BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding for 6NR BMW Apps?
      02-10-2015, 03:14 AM   #45
bojan_a
bojan_a's Avatar
Sweden
Drives: BMW F11 520d Xdrive 2016
Send a message via Skype™ to bojan_a
Hi guys,
Just to follow up on my problem I had. Just got an Android 5.0 lollipop upgrade to my phone and It has started to work fine for my Samsung Galaxy S5 with usb cable. I do not need snapin adapter.
I have only identified one problem, I have no sound when playing audiofiles thourhg the player in BMW apps. Anyone has any clue what it can be? Everything else works fine.
//Bojan
      04-15-2015, 06:45 PM   #46
sammor20
Drives: BMW X3 F25 2012
Originally Posted by shawnsheridan View Post
6NR BMW Apps is in addition to 6NL/6NS Enhanced Bluetooth Option Code.
I have a source that gets 9C FSC Codes from BMW AG. Cost is around $235 USD.
Dealer will not help you in anyway with retrofitting 6NR BMW Apps. You would need to use E-Sys to Import and Activate the FSC Code, add 6NR to FA, and Code car.
Hi shawnsheridan,
Could you please share with me by MP your source to get a 9C FSC? Also, do you know if there is a step by step guideline to retrofit the 6NR BMW apps?
Thanks in advance!
      04-15-2015, 06:53 PM   #47
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by sammor20 View Post
Hi shawnsheridan,
Thanks in advance!
You cannot send or receive PM's yet. Send me one when you can.
There is no Tutorial, but the steps are:
1) Add 6NR to FA
2) Import and Activate FSC Code
3) VO Code Head Unit / Combox for 6NR
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      01-09-2016, 03:45 AM   #48
Bigone
Bigone's Avatar
Italy
Drives: 120D (F20)
1) Add 6NR to FA
HI shawnsheridan and thanks for your valuable advice.
Only one thing. I bought the '' FSC lifetime "by a Canadian site with which I updated my navigation maps.
Is the FSC that I have the same i can import and Activatein the VO Code Head Unit / Combox for 6NR ?
      01-09-2016, 03:58 AM   #49
shawnsheridan
No. Map FSC Code is different than BMW Apps FSC Code.
Yes, VO Code HU_CIC and CMB_MEDIA with 6NR in FA.
      03-20-2016, 01:29 PM   #50
mgaciah
mgaciah's Avatar
19
Drives: F23 cabrio, F85 X5M
VO Code:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
Shawn I having this error whe I tried to code ECU...
Abort!
Asynchrone programming failed! [C049]
task extension configuration missing in container - maybe the template is too old [1906]
      03-20-2016, 01:36 PM   #51
shawnsheridan
Abort!
If you are using 58.x PSdZData, you must also use E-Sys 3.27.1.
      03-20-2016, 01:40 PM   #52
mgaciah
mgaciah's Avatar
19
ok let me check
      03-20-2016, 02:05 PM   #53
mgaciah
mgaciah's Avatar
19
Ok, now It went thru, however I got a lot of errors during ecu coding, I have a RPA and some traction error messages on screen, I just turn it off for a while turn back on and everything backs to normal, I added 6NR but I have no apps on Connected drive menu, do I need the FSC to get it? I'm doing this on my F23 01/15 production date.
      03-20-2016, 02:07 PM   #54
shawnsheridan
Yes, you need NBT and a 9C FSC Code. PM sent.
      04-05-2016, 05:04 PM   #55
pcvet
pcvet's Avatar
Drives: BMW 328i xDrive Touring 2012
Shawn,
Can you send me your contact of where I can get the 9C FSC Codes please.
Thanks in advance.
      04-05-2016, 05:09 PM   #56
shawnsheridan
Originally Posted by pcvet View Post
Shawn,
Thanks in advance.
PM sent.
      04-11-2016, 03:53 PM   #57
Bowen151
Drives: BMW 2012 320D Efficientdynamic
I've read the thread and i'm a little confused on the terminology.
Can you please let me know what the following stands for in relation to the coding process:
VO
FSC
FA
Also, am I right in thinking I can't activate the 6NR apps as I have only the following:
S676A HiFi speaker system
S696A DVD changer
S698A DVD Area-Code 2 for DVD
S6AAA BMW TeleServices
S6ABA Control for Teleservices
S6NFA Music interface for Smartphone
S6NKA Link for Bluetooth and USB device
I have a CIC unit (non-navigation) along with the combox, stock 6.6' screen + iDrive controller and the DVD changer is in the trunk not the glovebox. F30 built 04/2012
Ultimately I would like online connectivity and video functionality (plus a bigger screen).
      04-11-2016, 06:07 PM   #58
shawnsheridan
VO
FSC
FA
S696A DVD changer
VO = Vehicle Order
FSC = Freischaltcode (Enabling code)
FA = Fahrzeugauftrag (Vehicle Order)
I think you have CHAMP2 Head Unit, so you could not have 6NR BMW Apps. If you PM me your short VIN, I can confirm it.
      04-12-2016, 09:01 AM   #59
Bowen151
Thanks Shawn, I'll PM you my short VIN now.The help is very much appreciated!
      04-12-2016, 09:13 AM   #60
shawnsheridan
You have HU ENTRY head unit. You cannot have BMW Apps.
      04-12-2016, 09:50 AM   #61
Bowen151
Thanks very much for taking the time.
So am I right in saying a retrofit to NBT with nav and a larger screen should give me what I want? Or at least give me the hardware I need to activate BMW apps? (along with the video playback)
      04-12-2016, 10:28 AM   #62
shawnsheridan
Correct.
      04-30-2016, 02:59 PM   #63
mjuhl2003
Drives: BMW F01 730D M-Sport
regarding bmw apps - I have used an iphone 4s for a long time with my f01 with apps - however after I reset the phone (wanted to delete everything on it) I cannot make it work with bmw connected and apps.
I have an Ipad air (same os and same version of BMW connected) which works perfect. Have any of you had the same problem or have I forgot something after the reset to make it work with the APPS?
Thanks
Mogens
      07-02-2016, 02:42 AM   #64
RelAlex
Drives: bmw f07
1) Add 6NR to FA
Hi Shawn!
Should i write updated FA (with 6NR option) to the car?
Will it cause any issues when dealer decide to make sw update?
Thanks.
      07-02-2016, 04:39 AM   #65
shawnsheridan
Originally Posted by RelAlex View Post
Hi Shawn!
Thanks.
If 6NR was valid factory Option for car's Build Date, and car has all required hardware, then it should not be any issue.
      07-05-2016, 01:43 PM   #66
RelAlex
Drives: bmw f07
Got it. Thanks!
Everething passed fine.
