BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding for 6NR BMW Apps?
      07-09-2016, 04:20 AM   #67
tomsab0
Drives: 320xd GT
@Those who have retrofitted NBT and 6NR: Did you change the VIN in the FA to NBT VIN for VO coding 6NR or did it work with car's VIN?
      07-09-2016, 09:09 AM   #68
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
I would always code a retrofitted Head Unit using VIN in FA that matches VIN of Head Unit, not car.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      07-09-2016, 10:01 PM   #69
BoldSauce
Drives: 2015 328i
So just to be clear. Read/activate FA, add 6NR, write the new FA to the car, then import/activate the Base64 decoded 9C FSC, and VO Code the Head Unit (HU_ENTRYNAV in my case)?
That should prevent losing the 9C FSC in the event of a later software update, right?
Seems pretty straight forward, but just confirming.
      07-09-2016, 10:09 PM   #70
shawnsheridan
FSC Code does not need to be Base64 Decoded in newer versions of E-Sys.
I don't make any assurances for what ISTA/P will do now or in the future. Too many variables and unknowns.
      07-09-2016, 10:38 PM   #71
BoldSauce
Drives: 2015 328i
I guess I meant more in terms of past experience. Of course no telling what the future may bring, but in the past adding 6NR worked to keep the 9C FSC right? Or was there another step?
Also, any idea what the Diagnostic Address for HU_ENTRYNAV is in decimal (for the FSC import and activation)?
Thank you!
      07-09-2016, 10:49 PM   #72
shawnsheridan
Also, any idea what the Diagnostic Address for HU_ENTRYNAV is in hex (for the FSC import and activation)?
Thank you!
Yes, but in the past, there was no HU_ENTRYNAV, and that was before 6AK replaced 6NR, so now FA Date and Option code has greater significance.
      07-10-2016, 05:49 AM   #73
tomsab0
Drives: 320xd GT
Solved: 6VB had to be deleted... Now APPS arme working incl. BMW Live, Internet & Teleservice. I also tried 6AM (RTTI) but it doesnt work. Also 6AC (Emergency Call). When 6AC is added, Bluetooth Tethering is disabled. So I think this needs a TCB... But perhaps there is another possibility to get it work with BT Data...?
      07-19-2016, 02:59 PM   #74
lolshto
Drives: F10 535
Do I understand correctly that without 9C FSC code you can't get Apps to work with Bluetoothe Internet Streaming?
I don't have 6NR option, but I wanted to code it and use Apps with internet sharing from Bluetooth ( not BMW )?
I did this with BMW Live and Internet. They use mobile phone internet.
      07-19-2016, 04:16 PM   #75
tomsab0
Drives: 320xd GT
Without FSC no Apps...
      09-08-2017, 04:48 AM   #76
yoyoso
Drives: BMW F30
Hi shawnsheridan
I need too a 9C FSC code for my 3 series 2013.
Can you help me?
      09-08-2017, 07:32 AM   #77
shawnsheridan
Originally Posted by yoyoso View Post
Hi shawnsheridan
Can you help me?
I replied to your same PM.
      11-06-2017, 07:15 AM   #78
cryptomit
Drives: 320d 2012
Guys,
Anyone can give me advice what I need to code to enable USB for APPS in media MENU in NBT?
Currently I have USB, Bluetooth and AUX-Front, but not this USB with smartphone icon as shows in attached picture.
What line needs to be code?
Thanks.
Click "Appreciate" if I helped you.
      11-06-2017, 09:14 AM   #79
shawnsheridan
Originally Posted by cryptomit View Post
Guys,
Thanks.
Is this set?
HU_NBT => API_USB_VIDEO = both?
      01-05-2018, 08:02 PM   #80
Anastomose
Spain
Drives: BMW 420D Coupe
Originally Posted by shawnsheridan View Post
You have HU ENTRY head unit. You cannot have BMW Apps.
I have hu entry Head Unit and i have access to buy ConnectedDrive and bmw remote..
where i can find BMW Apps ?
I suppose BMW Apps are inside ConnectedDrive or not?
Why a car with business Nav cannot have bmw apps?
Thanks
      01-05-2018, 08:10 PM   #81
shawnsheridan
Why a car with business Nav cannot have apps?
Thanks
You have HU ENTRYNAV head unit, not HU ENTRY head unit. Big difference.
Connected Drive contains Apps.
      01-05-2018, 08:59 PM   #82
Anastomose
Spain
Many thanks Shawnsheridan
With hu_entrynav "only" need , Adding 6NR to VO , importing and activating 9c fsc code in Head Unit and coding Head Unit. Thatīs all?
Combox?
Bmw Remote need fsc code too?
Many thanks
      01-05-2018, 09:08 PM   #83
shawnsheridan
Combox?
Many thanks
You just need HU_ENTRYNAV and 9C FSC Code and 6NR Coding.
No FSC For 6AP Remote Services, but this is a Telematic Subscription Service that requires VIN with authorization.
