01-01-2013, 08:52 AM | #1629 |
Rep 40,642
It seems to have been added in 48.x, but not for the F10. Is there an actual "M Performance" option on the F30 that this eye candy goes along with?
01-01-2013, 08:52 AM | #1630 | |
Rep 40,642
Anyone have a picture of this connection?
01-01-2013, 08:55 AM | #1631 |
Rep 490
01-01-2013, 08:56 AM | #1632 |
Rep 40,642
Ok. That makes sense then. With a M135i, it is probably set to mpm by default.
01-01-2013, 08:57 AM | #1633 | |
Rep 1,544
No, there doesn't seem to be one for US. |
01-01-2013, 09:00 AM | #1634 |
Rep 490
anybody knows the code to disable the seat belt chime?
I did fdl coding using the cheat sheet, but it still continue to chime... 3000 Ausstattungsflags SeatBeltReminder_SBR_Fahrer Found another cheatsheet, but couldn't find the option in ACSM 3000: 3000 SBR_FA_GWF_SBR_FA 3000 SBR_BF_GWF_SBR_BF What did I do wrongly? |
01-01-2013, 09:04 AM | #1635 |
Rep 490
so by removing country controller, it becomes "USA" enabled?
01-01-2013, 09:09 AM | #1636 | |
Rep 40,642
For F30 you should code both of these: SeatBeltReminder_SBR_Fahrer (Driver) SeatBeltReminder_SBR_Beifahrer (Passenger) Double check that both are set to nicht_aktiv. This won't disable the short initial Gong on starup though, just the persistent one.
01-01-2013, 09:13 AM | #1638 |
Rep 40,642
In your FA (VO) along with all your other option codes, listed under SALAPA-Element.
01-01-2013, 09:14 AM | #1639 |
Rep 52
01-01-2013, 09:18 AM | #1640 | |
Rep 40,642
http://www.f30post.com/forums/showpo...postcount=1624 Click the link in my thread, and you will understand SALAPA-Element.
01-01-2013, 09:24 AM | #1641 | |
Rep 40,642
S8L1A S8LBA S8LFA S8LHA = Hong Kong S8LMA S8LRA = Russia S8LSA S8LTA If anyone has any of the unidentified ones, please advise what code you have and what country you are in. Thanks!
01-01-2013, 09:24 AM | #1642 | |
Rep 490
01-01-2013, 09:27 AM | #1643 | |
Rep 40,642
So did you get it working, or in this case not working as desired? If that didn't work, you can try it the BMW way using K-Words in your FA.
01-01-2013, 09:40 AM | #1644 | |
Rep 40,642
01-01-2013, 09:42 AM | #1645 |
Rep 490
I code it for my frens, I refuse to code the chime on my ride as I want to make sure everyone buckle up I'll ask him to monitor though. I think the chime we heard could be as you described, the initial one and not the persistent one.
01-01-2013, 09:48 AM | #1646 | |
Rep 52
just to doublecheck: Salapa Elements are my Loaded Extra in the car? right? Does this mean I can add as "example" the extended BT: I add to the below textfield (with the numbers the big one) : 6NL ??? and then all values are set for this, which I have done manually? |
01-01-2013, 09:49 AM | #1647 | |
Rep 40,642
Initialwarnung_GWF_IW In your case then, since you like the Gongs, you can enable the passenger one.
01-01-2013, 10:02 AM | #1648 |
Rep 52
Hi works on F30; Thanks to Illhan :-)
Seatbelt alarm driver ACSM 3000 SBR_FA_GWF_SBR_FA Seatbelt alarm passenger ACSM 3000 SBR_BF_GWF_SBR_BF Display seatbelt driver ACSM 3000 Gurtzustandsanzeige_Fahrer_GWF_GZA_FA Display seatbelt passenger ACSM 3000 Gurtzustandsanzeige_Beifahrer_GWF_GZA_BF set to: nicht aktiv |
01-01-2013, 10:06 AM | #1649 | |
Rep 490
01-01-2013, 10:07 AM | #1650 | |
Rep 40,642
1) Your SALAPA-Element's are your vehicle's unique option codes (e.g. 205 Automatic Transmission, 609 Navigation Professional, 2VL Sport Steering, etc,) 2) You cant add or code anything "on" that requires hardware you physically do not have, whether through FA (VO) Coding or FDL Coding. 3) You can accomplish everything via FDL Coding if you know what you are doing, although it can be more tedious when there are many changes required. But for instances where you don't fully know all the required FDL Codes to enable a feature, or for ease, if you have the required hardware, you can alter your VO Option Codes, and then VO Code a module(s), which will code the entire module, all at once, making all the FDL changes for you to support every Option Code in your VO. So for example, removing 6NH from your VO and replacing it with 6NK won't automatically get you Enhanced Bluetooth functionality unless you physically also have a Combox.
