BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > M Performance Power Kit Details
proTUNING Freaks
      03-14-2013, 09:35 PM   #375
Fetko
Drives: 2013 335i sport line
Hope we get some confirmation on the M-Sport requirement soon. I went with the sport line, but would have chosen M-Sport if they had made that requirement clear. I'll be pretty upset if I can't get it on a sport line.
      03-15-2013, 03:43 AM   #376
CasZy NL
CasZy NL's Avatar
Netherlands
17
Drives: M4 | X5 | Z1
2008 BMW X5 35d  [10.00]
2015 BMW M4  [10.00]
1991 BMW Z1  [10.00]
All,
I recently drove the M135i. It is an amazing machine. Clearly it has the same engine and gearbox as the 335i, however the software (together with some modest hardware changes and less weight) makes it far more fun to drive! It sounds awasome, shifts perfect and seems to be quite quicker in the first 100 meters.
My question:
Does anyone know if, after installing the M Performance Power Kit, the car software of the 335i is comparable to the M135i? Will in (sport mode) the character of the 335i be comparable to its smaller brother? Clearly it will have a bit more power, but will the character of the drivetrain (gas response, (lower) gear selection, shifting, etc) change?
Does anyone already have installed the M Performance Power Kit on the 335i?
Many thanks!
      03-15-2013, 06:37 AM   #377
F30form
Drives: '13 Mini Cooper S Hardtop
Originally Posted by Agamemnon View Post
Well at least we know that it exists! From what I could get from the translation is that the performance is real and drivability is good. Its going to be a tough decision whether to go with this or the Dinan tune.
Currently there is no Dinan tune. There IS a PPK, it just hasnt been released yet.
      03-15-2013, 08:29 AM   #378
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Going back to what I mentioned earlier - that friend of mine who put the E9x N55 PPK in his car said that the 20HP gain was underrated - felt more like 40, according to him. Wonder what the pricing will be here in the US?
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      03-15-2013, 09:50 AM   #379
Calasan
Drives: 335i F30; m2 Comp F87N
2020 BMW M2C  [0.00]
2013 BMW 335i  [0.00]
My car has arrived from the factory so I just went down there to order the PPK for it. It will be set up when I get back from a business trip in a week. Kit was around a 1K euro, installation only 80 Euro. Sure am glad I am VAT exempt.
      03-15-2013, 11:27 AM   #380
Agamemnon
Drives: 2016 m3 ss2 zcp full leather
The Dinan tune is being worked on. It should be available by late summer. They have one for the N55 for the last generation which gave an extra 100 ft lbs of torque and about 50 extra HP. I talked to the techs in my local performance centre - they are anxiously awaiting release of both products as the demand from folks like us is huge.
      03-15-2013, 12:21 PM   #381
SwnSng
Drives: 335i MSport - 6MT - GS
LOL underrated horsepower for a Tune...Now i've heard everything! 2k for a tune and some cosmetics under the hood sounds STEEP!
I would pay 500 bucks for 20hp tune...but that's about it.
      03-15-2013, 12:35 PM   #382
F30form
And when the motor blows and its not covered under warranty? Worth that $500? BTW PPK is not going to be anywhere near 2k. Lot closer to 1k.
      03-15-2013, 12:39 PM   #383
Ed335xi m
Drives: 2011bmw x6 5.0
I won't mind going with the PPK. But I rather go with the Dinan stage 2.....more power!! Hopefully it comes out by the summer!!
      03-15-2013, 12:40 PM   #384
Ed335xi m
They both are cover under BMW warranty!!
      03-15-2013, 12:48 PM   #385
F30form
Incorrect. Dinan has its own, matching warranty. BMW does not cover anything that goes wrong with Dinan tunes/parts.
      03-15-2013, 02:31 PM   #386
Ed335xi m
It's cover thru a BMW Dinan dealer!
      03-15-2013, 03:10 PM   #387
brandon @ eas
brandon @ eas's Avatar
Drives: F30 335i
Extra Extra! This just in:
•M-Sport is required to install the PPK
•Only the M Sport gets additional cooling features from the factory (larger radiator fan/relay, auxiliary water/oil coolers). None of the other lines receive these required cooling features.
•The (under rated) HP and torque gains are the same as the Power Kit on the E9x. Bulletin to announce the Power Kit availability will hopefully go out by the end of the month!
With the PPK, Exhaust, M-Performance Suspension and brakes, we are able to create our own unofficial M335i.
      03-15-2013, 03:42 PM   #388
blatantlies
Drives: 2013 335i
Ah too bad. I think they will miss out on a bunch of sales. Thanks for the info though.
      03-15-2013, 04:07 PM   #389
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
As much as I have liked Dinan in the past, I think I may go for this PPK this time around.
      03-15-2013, 04:38 PM   #390
brandon @ eas
Drives: F30 335i
That is definitely true, but in comparison to the potential cost of blown motors due to people over pushing cars that do not have the additional cooling capabilities, the numbers will likely even out
      03-15-2013, 04:41 PM   #391
Agamemnon
I know what you are thinking. The PPK is a pretty safe bet. If it is under rated which is probably likely as BMW seems pretty conservative, it should give enough extra to make us very happy with our ride.
Glad I bought the M-sport. We are also very lucky here in Canada to be able to get the m-sport brakes for a cheap $500. The rotors aren't drilled but they are bigger and the calipers are the same as the M-performance ones.
      03-15-2013, 05:09 PM   #392
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
So are these brakes different than what we get in the US? I don't remember seeing an option for those. Maybe we get them as standard equipment?
      03-15-2013, 05:34 PM   #393
Ed335xi m
I don't think we're getting the m sport brakes here in the US.
      03-15-2013, 06:14 PM   #394
Agamemnon
No, you don't get them in the US. You have to pay the full price for the M-performance brakes. Don't know why BMW didn't let the US market have them. Probably a marketing move - more chance of M-performance brake sales perhaps.
      03-15-2013, 06:30 PM   #395
tdizzle
Drives: 2017 F80 ZCP
Ordered JB4 just now. Would've probably gotten the PPK if it were available for the sportline. Doesn't make much sense to me. The product guy insinuated the msport and sport line both had upgraded oil coolers, so maybe the msport gets some other cooling features (fan/water, etc)
Isn't there alot of msport guys with limp mode issues due to the fans? Maybe that's why it got pushed back so many times from the November initial date?
      03-15-2013, 06:30 PM   #396
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Aha...M PERFORMANCE brakes...not M-Sport. Gotcha. I think I've seen those somewhere like getbmwparts.com, but they weren't listed under options or accessories when ordering. I'll just stay with what I've got, as I don't plan on hot-dogging it too much. At least not for awhile.
