      06-05-2013, 11:09 AM   #3763
ad78
Yr1OfD1
ad78's Avatar
Drives: 2015 F34 M Sport
Originally Posted by john08135i View Post
Zero worked but what do I set to auto unfold upon unlock?
Also for the idrive mlogo where is that located
try this combo:
Closing side mirror with Fob set as aktiv
Fembody 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN
Opening side mirror with Fob set as aktiv
Fembody 3110 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN
2015 328i Gran Turismo M Sport
2013 328i XDrive Sedan M Sport
2011 X5 xDrive50i
2009 X5 xDrive 30i
2008 135i Coupe
      06-05-2013, 11:18 AM   #3764
shawnsheridan
shawnsheridan's Avatar
Originally Posted by 4.8 E70 View Post
You mean instrument cluster and HUD ?
Kombi / 3000/ BMW_Logo -- Change ag to mpm
No, I believe he means iDrive CIC.
For this you need NBT Head Unit, which unfortunately your 2013 U.S. F30 does not have unless you retrofitted it, and the FDL Code is:
HU_NBT = > STARTUP_EMBLEM = variant_xx
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      06-05-2013, 11:41 AM   #3765
Frogman
Drives: 2012 F30 328i
Originally Posted by ad78 View Post
try this combo:
Plus you have to change FEM_BODY / 3053 / KOMFORTSCHLIESSEN_FB to aktiv in order for the mirrors to fold/unfold via the fob. CA fold/unfold is enabled by default.
      06-05-2013, 12:34 PM   #3766
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
Originally Posted by shawnsheridan View Post
I was laying low, as frankly I don't know the answer.
I think though this is a function of the Welcome Lights. In F10, I would look at WL_FUNKTION_POL and see what my options are, and other "WL" settings.
Inherently, what you are asking represents a conflict. By putting the switch in Position 4, you are disabling DRL, yet wanting DRL's as welcome lights, so this may be a lost cause.
There you are! I'll check it out, but wait I'm confused on why that represents a conflict, in my car even if i'm on switch position four the DRL's (which are the corona rings) remain on the whole time the car is on? on your F10 Position 4 = no lights on at all?
I'll investigate the WL_FUNKTION_POL lead....
      06-05-2013, 04:24 PM   #3767
kromix
kromix's Avatar
No Luck, closest I got was WL_AKTIVIERUNG
Translation of comments:
Comment = Welcome Light:
0 - disabled
1 - activation with light switch in position A (Auto)
2 - activation with light switch in position A (Auto) OR 2
Its already set to 2, not sure what Position 2 is, but its not the one I want lol, maybe I can't change it.
      06-05-2013, 06:33 PM   #3768
shawnsheridan
No, I just misread the note below the image you posted that Position 4 was both Head Light and DRL Off, but it is only Head Light Off. I just checked mine, and they are the same way. Apparently the Welcome Lights by design only work in Automatic mode, which seems strange to me.
      06-05-2013, 08:20 PM   #3769
kon
Singapore
Drives: F30 310i > G20 310i
Becoz there are folks that doesn't like seeing their headlights switch on/off all the time...
Without coding, some people feel the pain of headlights staying on despite what seems to be bright environment, and the welcome lights only stay on for a brief period, so traditional thinking on and off, can't be a good thing, so there better be a switch that I can turn that off
      06-05-2013, 08:37 PM   #3770
kromix
kromix's Avatar
Yea that's wierd, didnt see any options to change that either... Oh well.
      06-05-2013, 09:07 PM   #3771
shawnsheridan
It's the Angel Eyes, not the headlights, that we are talking about, and you can turn the Welcome lights on and off from the iDrive Menu, so it makes no sense that the welcome lights are disabled when the switch is in position 4. They should work the same as position 3, and if you don't like them, just can uncheck the iDrive box turn them off.
      06-05-2013, 09:40 PM   #3772
kon
Singapore
I'm just giving a real world example, I'm not complaining... and yes, angel or headlight, the on/off is a concern for some folks
and trust me, a lot of owners never explore their menu, and don't really know what seems to be very basic stuff
      06-05-2013, 09:49 PM   #3773
PauL K.
Drives: F30 328
Hello,
My f30 has i-step 12-11-504. I have coded it with 3.18.4 and psdzdata 48.1.
After FA coding I decided to update ECU after i did that procedure Connect => Read FA => Activate FA => Read VCM => Left-Click on KOMBI => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on INHK (the ECU itself not the underlying CAFD) => Select CODE I think I have coded ECU with 12-11-502. If I use 3.128.4 and psdzdata 48.3 can I upgrade Kombi ECU back to 12-11-504?
Thank for advance.
      06-05-2013, 10:10 PM   #3774
shawnsheridan
Originally Posted by PauL K. View Post
Hello,
Thank for advance.
What are you doing? If the ECU already had CAFD, why did did you do "Detect CAF for SWE"?
If it is working now, leave it alone. Changing the CAFD won't make any difference.
      06-06-2013, 12:43 AM   #3775
PauL K.
Drives: F30 328
This story started earlier. I decided to unlock video in motion, make memory for start stop function and to enable current speed at dashboard display. All of that I have done through fdl. Everything was fine but, before coding my trunk was opening together with the doors and it was very convinient for me but after I have coded all options I want trunk started to open without doors opening. To fix that and to make start stop coded through FA I have added to HO-Wort OMSA for start stop and OENE for trunk opening with doors. After that I decided to make operation I have described in my previous post for FEM and Kombi. I wasn't able to read fem because e-sys showed me message with error, during kombi reading there was no any problems with reading and I coded it with 12-11-502. After that kombi and it cafds became not blue as other ECUs but black. And at the top of ecus tree in brackets it written 18 colored black and after coma 1colored red. I think first figure is numher of all ecus and second is kombi ecu with another version. Sorry for such long text.
      06-06-2013, 03:00 PM   #3776
PauL K.
Drives: F30 328
Guys could you please send me torrent file with psdzdata 48.2!!! Thank you very much!!!
      06-06-2013, 09:07 PM   #3777
shawnsheridan
PM sent.
      06-06-2013, 09:55 PM   #3778
top6491
MSGT USMC (Ret)
Drives: 2012 AW F10 535i M-Sport
2012 BMW 535i  [0.00]
Operating systems that can be used
I bought a laptop for coding that has Win8. Can we code with Win8 or do I need to have a separate HD with Win XP or 7?
Mark
      06-06-2013, 09:59 PM   #3779
shawnsheridan
Mark
Win 8 is fine, including 64 Bit.
      06-07-2013, 01:33 PM   #3780
hrosenberg33
hrosenberg33's Avatar
630
Drives: 2023 M3 Competition X-drive
Sorry for the derail but could anyone direct me to a similar thread for coding for the E84? Good friend just picked one up and wants to know if he can get Bluetooth A2DP (only has bluetooth phone). Checked the E84 forum but did not find one. Thanks!!
      06-08-2013, 04:49 PM   #3781
Rizight1
Drives: 2013 328i xDrive
Hi shawnsheridan, would you please email me the link? I'm at F020-12-11-502. Thank you! rizight1@gmail.com
      06-08-2013, 05:32 PM   #3782
shawnsheridan
You should not request a specific I-Level, as it doesn't mean much by itself.
Case in point. F020-12-11-502 is both ISTA/P 2.48.0 and ISTA/P 2.48.1. If you got 48.0, and the car has 48.1, then you may very well not have what you need.
Ideally, you always want the latest PSdZData anyway, but this became complicated by the transition to E-Sys 3.22.5 and some people's reluctance to update if it was not needed, due to the cost of doing so.
In your case, I presume you are using E-Sys 3.18.4, which for F20 / F30 Chassis, the latest you can use without updating is 48.2.
E-Mail sent.
      06-08-2013, 05:43 PM   #3783
Rizight1
Understood. I realized according to the charts it could be 48.0 or 48.1 but I was hoping you'd link me to 48.1 or 48.2 assuming I'd want to milk E-Sys 3.18.4 as long as I can and you did. Thank you again!
      06-09-2013, 04:55 AM   #3784
H60Doctor
///M-Flight
Drives: 2013 F10 M5 Monte Carlo Blue
If you are having trouble locating the 511 ohm .6 watt resister I can help. I found them at Mouser Electronics which is an online electronic store used by car companies. The Mouser P/N is 594-mrs25000c5110frp. I have had no problems with them shipping to an APO address either. I hope this helps.
