01-30-2018, 03:20 PM | #23 | |
Rep 327
When you code make sure you delete 6NH and add 6NK (or 6NL) in alphabetical order. Then VO code HU_CIC. You will have to recode any options you had previously coded since it will code to stock.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
MHL13.00 |
02-04-2018, 04:55 AM | #25 |
Rep 134
Managed to code enhanced Bluetooth but speech button no longer works.
Also set HU_NBT > HMI 3000 > SYSTEM_TTS to ‘aktiv’, and CE_DEVICE_SPEECH_RECOGNITION 'aktiv' |
02-04-2018, 06:07 AM | #26 |
Rep 67
02-04-2018, 01:17 PM | #36 | |||
Rep 919
Drives: F30 328d Sport Line
02-05-2018, 05:32 AM | #38 |
Rep 134
Might be worth trying this http://www.bimmerfest.com/forums/sho.../topics/762419
02-09-2018, 08:52 AM | #41 |
Rep 319
Hi - just starting to look at coding for my 335dx 65 plate. I am going round in circles trying to find information on how to go about this. I would prefer to use bimmercode, all I want to do is enable EBT and turn radio off when opening the door. Some posts say you can't code EBT via bimmercode, some say you can, some say use VO coding, others FDL, totally confused! Is there anyone who can help a little as to do the above? Many thanks.
02-11-2018, 10:13 AM | #42 | |
Rep 107
Bestia64.50 |
02-11-2018, 05:03 PM | #43 | |
Rep 319
Sorry for all the questions but have to start somewhere I guess! Thanks. |
02-13-2018, 12:40 PM | #44 | |
Rep 107
You can't use Bimmercode for VO coding which would be easy to change just one code instead of the multiple lines to adjust when going the FDL route. The plus side is that the interface is easier to use. |
