05-03-2017, 10:11 PM | #67 |
Rep 25
Just a suggestion. Can u try to plug in a 3.5 mm jack into the aux located in your glove box. There is one that comes with this screen. The other end of th3 3.5mm cable can leave it free- bundle up nicely. Do it when car is off. After which turn on to see if it works.
05-04-2017, 09:12 AM | #68 |
Rep 20
05-04-2017, 09:13 AM | #69 |
Rep 20
I contacted Avin and they said that the split screen is the only way to prevent distortion and is the only option I have.
05-04-2017, 12:15 PM | #70 | |
Rep 27
I will try the aux now... Let's hope it works. During my late trip the google maps sound was working ok and I could hear the spotfy músic while maps gives orders, but when the phrase ends the music stops together... My cas has a CIC system and do not allow a blouethoot streaming, do you think it might be something with that ? |
05-04-2017, 12:34 PM | #71 | |
Rep 27
Also tried listening Avin sound with a CD playing but got no response =\ I have to check all cables and installing, maybe one of the optical fibers is loose. I don't really believe in that because car sound and google maps are working fine... how knows. The sceeen is so amazing, I really want that sound goes ok... |
05-04-2017, 12:52 PM | #72 |
Rep 456
I am interested in this route and greatly appreciate you guys pioneering and working on resolving some of the known issues. There is a great deal of potential with this setup and I am looking forward to seeing the end result!
05-05-2017, 04:39 PM | #74 | |
Rep 3,022
Drives: 2019 M2 Competition
Did you have an 6 inch screen before or 8.8? I can understand the scrambled but am confused the that you still have the split screen. |
05-07-2017, 01:42 PM | #75 | |
Rep 27
05-08-2017, 09:32 AM | #77 | |
Rep 20
05-08-2017, 09:33 AM | #78 | ||
Rep 3,022
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
jeffc83725.00 |
05-08-2017, 09:34 AM | #79 |
Rep 20
And still no luck on Android Auto. anyone else have success?
Also I can get phone calls to work, but I still cant get BT audio to stream music from my phone, anyone have luck? Another minor issue i have had is that the time format changes to 24 format regardless of how many times I go in and change the format to 12 hour format. Any ideas? Finally, I have had some issues on the easy share screen popping up randomly. I am just listening to my radio and the easy share screen just pops up and tries to connect (phone is not hard wired or anything). Wondering if I got a faulty unit or if this is par for the course? |
05-08-2017, 09:52 AM | #80 | |
Rep 256
05-08-2017, 08:58 PM | #81 |
Rep 27
05-09-2017, 08:39 AM | #83 |
Rep 25
I did not change any setting on the cabus . isn't the split screen normal.? My buddy owning a f30 with 8.8 inch screen said it looks exactly like stock bmw UI. See attached which is mine. I thought it looks ok to me. I don't encounter any funny pixel or distortion from the onset
05-09-2017, 08:40 AM | #84 |
Rep 25
05-09-2017, 08:45 AM | #85 |
Rep 25
By the way, have anyone of u guys tried the sygic navi? It picks up the coordinate very slowly.
Also it cannot pin point the location of the car accurately. Will jump about randomly. I tried using Google map via the screen with tethering to my phone data. Seems like also cannot pin point the location accurately. I have a feeling its hardware issue. That the gps antenna not strong enough. Where do u guys place the square piece of the end of the antenna. Hidden under dash or place on top of dash? Care to share on your experience with the sygic navi? |
05-09-2017, 10:08 AM | #86 | |
Rep 20
FWIW I was just given an android update file from AVIN in a google drive link. will see if this fixes it. |
05-09-2017, 10:12 AM | #88 | |
Rep 20
Still no luck on streaming audio from my phone. Anyone have luck? Side note, does anyone know how to change the ring tone or ring tone volume when the phone is connected? It is super loud when i get a call regardless of how loud I have my volume on. At this moment defaulting to the factory BT audio and phone. |
