Studio RSR
      07-23-2013, 08:20 PM   #4093
kon
Singapore
Drives: F30 310i > G20 310i
Originally Posted by PandaNL View Post
Hello,
I'm trying to find the location of the combobox in a F30 (production date. 2012-05-02 european model)
On the right side of the trunk is the battery located, on the left side I don't really see a cover to look behind it.
The F30 i'm working on has 6NH and 609, my goal is to change it to 6NK if this is possible. I found how i can change the FA, but what else needs to be done after this?
Also does this allow BMW Online/BMW Apps via iphone to work
Can anyone point me in the riht direction.
The Combox physical location, if you have one it's in the centre of the boot, pretty much behind the rear seat. You need to flip up the entire board to see it.
NBT, i had the impression that combox is built into the headunit, i.e. behind the CD slot.
But for 2012/05 production date, should be Combox
      07-23-2013, 08:24 PM   #4094
kon
Singapore
Google Local Search > Online Search
While waiting for my significant half today, I started to play with BMW Live again, and immediately notice Google Local Search was replaced with Online Search.
It seems to throw back result similar to Googlemaps, i.e. not restricted to company name that Google Local Search was used for (basically an online phone directory with addresses). I noticed in the past certain keyword will not get any result (while normal googlemap would provide some suggestion).
HOWEVER, the functionality to transfer the result back to onboard navigation seems to have disappear. Didn't do enough search, but all i see when I select the result is "phone number" (where available), the only other option available were "send to email", which was my configured/registered email.
Is it just me, or everyone having the same problem.
I'm glad the search engine has "upgraded", it is giving more accurate/comprehensive search result compared to past, but at the same time making it useless because we cannot transfer it to navigation
      07-24-2013, 05:17 PM   #4095
poejokiller
Drives: F31 Modern
The goodies
Hi Shawn,
Couls you please PM me the goodies? I just finished soldering the cable, and can't wait to start coding!
Thanks
      07-24-2013, 07:27 PM   #4096
nyczyar
Drives: F30 335i
Hey Shawn,
May I also get the E-sys, PSdZData, and token files? I finally made my cable. Thanks in advance.
      07-24-2013, 08:23 PM   #4097
klaysta
Drives: 2018 BMW M3 ZCP
Originally Posted by nyczyar View Post
Hey Shawn,
Can I put in for it as well?
      07-24-2013, 09:42 PM   #4098
shawnsheridan
shawnsheridan's Avatar
Hey Shawn,
PM's sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-24-2013, 09:43 PM   #4099
shawnsheridan
Originally Posted by poejokiller View Post
Hi Shawn,
Thanks
With this being your first and only post, you need to wait 24 hours to receive PM's, or post your email address.
      07-24-2013, 10:36 PM   #4100
kon
Singapore
No one else have problem?
      07-25-2013, 02:32 AM   #4101
Stichel
Stichel's Avatar
Belgium
Drives: 2013 BMW F31 330D M-Sport
Originally Posted by Stichel View Post
Yes! My ODB-cable arrived yesterday. The only thing I still need is the e-sys software to use. Got a version of e-sys but it seems like I need some other data. Anyone who can PM me about that? I'm riding a 2013 F31 330d.
Thanks!
Hi Shawn, Can you help me further with this? Many thanks in advance!
      07-25-2013, 06:18 AM   #4102
shawnsheridan
Hi Shawn,
Thanks
PM's sent.
      07-25-2013, 11:00 AM   #4103
RSC27
Drives: 320D M Sport
Help
I cant get my laptop to establish connection with the car. Windows 7 64 bit
I turned the antivirus off, I get the connected with an error symbol on the network connection but nothing after that.
Any help would be appreciated.
Thanks
      07-25-2013, 11:02 AM   #4104
shawnsheridan
Thanks
And the car is turned on?
Where did you get your ENET Cable?
      07-25-2013, 11:09 AM   #4105
RSC27
Car turned on but engine not running.
Cable off ebay from a seller recommended by other BMW guys in the UK.
How long should it take for a connection to establish?
      07-25-2013, 11:34 AM   #4106
shawnsheridan
I would turn the Engine on, just to make sure car has adequate power.
It should connect in about 2 minutes time.
You can't rely on ZGW_Search though. If you get the Yellow Exclamation on your LAN Adapter, then try and connect to car with E-Sys, and then Read FA and SVT, and see if it works.
      07-25-2013, 12:47 PM   #4107
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
2014 BMW 335 Xi  [10.00]
can you code bluetooth on f30 if i dont have enhanced bluetooth to stream music wirelessly?
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      07-25-2013, 12:49 PM   #4108
shawnsheridan
The car should at least have 6NH Basic Bluetooth.
In order to have Bluetooth Streaming (Bluetooth A2DP Profile), you must have Enhanced Bluetooth option on car. In order to have Enhanced Bluetooth Option on car, you must have a Combox.
      07-25-2013, 12:52 PM   #4109
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
Originally Posted by shawnsheridan View Post
The care should at least have 6NH Basic Bluetooth.
ok understood! thanks!
      07-25-2013, 02:31 PM   #4110
RSC27
Thumbs up Sorted
You can't reply on ZGW_Search though. If you get the Yellow Exclamation on your LAN Adapter, then try and connect to car with E-Sys, and then Read FA and SVT, and see if it works.
Got connected not sure what sorted it, I messed with a LAN setting, still showing exclamation mark on network connection but ZGW Search showed the active connection.
Time for a breather, order patch and token then lets see what I can do.
Thanks for the help
      07-26-2013, 05:37 AM   #4111
PandaNL
Netherlands
22
Drives: F30 330e & E92 335i
If you have either CMB_MEDIA or HU_NBT in your SVT, then you have Combox.
And if you do, change FA to 6NK, and VO Code either CMB_MEDIA or HU_NBT.
This will allow BT Audio Streaming (A2DP), but it has nothing to do with BMW Online / BMW Apps.
I do have Combobox_Media I guess this is the same?
So after changing FA to 6NH to 6NK all what is left is change A2DP to Aktiv, or do i need to activate more functions?
      07-26-2013, 06:18 AM   #4112
shawnsheridan
Yes.
You don't need to FDL Code Anything. Just VO Code Combox and Head unit.
      07-26-2013, 06:21 AM   #4113
PandaNL
Netherlands
22
Sorry for being a noob, but what does VO code mean?
Do you mean code the Combobox_Media CAFD and the HU_CIC?
      07-26-2013, 06:25 AM   #4114
Jazz239
Jazz239's Avatar
Russian Federation
Drives: BMW X3 35i '10, M sport
Hello Shawn!
Could you please send me the hints about how to get actual versions of E-sys, PSdZData and token files?
Thnksbfhnds
