BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Front Park Distance Control (PDC) Retrofit DYI
Vorsteiner
      08-23-2017, 02:06 PM   #133
Davef30hull
Drives: 2013 F30 msport
argh does anyone know how to resolve this error? I have bother front and rear PDC having just retrofitted the front. I've come coded 508 and removed 507. to be honest I have tried all combinations of course coding and still get this error. double check rem connections and are all correct :
      08-23-2017, 03:10 PM   #134
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Try running ISTA and see what comes up as fault.
Did my post help? Click "Appreciate!"
F30 328i xDrive Sport Line | 475 BSM | 2A5 18" | Cold Weather | Nav Pro | Tech Pkg | Injen Intake | DINAN Sport Tuner | Integral Audio | Retrofit: 522 & 524 EDM | 5AC HBA | VLD | 2TB SAT | 508 | 3AG | 5DL | 6WB
      08-24-2017, 03:32 PM   #135
Davef30hull
hi thanks for the reply, just tried ista and no fault codes came up at all. clicked reset for the hell of it but the PDC error came up on screen again looks like a few others have had this as well - dying to know what the fix is!
      08-29-2017, 08:15 AM   #136
jkwhar
In ISTA, under "Vehicle information"->"control unit tree"->"display fault memory" shows nothing?
      08-29-2017, 09:57 AM   #137
Kiwoz
Kiwoz's Avatar
Drives: 320dx F31
I had the same problem. Took me to reconnect 2 cables, they were reversed (same color ) .. i controlled everything twice.. but it dont worked.
ISTAT showed me some faults in the memory.. After the clean up of the memory everything worked fine!
      08-30-2017, 09:22 AM   #138
Davef30hull
Can I just double check my front pdc plug to rem connections...
Pin 1 front pdc to pin 48 rem
Pin 2 front pdc to pin 36 rem
Pin 3 front pdc to pin 53 rem
Pin 4 front pdc to pin 40 rem
Pin 5 front pdc to pin 41 rem
Pin 6 front pdc to pin 52 rem
is this correct?
      08-31-2017, 08:38 AM   #139
Kiwoz
Kiwoz's Avatar
Drives: 320dx F31
Have you checked for errors with ISTA?
DIY says:
Connect branches A2–A7 as follows to plug A174*14B
SW 54-pin socket casing, on REM A174:
- Branch A2, GN/WS cable, to PIN 48
- Branch A3, BR/WS cable, to PIN 36
- Branch A4, BL/RT cable, to PIN 53
- Branch A5, BL/SW cable, to PIN 40
- Branch A6, BL/BR cable, to PIN 41
- Branch A7, BL/GN cable, to PIN 52
Connect plug A174*14B to REM A174
https://drive.google.com/file/d/0Byn...ew?usp=sharing
      08-31-2017, 04:13 PM   #140
Davef30hull
hi checked data and no faults in any of the ecus which I find surprising. Looks like the pins are wired correctly too!
      09-02-2017, 01:10 PM   #141
Davef30hull
noticed the plug at the bumper was full of moisture so letting it dry
regarding ista not reporting any errors I do get this message when I first open it. could this have any bearing?
      09-05-2017, 12:24 AM   #142
Icydubloon
Icydubloon's Avatar
Drives: 2013 328i
Just did the retrofit. As a note for others, you need to connect both of the following wires for the PDC on/off switch to work.
CC PIN1 to ICM PIN28
CC PIN2 to ICM PIN6
My (new) center console switch has the buttons for traction control, sport/eco up down buttons, and the PDC button.
If you have rear PDC, the PDC button will work without having to code front PDC. This is a nice check to perform before moving on to other parts of the install/coding.
      09-07-2017, 06:57 PM   #143
kubax86
Poland
Drives: F30 335i,F48 28i,F83
Hello, do you have any photos where you route cables under the hood?
thank you!
      09-07-2017, 08:46 PM   #144
agilbert314
Drives: F30 328i xDrive Sport 2013
Originally Posted by jkwhar View Post
If you're talking about the single wire (green and/or blue) that connects the Center console to the ICM, that cable came with something that I ordered. I'll have to dig thru my pictures and see what it came with.
EDIT: I think it came with the HSD Cable set for the surround view retrofit.
Thanks jkwhar,
Does anyone knows the length of this wire and which pins are required to make it myself?
      09-08-2017, 09:59 AM   #145
jkwhar
Originally Posted by agilbert314 View Post
Thanks jkwhar,
The lengh is short, less then 12" since the ICM right next to the ebrake. Can't seem to find the pin size for it though.
      10-09-2017, 10:38 AM   #146
dopamine
dopamine's Avatar
Drives: F10 LCI
can someone please share EBA file for mini f56 rear PDC retrofit?
EBA 2287372 to be exact
      01-22-2018, 02:51 PM   #147
szmib
Drives: 120dA F20
Hello,
greetings everybody! Half a year ago I bought a 2014 F20 (CIC navigation)- sadly without PDC front and combox. I got into the PDC retrofitting a month ago, this is by far the best How-To i could find, i hope it works for the F20 as well
I did some research and in my opinion I need the following parts:
66202338070 retrofit set front PDC for M sport 0337 and M aerodynamic 0715
61129357958 cable set for F20 front bumper, no problem here as well
61319252911 fun fact: I checked this part on ebay, you can buy one of these for like 30€ - if you dont need the PDC button
66209261617 well, ultrasonic sensor colored in blue. The original BMW would set me back 170€/piece, I checked at ebay and found these: https://www.ebay.de/itm/NEW-OEM-BMW-...QAAOSwODFaXJCJ what do you think?
51117324343 as far as I get it: I glue this things on the inside of my bumper? Sadly, I didnīt find anything for the F20. Possibility 1: I am too dumb to google. 2: it doesnt exist. 3: they are the same for the F20 as for the F30
Besides the parts, I have three more questions:
a) some "How-To" do list a ECU in the parts list, do I need it or not?!
b) quote starting post: "On the guides for the PDC holders, drill the holes carefully to 18mm." Iīve checked some front bumpers online, I didnt see any guides on the backside, can someone confirm there are guidelines?
[not really related to the topic, but well:
c)I plan on retrofitting backup camera and combox as well, do it all together or split it in 3 different tasks? There are a lot of imformation about the backup camera, but not so much about the combox).]
(i have no experience working on my car, thats why i want to know everything in detail before i start working on it)
sorry for the bad english :S
lg
szmib
      01-22-2018, 03:21 PM   #148
jkwhar
Originally Posted by szmib View Post
Hello,
lg
szmib
http://www.realoem.com/bmw/enUS/show...diagId=03_2012
The pdc mount is under the retrofit catagory. (I picked a random f20 so select your correct vehicle. Also, there are two types of mount. One is for m-sport and one for non m-sport)
a) If the ECU you're speaking of is the REM, it depends if you have the pins for the PDC. When I checked mine, I didn't have the pins and needed to replace and code the REM.
b) This also depends, I believe most, if not all OEM bumper should have the markings on the bumper. Mine did.
c) Do them in steps. My final was to have surround view but to have surround view, I need front and rear PDC. I did the rear PDC, then did the front PDC and then added surround view. This way if something didn't work, you know its only within what you were working on.
Goood luck!
szmib0.00
      01-22-2018, 03:39 PM   #149
Jhnblckwood
Drives: F30 2014 320i xdrive
Anyone go with the non oem sensors? If so any good or no?
      01-22-2018, 04:00 PM   #150
jkwhar
Not sure what the prices you found were but I got mine for ~18$ shipped each.
http://f30.bimmerpost.com/forums/sho...&postcount=267
Now its just a little under $17 shipped from cali.
      01-23-2018, 02:37 PM   #151
szmib
Drives: 120dA F20
okay found it, I think: http://www.realoem.com/bmw/enUS/part...&q=51118060287
ok, I will check tomorrow.
I found one ebay auction where you could see the markings (and 20 where you could see... nothing), i ll just go with a "there are markings".
Goood luck!
The Combox will be a lot more work, not like doing it, but gathering all the information. Every How To i find is for E60 or E90 or in combination with installing the whole CIC system and... weīll see...
      01-26-2018, 12:03 PM   #152
boltinvader
Drives: BMW F
Hi got the problem, that I Coded the Front PDC as VO and now its only showing the front and like in page one my Button isnt working
Any solutions here?
None of the PDC is working. The PDC in the back is working fine.
Can Anyone help me? Maybe someone could give me remote help from somewhere?
      01-26-2018, 12:47 PM   #153
jkwhar
Any solutions here?
Which VO did you use?
Back PDC works but the front doesn't? Have you tried running ISTA/D and if theres any error?
      01-27-2018, 02:26 PM   #154
boltinvader
Drives: BMW F
My ISTA isnīt working...
This is the link to my VO
https://picload.org/view/ddpriidw/esys.png.html
I put 507 and 508 in it
... Afer removing the 507 the PDC Rear and Front are Working. One Problem is that the PDC is just Beeping. Maybe the sensors are to deep in the Front?
And my Middle Console Button isnt working too. is there any solution?
