BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Reverse camera OEM style retrofit for $199 shipped - DIY Details
      09-23-2019, 08:58 AM   #45
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
Guide lines not centered
Got it installed and been trying to work with the manufacturer on centering the guide lines on the screen. Originally had it on the driver side, tried to adjust them but apparently it's either driver or passenger side. It won't let me center them. Seller in China so there a minor language barrier and a major delay due to time zone differences.
What I did:
-put car into reverse
-held iDrive controller knob down
-when lines started blinking pushed knob right, twisting simply moves the grid closer or further away from the bumper.
F32
NBT
8.8"
Any insight is appreciated.
      09-23-2019, 10:01 AM   #46
muniz_ri
Drives: BMW 320I
What I did:
F32
NBT
8.8"
Whoa. Let us know how that works out. I was considering buying one this week.
      09-23-2019, 03:42 PM   #47
330istocknot
Drives: 330chino
What I did:
F32
NBT
8.8"
When you ordered it, did you select that you had an 8.8 inch screen or 6.5 that seems e made for 6.5
I got a 6.5 inch screen and it works great. I haven an 8.8 inch screen on the way here that i will be installing soon, ill let you know if this problem happens, if so, that means you might have ordered the 6.5 inch version not version.
      09-23-2019, 03:57 PM   #48
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
What I did:
F32
NBT
8.8"
Yes. I selected the appropriate screen size. There's also a number of dim switches on the side you can select. It's set for the 8.8" but their support has been asking me to try a bunch of different settings. Nothing has corrected it so far.
      09-23-2019, 04:06 PM   #49
330istocknot
Drives: 330chino
I was not aware of the option to move th elines closer to the bumper, i assume if there is an option for that, there should also be an option to align the lines.
I tried a bunch of combinations to see if i could move the lines but nothing so far. I will continue to do more research and see if i find something ill let you know as soon as possible.
      09-23-2019, 04:56 PM   #50
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
Put the car in reverse. Hold down the iDrive knob. When the lines start blinking, turn the knob. This will pull the lines in closer and push them further away from the car. When done, hit back.
      09-23-2019, 05:21 PM   #51
330istocknot
Drives: 330chino
Yeah i did that and works, but there has to be a way to be able to align them to the left or right.
      09-23-2019, 06:24 PM   #52
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
I figured it out. Steps below. Video attached.
-Put the car in reverse
-hold down iDrive knob
-turn knob to move the lines closer/further away from car
-push and hold knob left to right to move lines from one side to the other
Hope that helps.
jbb238847.50
aps335.50
      09-23-2019, 06:50 PM   #53
330istocknot
Drives: 330chino
Hope that helps.
Perfect, will add this to the main post in case anyone else encounters this problem.
Thanks for diagnosing it! Now enjoy the camera! It works great!
      09-23-2019, 10:52 PM   #54
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
What I did:
F32
NBT
8.8"
It worked out. I was able to adjust the guide lines by pushing and holding the iDrive knob down. Everything is looking good now!
jbb238847.50
aps335.50
      09-23-2019, 11:35 PM   #55
muniz_ri
Drives: BMW 320I
Nice to see that! This camera kit is a great deal.
      09-24-2019, 01:16 AM   #56
DarkF30
DarkF30's Avatar
54
Drives: F30 328i
What I did:
F32
NBT
8.8"
Were you able to center the lines?
jbb238847.50
vcxz-z0.00
      09-24-2019, 08:47 AM   #57
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
Yes. The guide lines can be moved pretty easily.
jbb238847.50
aps335.50
DarkF3054.00
      09-24-2019, 10:13 AM   #58
jbb2388
Drives: 2016 F30 340iX
Guys, thanks very much for posting the details about tweaking the guidelines. Had no idea this was even possible or necessary with an install. I've already installed an 8.8" display a couple months back. Will be pulling the trigger on this camera purchase now.
      09-24-2019, 10:46 AM   #59
sthor10
sthor10's Avatar
Drives: BMW F30 328
Agree with above, been wanting this for a long time and the comments in this post convinced me to pull the trigger. Hope it arrives in time for the weekend to install and hope they were correct on which unit to purchase.
      09-24-2019, 11:02 AM   #60
aps
aps's Avatar
336
Drives: 2018 M3 ZCP
Awesome! I'm going to tear apart my screen asap to figure out which pin I need and will order.
      09-24-2019, 11:26 AM   #61
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
Super glad what I'm posting is helpful. Would appreciate clicking "appreciate" as I'm somewhat new to posting on this forum!
On a side note, I've been emailing with their support on widening the guidelines to fit my 8.8" screen. They've got their developers looking to see if they can update the firmware to make them wider. If they can, I'm told they'll send me the file to load on an SD card to insert into the side of the hardware. Picture below. I'll update if/when this happens.
One more thing to note, once installed you can push the iDrive knob down once to populate the camera option. There you'll be able to adjust brightness and contrast, turn the guide lines off and on, and turn off and on your parking sensors if you have that option. Let me now if you have questions!
Appreciate 6
muniz_ri447.50
aps335.50
DarkF3054.00
jbb238847.50
      09-24-2019, 02:19 PM   #62
330istocknot
Drives: 330chino
Perfect. update US please. I am waiting for an 8.8 inch screen to get here tomorrow, however i have the 6.5 unit model, so we will see how it looks.
Illl update if it auto stretches or its out of place.
      09-25-2019, 09:02 AM   #63
jbb2388
Already have multiple times.
Hey, how is the nighttime performance and clarity of the image?
      09-25-2019, 10:50 AM   #64
330istocknot
Drives: 330chino
I made a video for night, check out original post, clear even with the stock reverse bulbs, however im upgrading to LED reverse lights soon.
      09-25-2019, 02:23 PM   #65
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
The low light performance is consistent with my bro's OEM Acura camera. I'm pretty happy with it. It's not 1080p but has enough detail to see debris like branches or parking lot trash. I've got stock reverse bulbs in.
This picture was taken just before dawn, still dark out.
      09-25-2019, 02:32 PM   #66
dubsixjmac
Drives: 2013 BMW 328i
For those who have installed this kit, is there an ignition power and negative line coming off of the camera that needs to be connected? Are you able to slice the ignition into something like the reverse light or is it a different voltage that would require a relay?
