      01-13-2013, 08:39 AM   #1981
williammm
Drives: BMW F80 M3 (2016)
Wanna check, is there a way to make sure that the volume of the audio is always to the volume of the last trip before shut down?
Shawn: Could give me the link to d/l the files? The files that i had are from my friends and they are a bit out dated.
      01-13-2013, 09:20 AM   #1982
estragos
TUGA
estragos's Avatar
84
Drives: F30 320d M Sport
Originally Posted by shawnsheridan View Post
You can use INPA and Tool32 (reset error codes) with ENET, but for full diagnosis, you really need ISTA/D and an ICOM interface.
Thanks a lot!!
I will try to find INPA software...
      01-13-2013, 09:24 AM   #1983
shawnsheridan
shawnsheridan's Avatar
You can't receive PM's. Put up an email.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      01-13-2013, 09:25 AM   #1984
shawnsheridan
Originally Posted by estragos View Post
Thanks a lot!!
It is part of BMW Standard Tools (EDIBIAS, INPA, Tool32, and NCS Expert).
      01-13-2013, 09:56 AM   #1985
williammm
beckz_7@hotmail.com
TIA
      01-13-2013, 09:58 AM   #1986
shawnsheridan
Email sent.
      01-13-2013, 08:46 PM   #1987
howiegu
Member
howiegu's Avatar
Drives: 22%E2%80%99 M440
Originally Posted by avgor123
Originally Posted by howiegu View Post
All the experts:
Will enable this setting enabling a brighter "angel eye" ring when headlight is on?
Maybe you will try this:
Fem_body>3062
MAPPING_STANDL_V_L_PWM_LEVEL_1
MAPPING_STANDL_V_R_PWM_LEVEL_1
set to 100% instead of 8%
Did you mean to change the "werte" to 64 from 08 (in hex term it's 100)?
Have you done that to increase the brightness if the rings?
Thanks.
      01-13-2013, 10:09 PM   #1988
mrtanz
Australia
24
Drives: BMW 2008 325i upgrade
From reading this am i correct in saying that you still need E-SYS for coding and can not use NCS EXPERT for F30
      01-13-2013, 11:39 PM   #1989
shawnsheridan
That is 100% correct.
      01-14-2013, 12:21 AM   #1990
ykau
Drives: F30 320I
hi guys, currently my current playing video screen is small, is there any code to enlarge the screen size for video to be exactly the same like the menu size? thanks
      01-14-2013, 12:26 AM   #1991
ykau
Drives: F30 320I
Thanks.
from the FM_body, i see 8%,10% 12%.. each has a hex value. So do I change the werte value at 64 for 8% only?
      01-14-2013, 12:57 AM   #1992
ykau
Drives: F30 320I
hi shawnsheridan, i recalled coming across a post from you saying can telnet into the CIC and view whatever files are inside. How do you telnet and what root account and password to use? does it has FTP as will? thanks
      01-14-2013, 01:09 AM   #1993
shawnsheridan
Believe it or not, it was done very early on, before E-Sys was "available" to the public, as a means to enable Video In Motion.
Back then the password was cracked, and you could Telnet in and and use the QNX Software Developmental Kit to access the files. As I recall, FTP would not work. Somewhere around a year ago, BMW changed the password scheme, and since then it has not been cracked, and with E-Sys readily "available" now, no one bothers anymore to try and get into it.
If you want to know more, I can send you a link where this was discussed. Just PM me.
      01-14-2013, 01:39 AM   #1994
ykau
Drives: F30 320I
Hi Shawn, thanks for sharing!!. I did a brief search on QNX on how it works. Apparently , its can open a terminal session with the remote system and compile codes using C++ . if the password is cracked, does it mean we even add instead of modifying existing functions? i will send you a PM.
      01-14-2013, 01:51 AM   #1995
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
I think you can set "Werte" to any value from 00 to 64 HEX for that parameter without editing of "mnemonic value" (%, voltave)
      01-14-2013, 03:51 AM   #1996
kon
Singapore
20
Drives: F30 310i > G20 310i
wow! yours can play video? from what source? without 6NR, I can only play DVD, when playing DVD, I recall it does expand to used the whole 8.8" so no little screen problem with DVD.
pray tell how to play video (other than DVD)
      01-14-2013, 04:58 AM   #1997
shawnsheridan
If he has the new HU_NBT, it can play Video via the USB Port.
      01-14-2013, 05:35 AM   #1998
ykau
Drives: F30 320I
Hi Shawn, the manufactured date for my ride is april 2012, if it has a HU_NBT, how to make it play with video via usb? I've tried, but in vein.
      01-14-2013, 05:36 AM   #1999
ykau
Drives: F30 320I
hey, you and me come from the same , dun have to tease me lah, you know is a typo
      01-14-2013, 05:53 AM   #2000
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
Hu_nbt is from November 2012 and newer if I'm not mistaken.
      01-14-2013, 05:59 AM   #2001
Spikey
Australia
63
Drives: erratically
Here's proof that it can be done on F30... but like what Shawn say, if your vehicle original PSZData is old, you might not see the option to make the change at all, for such vehicle, you shouldn't even see the original BMW logo
Damn, I've changed my KOMBI / BMW_LOGO = mpm but it still stays as original BMW logo
Also, I'm having issues with my ipod hey... using the y-cable supplied from dealer, it charges the ipod but won't play it via i-drive just as a normal input via AUX. I can play usb sticks via the usb input but it refuses to load my ipod via the i-drive interface. Is there anything I can check coding wise to see if I can figure out if something isn't coded right?
I have 6nh, in the e-sys program I've got HU CHAMP2.
On a positive note, I've got the sports dispay (power/torque) on my business nav now thanks to the coding explain in this thread
      01-14-2013, 06:01 AM   #2002
shawnsheridan
Again, you must have NBT, and thanks to user cronek, it looks like it is:
Enable USB Video Support:
HU_NBT > 3003 > API_USB_VIDEO > both
HU_NBT > 3000 > ENT_CODEC_XVID > aktiv
HU_NBT > 3000 > ENT_CODEC_VCD > aktiv
HU_NBT > 3000 > ENT_MC_VIDEO_SUPPORT > aktiv
Enable Wifi:
HU_NBT > 3003 > WLAN_STATUS > aktiv
HU_NBT > 3003 > WLAN_MODUS > ap
HU_NBT > 3003 > WLAN_SIGNAL_STRENGTH > “incar” for low power, “outdoor” for high power
HU_NBT > 3000 > ENT_MC_WLAN_STREAM_DMP_COVERART > aktiv
HU_NBT > 3000 > ENT_MC_WLAN_STREAM_DMP_VIDEO > aktiv
HU_NBT > 3000 > ENT_MC_WLAN_STREAM_DMP > aktiv
It looks like Internet over Bluetooth is codeable too.
