BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > A NEW 10.25" Android 7.1, 2GB / 32GB OPTION! CHECK INSIDE!
proTUNING Freaks
      08-27-2018, 07:10 AM   #507
DRuw
DRuw's Avatar
Netherlands
130
Drives: G21 330e MSport Individual
New interest poll here for a Ugode group-buy
https://f30.bimmerpost.com/forums/sh....php?t=1529645
      08-31-2018, 12:52 AM   #508
zobbified
Drives: F30 318i
I just got mine installed this week but the NAV button on idrive sends me to Google maps. Any idea how to point it back to the stock BMW maps?
      09-02-2018, 01:01 PM   #509
vrslider
vrslider's Avatar
Drives: bmw e91 2011
I bought a gen 2 Avin unit, initially, i had some issues with the original screen not showing up correctly, however, this turned out to be a can bus setting. What i don't like is the speed of the unit starting up, what i also don't get is why its always seemed to default to my old cic screen, the stability of playing music is not good, it stops playing when i scroll through my hdd filled with music.
Any tips are welcome.
      09-04-2018, 08:38 AM   #510
caniswolf
Drives: BMW F30
I just bought Gen2 Version, but i have A big Issue.
The Screen is not conect to my car, It show '' No Signal ''.
I have to try many options in ''Car type'' but it's not work.
And i wonder : My screen is used for F30 ( 3 seri )???? You can see the '' Car Type'' below the picture. I didnt see for F30. (
      09-04-2018, 08:44 AM   #511
DRuw
DRuw's Avatar
Netherlands
130
Which car system originally? Where did you get the Android unit? where did you get the no signal screen (since you have a screenshot showing the android menu, I think you mean no signal from Idrive...?)
Did you connect all the cables? (also the 4 or 6 pin, thats you idrive source).
Really need more details..
Your exact car type doesnt need to be in the screen, just try them all and see if it works (its normally the one with the dicsplay size that your original car had...).
You hould also be able to scroll donw in that menu you have on your screenshot or you have the wrok cartype.xml (or bought the wrong unit for you car...)
      10-01-2018, 07:41 PM   #512
s2kvee
Drives: 2008 BMW E90 M3
is there a way to have the android side auto still playing when using the factory back up camera?
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current
      01-06-2019, 10:21 PM   #513
mikeyb540
Drives: '13 X1 E84
just got mine and installed. love it! anyone know how to change KM to Miles?
      01-31-2019, 06:05 PM   #514
Tullan
Drives: 120i F20
I just picked up a brand new 120i F20.
But I havn't got the AUX used for audio from the android unit - however I have a USB connector instead.
Is there a way around that?
      03-01-2019, 06:35 AM   #515
Werra2006
Drives: X5 E70 2009
Go to settings a change
      03-02-2019, 02:46 AM   #516
Mikesmith2939
Drives: 2013 320i xdrive
Have you used the GPS splitter cable or the GPS arial ?
This is a known issue when using the splitter cable as the Android unit uses a different voltage to the BMW side.
      03-18-2019, 07:30 AM   #517
FrederikD
Drives: BMW F31
Originally Posted by losdamianos View Post
minigp Supernova66
Is 12V black cable not required for the camera ?
Am I right saying only yellow one going straight to the unit is required and you only need CCD+12 to connect with the red cable coming out of end of yellow rca
Everything works, except the rear camera..
Can someone help me? I have everything branched as in the pictures..
'NO SIGNAL'
      03-19-2019, 09:22 AM   #518
jkoljo
Drives: M235i
You need to connect the loom marked with X.
At the back of the car: Red goes to the red of the RCA loom and black to nearest convenient ground.
At the front of the car near HU: Red of the RCA loom goes to red "CCD 12v" of the main HU loom. Then select aftermarket camera from menu. No need to connect separate ground at this end.
Just installed the same system on my car. Has anyone figured out how to adjust the range of the reversing lines? They are too optimistic in my system.
      04-14-2019, 05:25 AM   #519
Werra2006
Drives: X5 E70 2009
Something on my setup has started playing up. When I'm playing the android side of things, the iDrive cuts off and shuts down or reboots. I've had the stereo on the BMW side and everything has worked perfect. Is it my head unit gone or is the idrive no longer able to take aux?
      05-18-2019, 02:53 PM   #520
alpha_male
Drives: F31
I was looking at upgrading my factory ENTRYNAV to the 8.8" screen then came across these units.
been speccing up for one and am wondering about the optional DAB module - do you need this to get DAB? My car has DAB so would the existing DAB connection not work with the android screen ? Not fussed about having it on the android side as my main reason for this is the screen size.
      06-11-2019, 10:57 AM   #521
Flyvron
Drives: BMW 116i 2011
Originally Posted by wacky007 View Post
I installed my unit yesterday. I ordered the CIC version of the android head unit, because my car is from 2012, comes with CIC system with no nav.
During installation I learned that my CIC system from 2012 comes with 6pin (4+2) LVDS connector. I expected it to be 4pin.
Asked Louie, his engineer said the only important judgement is to see LVDS, if it is 6pin, it is NBT.
Important note / lessons learned for all people with CIC interessed in the unit:
  • Check your LVDS connector from display before order!
  • 4pin = order CIC head unit
  • 6pin = order NBT head unit
End of the story is I ordered a new NBT unit.
Hello to everyone! Yeah, I made the same mistake but not without pain!
The Coika Service changed me the unity (I've a F20 from 2012 built in 11), The HU arrived and seems all the functions are working fine, outside the parking sensor (no apk popup) but the worst problem is the iDrive control knob.
When I move the know it moves in the Android System and also n the NBT system, not the opposite.
Coika is not able to fix the problem and I hope you could not find the same problem.
Is somebody able here to do a Rever Engineering of a MCU?
The service said to me that "in China there's no your model of system", so I have to keep it or send it back again (69.- €).
Some good souls that could help me?
Thanks in advance!
