   #12473
shawnsheridan
...I don't have that. I'm looking to change FEM_BODY, so I click on CAFD____ under FEM_Body and click "Read Coding Data". I get an error stating :
readCPS o.k.
You haven't read this whole thread?
Scroll up to post # 9212:
http://f30.bimmerpost.com/forums/sho...postcount=9212
      09-13-2017, 09:37 PM   #12474
Almaretto
Almaretto's Avatar
readCPS o.k.
Cafd not found means you need different PSdZ, usually an upgrade.
I do not mean any ENET would work, but they are less likely prone to be wired wrong/faulty as K+DCAN's. It is wise to buy from seller with good rating.
