08-17-2017, 04:19 PM | #89 |
Rep 36
08-17-2017, 04:21 PM | #90 |
Rep 1,015
08-18-2017, 03:10 AM | #92 |
Rep 864
08-18-2017, 11:09 AM | #93 |
Rep 1,015
08-19-2017, 06:40 AM | #94 |
Rep 1,015
08-19-2017, 07:17 AM | #95 |
Rep 864
I do realise what digital means. I dont think u understand what i am getting at. For all I know the cluster part may be rhd specific. I assume km/h may be a codeing thing but maybe its not.
Thats why ask to accomadate rhd and km/h as the steps will differ just a tad |
LiquidMercury212.50 |
08-19-2017, 09:34 AM | #96 |
Rep 832
08-19-2017, 09:38 AM | #97 | |
Rep 832
Regarding km/h, it's coding. |
08-19-2017, 09:45 AM | #98 | |
Rep 1,015
And just as cars have had the ability to display C or F for decades, its a simple line of code in a digital display. The fact that it 6WB part is not available for order in USA and all units in USA are coming in from EU, noted in several threads, should have also given you the answer. Last edited by GCinFLA; 08-19-2017 at 02:34 PM.. |
08-19-2017, 06:41 PM | #101 | |
Rep 864
As you are such an expert on the matter i would have thought you would have already shown off your finished retrofit. Based on another thread your getting someone else to do it. Guess your not that awsome after all. However on the slight chance you think you are ill be waiting on your detailed diy tutorial on this |
08-19-2017, 07:25 PM | #103 | |
Rep 1,015
However, that does not mean not doing a large amount of research on other 6WBs and private conversations with those who have retrofitted this unit in Europe and Asia. Again, the part is the same, unlike the 6WA and anyone that has been in a car this Century should know different measurements standards can be done with "the flick of a switch". If Bimmertech didn't know how to code this in C/KPH, then no one should allow them code their Car. Period. But of course they do know. So the answer to your question was obvious and essentially answered by pure logic before you posted. |
08-20-2017, 02:44 AM | #105 | |
Rep 864
I dont need to waste my time doing large amounts of research and having private conversation when all i had to do was ask a simple question to the company that is actually planning on doing the retrofit which was accommodate rhd vehicles...whatever that entails. I im not going to make assumptions no matter how logical or obvious u may think it is. If you are going to respond to my question (even though it wasnt to you) at least make it useful like some of the comments you made further down the track. When this is available in the usa i await your detailed step by step diy as you know so much |
08-20-2017, 11:51 AM | #106 | |
Rep 1,015
As item is beginning to become available and BimmerTech does not have stock yet, I k ow which way I am going - and saving money in the process - as I did my homework. |
08-20-2017, 12:18 PM | #107 | |||
Rep 589
Didn't see any attitude that wasn't deserved outside of your initial shitty first reply that set the tone. Not the first time I've seen you act this way and I'm betting it won't be the last. You don't come across as a person that can take criticism and grow, only retort in a pissier and pissier way. Any pickle, happy to call you out so you're now at least aware quite a few here think the same. Keep on being you bud. Seems to be working. Irrelevant to me if you care or take any of this as a learning lesson for yourself. |
smallba73.00 |
08-20-2017, 12:43 PM | #108 | |
Rep 1,015
Correct. I have little respect for those that can find answer via google in 30 seconds vs 3 minutes to type a question in forum and then wait hours or days for response...or better yet, use some common sense. That goes for common sense as well. BMW is not going to create a separate [B]digital[B] dash for EU/USA LH/RH cars as they are all for standardizing parts. One simply needs to look at RHD Automatic Gear Shift to see button on wrong side to know BMW will try to keep parts to the minimum for RHD cars. The forum is a great asset for beyond the basics. But one should use common sense (especially as many post are not correct). In this case, a simple look at realoem and seeing the same part number would have told the tale faster than it took to post in forum. Sorry if that insults you. BTW, noticed no thanks from you when I posted about user @sungwyu who tried to rip you off. http://f30.bimmerpost.com/forums/sho...4#post22084154 Oh well. Last edited by GCinFLA; 08-20-2017 at 12:48 PM.. |
08-20-2017, 05:04 PM | #110 | |
Rep 864
