08-24-2023, 01:41 AM | #90 |
Rep 107
Here is the lost of most popular and user friendly programs for disk cloning
SpoolinAddict25.00 |
08-24-2023, 01:44 AM | #91 |
Rep 107
Update on my case.... 🤣 "hdd" rattle comes from scratched cd inside cd tray.🤣🤣 hu was struggling to read cd. I have a car for more than one year and i never put a cd in it. I found some cd stuck inside from previous owner. 🤣
08-26-2023, 07:36 PM | #92 | |
Rep 1,816
Here is a list of top rated software. https://www.softwaretestinghelp.com/...ning-software/ Looks like AOMEI Backupper Standard should get the job done. I've never used this software. I haven't had the need to do this in many years and software I used is now obsolete. |
08-27-2023, 09:43 AM | #94 |
AH3 Owner
206
Rep 312
Drives: BMW 335i ActiveHybrid 3
What did they change with Evo to make it that simple, and why is plain NBT a pain in comparison? Did they not lock the drives?
08-27-2023, 06:01 PM | #95 |
Rep 540
Drives are still locked with Evo, but Evo is easier going with the SMART temperature variable which makes it a lot less picky with replacement drives.
Unlocking the drive isn't too difficult to do once you've figured the process out but it's still a bit of a pain in the ass. |
08-28-2023, 11:26 PM | #96 |
Rep 114
Anyone know if this process will keep aftermarket carplay working? I have a 2016 F80, I had mine coded with carplay after the fact.
2013 F30 335i - Totaled 2016 F80 M3 - PS2+ | MHD | Wedge Performance | |
08-29-2023, 05:19 PM | #97 | |
Rep 111
09-11-2023, 08:09 PM | #99 |
Rep 1,980
Drives: 2020 G20 320i M Sport
PM'd
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
09-19-2023, 02:43 PM | #100 |
Rep 11
hello,
I tried to replace my hard drive in the NBT EVO ID5 but impossible. I bought 2 Kingston 240GB SSD hard drives. I can't train them anymore. They are restricted... Do you have the solution for the unrestrained ones? Thanks |
09-23-2023, 05:30 AM | #101 |
Rep 3
09-24-2023, 05:35 AM | #103 |
Rep 11
hello to all PROs
I need help to re-inject all the code into my NBT EVO ID5. I made a big mistake when I wanted to replace my hard drive using ssh via Putty. Instead of deleting the disk partitions, I probably deleted the memory of my NBT EVO. pffff I'm disgusted. It doesn't restart anymore, black screen and it seems like it restarts all the time... I'm looking for someone who can re-inject the coding onto my NBT EVO via eSYS SOS - who can help me please |
09-30-2023, 06:28 PM | #104 |
Rep 114
do I have to use QNX? i cant seem to get a burnable disc from it. it's already bricked 2 hdds when I try using vmware.
01-13-2024, 08:04 AM | #106 |
Rep 4
HDD Ata Password Remove / Удаление ATA пароля на жёсткий диск
HDD Ata Password Remove "Jailbreak" / Удаление ATA пароля на жёсткий диск
Hope this video will help you to unlock ATA password on the HDD you've got from your NBT or other Thing and get old data from it if you need it! Supported HDDs - Toshiba, Samsung, WD and some other. The video is in russian lang, but it does not matter - there are a lot of pictures ) PS: Have a nice day! |
01-19-2024, 09:54 PM | #108 |
Rep 41
Drives: BMW X3
Need help
So my NBT system has been randomly rebooting, figured it was the hard drive and attempted to replace it with one of the Toshiba 500G disks others have been using. Booted up QNX on an old PC and ran create_hdd -i. As near as I can tell everything was created fine. Put the disk back in the NBT and let it boot up. It seemed to boot up fine, bluetooth appears to be working, but navigation was stuck at loading. So I figured I'd load the map via USB, plugged it in and nothing happened. Tried a media USB, nothing happened. Pulled the hard disk out again and looked at it in QNX. It's not locked, but the partition table is trashed and fdisk in QNX can't fix it. So it looks like this disk is toast. Before I go ruin another disk trying again, any ideas on what I'm doing wrong?
01-20-2024, 01:11 PM | #109 |
Rep 540
That is odd - your partitions before putting it in the car look correct, exactly like the drives I've prepared so I don't think there's anything wrong with the process there.
What NBT unit do you have? Have you tried the drive in Windows to see if that can see anything or delete the partitions? Maybe open up a Command Prompt and run Diskpart. Use 'list disk' to see what drive number it is, then 'select disk x' to choose the drive number and try a 'clean' to get rid of all partitions. |
01-20-2024, 01:57 PM | #110 |
Rep 41
Drives: BMW X3
Hi Zheez, the drive is not readable under windows anymore, I get device not ready errors. I even tried using a few USB booted disk recovery programs and none of them can access the drive anymore. The only thing that still accesses it is QNX, but it freezes if I try to delete the partitions.
nbt harddrive |
