BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Replacing or removing fog lamp cover from Luxury to sport.
      05-07-2013, 11:55 AM   #23
overkill1125
overkill1125's Avatar
Drives: 2019 440xi Gran Coupe
Originally Posted by MoneyFor View Post
No holes where needed, I made a small modification to the trims because not every plastic clip fitted the bumper but they where not needed to put the cover in place. I drove about 100 miles with them mounted and everything stays in place
Great, could you explain the process for the swap?
I know what parts is needed but just don't know how to remove old trim.
It would be a great DYI thread.
Much appreciated!!!
      05-08-2013, 01:04 PM   #24
overkill1125
51117300739 Left
51117279702 Right
51117293105 Left silver trim
51117293106 Right silver trim
Regards Kris
Noticed your parts number.
Shouldn't the right cover be part#51117300740 instead of 51117279702?
This is what I got from www.getbmwparts.com
Or maybe its the same part with different part#?
      05-10-2013, 07:58 AM   #25
MoneyFor
MoneyFor's Avatar
Belgium
25
Both parts could be used, the difference between my part n° and the one from getbmw is that mine is complete open and the part n° from getbmw is partially open. The left side is also partially open, so I think you best use the part n° from getbmw if u want both sides look the same. The part I bought by my dealer came with the part n° I posted so maybe I change it myself in a while after some stone chips They cost almost nothing so I don't mind changing them when needed.
      05-10-2013, 09:13 PM   #26
overkill1125
Thanks for the useful info. I'll order the parts and hope that the swap goes smooth.
      05-24-2013, 07:06 AM   #27
Rut
Drives: F30 318dA
Sport trim piece does not fit base bumper
Hi Guys,
I'm new to this forum, and was interested in this mod. So I got one of these sport trim pieces, but was unable to fit it to my base bumper.
I noticed also that the slits where the clip go into are a bit different on the top of the trim piece, but by removing these the problem was solved.
Next to that, I noticed that in order to let the trim piece fit to my bumper, I should cut away some bumper material??!! I just cannot push it back far enough to make it fit.
Any advice?
Cheers Rut
My car is a (Euro) 318dA base (no lines)
The trim piece has nr 51117300738
      05-25-2013, 05:45 PM   #28
overkill1125
Originally Posted by Rut View Post
Hi Guys,
Any advice?
Cheers Rut
I just did the swap today, and it does not fit 100% without some slight mod to the cover. I suggest not to cut/trim the bumper but to trim down the cover instead. I removed the upper 4 clips but heard only 3 was enough. Another member on this forum did the same thing and told me that the cover holds well just with the remaining side and bottom clips. He put some (mounting mastic) on the top to avoid wiggling of the cover.
What is mounting mastic?
      06-15-2013, 09:03 AM   #29
jamesakano
Drives: E90 320d MSport Business Ed
Any updates?
Does it fit perfectly? What modifications are needed apart from removing clips from the top of the trim?
Many thanks
      06-17-2013, 02:06 PM   #30
N8k
Drives: F30 BMW
Hi, can you make some photos of your covers please!! Interested in this mode so much
      06-17-2013, 02:32 PM   #31
overkill1125
Won't be able to take photos now since the covers are installed on the car. It's kinda hard to remove them without risking in breaking one of the clips.
You'll be able to see my car with the cover installed in this thread.
http://www.f30post.com/forums/showthread.php?t=851544
      06-18-2013, 03:49 AM   #32
N8k
Drives: F30 BMW
Thx !!!
      07-24-2013, 06:19 PM   #33
miretni
miretni's Avatar
Drives: F30 28i
Hey, F555
I m wondering how much force will be require in remove the trim with hands,
My sport trim was arrived, but i couldnt remove all the clips which is too tighted
I was try my best and only 1 clip has been removed from inside... Can you take some photos for the trim and let me make sure what is the position of the clips?
Thx
      07-24-2013, 06:24 PM   #34
miretni
miretni's Avatar
Drives: F30 28i
here is the picture of the 1 clip removeal
      07-30-2013, 11:10 AM   #35
killakam6687
Drives: 2013 328i xdrive (Canada)
Hey I'm very interested in this mod. One question I had, I noticed that four parts were listed in order to complete this mod. The case and then the silver accent part. Is there any assembly required for those two parts? I was under the impression that I just take the original case off and replace it with this one, which comes with the silver accent. From what I see with these parts though it seems the case and the silver accent come separately. Is there a lot of work involved to put the case and accent together? Also where did you guys order your parts from? I'm thinking of ordering mine from bmwpartsupply.com. Any other recommendations?
Thanks!
      12-22-2013, 02:00 AM   #36
AdiSinghV12
India
56
Drives: 320d M-Sport, X1, 525d
I'm thinking of doing this very same mod on my Luxury Line. I wanted saddle brown interior but unfortunately we don't have the Saddle Brown option in the Sport Line hence placed the order for the luxury line.
Now the main thing is, I love the Sport Line bumper and want to get the same look as soon as I pick up the car.
Should it be a SNAP ON fit without any hassles or modifications and will it look like it was this way from the factory?
Here is a last of part numbers I have gathered. Please let me know if any addition is needed. Once again a reminder, I wanna go from the Luxury Line trim to the Sport Line trim.
Close Grid Left: 51117300737
Close Grid Right: 51117300738
Finisher Rod Left: 5117292105
Finisher Rod Right: 5117293106
Finisher Rod Center: 51117279699
I got these part numbers from real oem. If anything more would be needed please let me know.
      12-26-2013, 06:34 PM   #37
mscalissi
Brazil
Drives: BMW 320i GP
Monefor,
I tried to update my fogs with the sport cover but didn't fit...it's possible send me some pictures of your adjustments?
My bumper is standard so I'm not sure if it's the same of your car.
Thanks anyway.
Mscalissi
      01-21-2014, 12:04 PM   #38
AdiSinghV12
India
56
What about this?? About to order...
Confused coz this is different from above mentioned part numbers
      01-24-2014, 06:30 AM   #39
WHL102
Drives: '16 GTI S, DSG, 4-Door
Ordered the parts for the sport line fog covers... I just need someone to confirm that the black surround trim simply pulls in and out using force. Which corners would you attack first!
I have read elsewhere that they are held on behind the bumper...
I would appreciate any PM or reply to this!
Looking forward to putting on that sport line trim!
      01-27-2014, 06:40 PM   #40
Marvin187
Drives: 2013 BMW 320i
I have a pair
Hi guys,
I have a pair of these covers for 328i/335i, let me if you're interested.
P/N: 51117279702 Open Grid, Right has top clips removed to fit base model F30.
P/N: 51117300739 Partially Open Grid, Left New.
PM me for more info.
      01-27-2014, 07:23 PM   #41
Marvin187
Removed and Replaced Fog Cover Base to Sport line
Guys today I finally replaced my Fog Covers. I have the 320i with Base line trim. So far I replaced the Front Grills with M Performance and added the rear deck spoiler, today the Fog Covers. Below are the pictures.
I had to remove the top 4 clips and use a dremel tool to cut a small piece from the bumper. The result was an OEM fit IMHO. Tell me what you think?
      01-29-2014, 08:12 AM   #42
AdiSinghV12
India
56
Looks fantastic! Where did you order these from? Also, can you tell me whether this will be a snap on or some mods would be needed for fitting em onto a luxury line?
PS: This is the close grid one right?
      01-29-2014, 09:30 AM   #43
Marvin187
Yes these are the closed grid. I got them a the steelership here in Virginia Beach, your best bet is to get them from web stores. As far as Luxury to Sport look at the beginning of this tread.
      01-29-2014, 12:16 PM   #44
AdiSinghV12
India
56
Please let me know the part numbers for all the needed parts.
