04-15-2021, 09:33 AM | #1 |
Rep 35
Can't Code HU_NBT for 3AG
Hi guys,
i'm working on retrofitting a BMW rear camera on my f30 equipped with PDC 507 and Pro GPS 609 . Using oem kit 66 21 2 361 833 and a used module 6653 9282420 02 I connected wires following doc EBA 361831. In ESYS I can't code HU_NBT with VO containing 3AG. By the past I already did VO code NBT adding 6NK without problem. If I add 3AG to activated VO I get an error when coding NBT... below extract of the log (partially masked VIN ) Of course I have only a black screen and on ISTA error saying "no FBAS connection". Any help appreciated Code:
***** Link: HU_NBT_63_ETHERNET, Service: WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value) Request Parameter count: 3 - WDBI: 0x2e - WDBI_PLAIN_DID: 0x3001 - WDBI_PLAIN_DREC: (151) ff c3 18 4c 29 ff ff ff ff 67 ff ff ff 01 1e 3c 04 01 0a 00 99 66 b3 4c 80 7f 80 7f 80 7f 80 7f 80 7f 80 7f 99 66 b3 4c cc 33 80 7f b5 4b e7 19 dd 23 d8 28 06 06 00 28 02 02 00 ff ff 11 04 ff c1 f8 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff Request PDU: (154) 2e 30 01 ff c3 18 4c 29 ff ff ff ff 67 ff ff ff 01 1e 3c 04 01 0a 00 99 66 b3 4c 80 7f 80 7f 80 7f 80 7f 80 7f 80 7f 99 66 b3 4c cc 33 80 7f b5 4b e7 19 dd 23 d8 28 06 06 00 28 02 02 00 ff ff 11 04 ff c1 f8 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff Response count: 1 Response 0: Response Parameter count: 3 - RESPONSEID: 0x7f - RSID: (1) 2e - RC: conditionsNotCorrect Response PDU: (3) 7f 2e 22 DiagAdresses: 0xf4 -> 0x63 [ParallelTask-6] 18-03-15 18:53:39,257 [DEEP_TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding: ''''''''''''Final Diagnostic Block in Case of Failure started: [ParallelTask-6] 18-03-15 18:53:39,258 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding: MCD service RDBI_ADS started [ParallelTask-6] 18-03-15 18:53:39,258 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.prodias.io.tcp.HsfzTcpCommunicationLink: will send data for host 169.254.74.61 on port 6801, SA= 0xF4, TA= 0x63, link data= 0x00 0x00 0x00 0x05 0x00 0x01 0xF4 0x63 0x22 0xF1 0x86 [ParallelTask-6] 18-03-15 18:53:39,259 [INFO] [] com.bmw.prodias.io.tcp.HsfzTcpCommunicationLink: got data from host 169.254.74.61 on port 6801, SA= 0xF4, TA= 0x63, control= 2, link data= 0x00 0x00 0x00 0x05 0x00 0x02 0xF4 0x63 0x22 0xF1 0x86 [xNbcPool-1-thread-1] 18-03-15 18:53:39,295 [INFO] [] com.bmw.prodias.io.tcp.HsfzTcpCommunicationLink: got data from host 169.254.74.61 on port 6801, SA= 0x63, TA= 0xF4, control= 1, link data= 0x00 0x00 0x00 0x07 0x00 0x01 0x63 0xF4 0x62 0xF1 0x86 0x41 0x02 [xNbcPool-1-thread-1] 18-03-15 18:53:39,296 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding: MCD service RDBI_ADS finished ***** Link: HU_NBT_63_ETHERNET, Service: RDBI_ADS - ReadDataByIdentifier ActiveDiagnosticSession Request Parameter count: 2 - RDBI: 0x22 - RDBI_DID: activeDiagnosticSession Request PDU: (3) 22 f1 86 Response count: 1 Response 0: Response Parameter count: 4 - RDBIPR: 0x62 - RDBI_DID: (2) f1 86 - RDBI_DID_ADS_ADS_MSB: codingSession - RDBI_ADS_SI: sessionStateUnlocked Response PDU: (5) 62 f1 86 41 02 DiagAdresses: 0xf4 -> 0x63 [ParallelTask-6] 18-03-15 18:53:39,296 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding: RDBI_ADS_SI does exist in RDBI_ADS, we found L6/L7 ECU: false [ParallelTask-6] 18-03-15 18:53:39,296 [DEEP_TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding: ''''''''''''Final Diagnostic Block in Case of Failure finished! [ParallelTask-6] 18-03-15 18:53:39,297 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding: sjob PERFORM_ECU_CODING/MCD3_PerformECUCoding finished Result: [Response 0: [ERROR_CODE: service returned global negative response], [ERROR_DESC: Service WDBI_PLAIN returned a negative response with response code conditionsNotCorrect; LinkName: HU_NBT_63_ETHERNET], [ERROR_SEVERITY: ERROR]] [ParallelTask-6] 18-03-15 18:53:39,297 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.prodias.collections.mcd.AbstractNamedCollection: provided name TP_CONTROL doesn't map to an item [ParallelTask-6] 18-03-15 18:53:39,297 [DEBUG] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper: Could not read TP_CONTROL successfully cause Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name TP_CONTROL doesn't map to an item' [ParallelTask-6] 18-03-15 18:53:39,297 [DEBUG] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper: Could not get TP_CONTROL from MCDResponse, the reading of TP_CONTROL will be ignored. [ParallelTask-6] 18-03-15 18:53:39,298 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.api.impl.bf.EventManagerBF: API: getCurrentEventID() started [ParallelTask-6] 18-03-15 18:53:39,298 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.api.impl.bf.EventManagerBF: API: getCurrentEventID() finished [ParallelTask-6] 18-03-15 18:53:39,300 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.uc.event.EventManagerImpl: PSdZEvent: MCDDiagService<id=62634, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : conditionsNotCorrect, link=HU_NBT_63_ETHERNET> [ParallelTask-6] 18-03-15 18:53:39,302 [DEBUG] [] com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread: mQueue.take()after:0 [com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread] 18-03-15 18:53:39,302 [DEEP_TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper: update ECU statistics from job: DA: 0x63 State: 2 [ParallelTask-6] 18-03-15 18:53:39,302 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper: removing Job: ECUId:HU_NBT_0x63com.bmw.prodias.execution.primitives.mcd.SingleEcuJob[state=25089, primitiveSN=PERFORM_ECU_CODING, logicalLinkSN=HU_NBT_63_ETHERNET] [ParallelTask-6] 18-03-15 18:53:39,302 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper: removed Job: ECUId:HU_NBT_0x63com.bmw.prodias.execution.primitives.mcd.SingleEcuJob[state=25089, primitiveSN=PERFORM_ECU_CODING, logicalLinkSN=HU_NBT_63_ETHERNET] [ParallelTask-6] 18-03-15 18:53:39,302 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper: analyseJobResult started [ParallelTask-6] 18-03-15 18:53:39,303 [WARN] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.api.exceptions.PSdZMCDErrorException: unable to parse error code from D-Server, setting variables to default, parsed string was: 'Service WDBI_PLAIN returned a negative response with response code conditionsNotCorrect; LinkName: HU_NBT_63_ETHERNET' [ParallelTask-6] 18-03-15 18:53:39,304 [WARN] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.vehicle.connection.util.ResultUtil: ---Job Failure: negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code conditionsNotCorrect; LinkName: HU_NBT_63_ETHERNET severity: ERROR [ParallelTask-6] 18-03-15 18:53:39,304 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper: analyseJobResult finished [ParallelTask-6] 18-03-15 18:53:39,304 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.programmer.facade.AbstractProgrammer: performECUCoding finished [ParallelTask-6] 18-03-15 18:53:39,304 [DEBUG] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.programmer.facade.AbstractProgrammer: executeCDDeploy: performECUCoding finished (result: TAResult [mException=job failed with negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code conditionsNotCorrect; LinkName: HU_NBT_63_ETHERNET severity: ERROR , mTAReturnCode=cancel]) for HU_NBT, SWE=cafd_00000ded-001_020_106 [ParallelTask-6] 18-03-15 18:53:39,304 [DEBUG] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.programmer.facade.AbstractProgrammer: executeCDDeploy finished (result: TAResult [mException=job failed with negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code conditionsNotCorrect; LinkName: HU_NBT_63_ETHERNET severity: ERROR , mTAReturnCode=cancel]) for HU_NBT [ParallelTask-6] 18-03-15 18:53:39,305 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.tasks.base.TaskStep: TaskStep CDDeployTaskStep finished with failed [ParallelTask-6] 18-03-15 18:53:39,307 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.api.impl.bf.EventManagerBF: API: getCurrentEventID() started [ParallelTask-6] 18-03-15 18:53:39,307 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.api.impl.bf.EventManagerBF: API: getCurrentEventID() finished [ParallelTask-6] 18-03-15 18:53:39,307 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.uc.event.EventManagerImpl: PSdZEvent: TA finished [ParallelTask-6] 18-03-15 18:53:39,307 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.tasks.base.SingleEcuTask: TALLineTask.executeTA finished with failed [ParallelTask-6] 18-03-15 18:53:39,304 [DEBUG] [] com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread: mQueue.take()before:0 [com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread] 18-03-15 18:53:39,308 [DEBUG] [] com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread: mQueue.take()after:0 [com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread] 18-03-15 18:53:39,309 [DEBUG] [] com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread: mQueue.take()before:0 [com.bmw.psdz.uc.event.ExternalSynchronizedHandler$AsynchronousNotificationThread] 18-03-15 18:53:39,309 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.tasks.base.Task: add error cause in task com.bmw.psdz.talexecutor.tasks.CodingTask: ecu:HU_NBT - da:0x63: job failed with negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code conditionsNotCorrect; LinkName: HU_NBT_63_ETHERNET severity: ERROR Timestamp: Thu Mar 15 18:53:39 CET 2018 ErrorCategory: VEHICLE_ERROR ID: 433 Class: com.bmw.psdz.vehicle.connection.util.ResultUtil ExecutionContext={category=TAL, ecuid=(HU_NBT,0x63), TA_CATEGORY=cdDeploy, PROGRAMMING_STATUS=performECUCoding,PSdZEvent={message=MCDDiagService<id=62634, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : conditionsNotCorrect, link=HU_NBT_63_ETHERNET>, timestamp=Thu Mar 15 18:53:39 CET 2018, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, ECUId:HU_NBT_0x63}} [ParallelTask-6] 18-03-15 18:53:39,309 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.api.impl.bf.EventManagerBF: API: getCurrentEventID() started [ParallelTask-6] 18-03-15 18:53:39,310 [INFO] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.api.impl.bf.EventManagerBF: API: getCurrentEventID() finished [ParallelTask-6] 18-03-15 18:53:39,310 [TRACE] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.uc.event.EventManagerImpl: PSdZEvent: There was an error during TAL execution, please check the log files. [ParallelTask-6] 18-03-15 18:53:39,310 [WARN] [CodingTask - vin:**********J475649 - ecu:HU_NBT - da:0x63] com.bmw.psdz.uc.event.EventManagerImpl: There was an error during TAL execution, please check the log files. [ParallelTask-6] job failed with negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code conditionsNotCorrect; LinkName: HU_NBT_63_ETHERNET severity: ERROR Last edited by Shadar; 04-15-2021 at 09:35 AM.. Reason: adding infos |
04-15-2021, 11:08 AM | #2 |
Rep 536
Post picture of esys to see how it looks like(I mean on HU NBT) Do you have cafd inside?
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
04-15-2021, 12:57 PM | #4 |
Rep 536
Ok and check again fbas cable. Do you have NBT oder CIC? Where you put 3 cable
Red - Pin #18, Shield - Pin #27, and White - Pin #28 CIC OR Red - Pin #21, Shield - Pin #23, and White - Pin #24 NBT
04-15-2021, 01:25 PM | #5 | |
Rep 35
(off topic impressive your retrofit list ) Last edited by Shadar; 04-15-2021 at 01:41 PM.. |
04-15-2021, 02:02 PM | #6 |
Rep 536
That is ok you have NBT just check again if pin is inside like it should
If you are now in car I can look quickly for you over teamviewer just write me pm with ID and PASS
04-17-2021, 03:20 PM | #7 |
Rep 35
Hi,
sorry for the delay, didn't have a lot of time thanks for your teamviewer proposal, I need to install it on the garage laptop asap below if it can helps, a screenshot I did today ? |
04-17-2021, 04:27 PM | #8 | |
Rep 2,302
So, please check again your VO. It is best to load the original and unchanged VO. Or you could try to remove the 6NK. I also read of problems when the 698 is in the VO. |
04-17-2021, 10:04 PM | #10 |
Rep 1,982
Drives: 2020 G20 320i M Sport
I had the same issue once and the NBT needed to be flashed so that it could support 3AG.
Given that it's on BTLD1 and likely from an early 2012 vehicle, it wouldn't be a bad idea to try flashing it.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
04-18-2021, 06:31 AM | #11 | |||
Rep 35
I already tried to remove 698, think I read it here, but no more success Quote:
Thanks for the help you all |
04-18-2021, 10:58 AM | #12 | |
Rep 536
05-07-2021, 08:45 AM | #14 |
Rep 35
Hi,
unfortunately not... I tried with newer esys 3.34.0 (no launcher) + psdzdatafull.4.28.12 no more success Thanks to full psdzdata I have updated the HU_NBT to F020-21-03-520 but still can't code HU_NBT with 3AG, if I remove 3AG it works, I add only 3AG error... edit : I tried with 3AG but without 698 same result error Code:
description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_NBT_63_ETHERNET severity: ERROR [WARN]> <[HU_NBT - 63] - [Exception - HU_NBT - 63] job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_NBT_63_ETHERNET severity: ERROR > <[HU_NBT - 63] prepareECUforCoding started [PROGRESS]> <MCDDiagService<id=230634, job=com.bmw.psdz.jobs.uds.MCD3_PrepareECUforCoding, service=DSC - DiagnosticSessionControl, description=error: negative response : conditionsNotCorrect, link=HU_NBT_63_ETHERNET> [DIAGSERVICE]> <[HU_NBT - 63] prepareECUforCoding finished [PROGRESS]> <[HU_NBT - 63] authenticateECUforCoding started [PROGRESS]> <MCDDiagService<id=16727, job=com.bmw.psdz.jobs.uds.MCD3_AuthenticateECUforCoding, service=SA_SK - SecurityAccessSendKey, description=error: negative response : serviceNotSupportedInActiveSession, link=HU_NBT_63_ETHERNET> [DIAGSERVICE]> <[] job failed with negative response error: code: service returned global negative response description: Service SA_SK returned a negative response with response code serviceNotSupportedInActiveSession; LinkName: HU_NBT_63_ETHERNET severity: ERROR Last edited by Shadar; 05-07-2021 at 11:05 AM.. |
05-07-2021, 11:21 AM | #15 | |
Rep 2,302
And if nothing works you can of course code the rear view camera by FDL Coding. REM_01 > PdcParkMasterVar 3203 > RVC = wert_02 HU_NBT > EXBOX 3001 > CAMERA_SYSTEM = trsvc HU_NBT > EXBOX 3001 > MACRO_RV_C = aktiv HU_NBT > EXBOX 3001 > TRSVC = wert_81 |
Shadar6.50 |
05-07-2021, 11:43 AM | #16 | |
Rep 35
good idea but no success same error with 6NH & 3AG (was 6NH in the original VO) will try FDL Coding now that NBT has been updated |
05-08-2021, 03:16 AM | #17 |
Rep 35
So I tried to FDL code only camera related lines (without coding ECU of HU_NBT with 3AG) and it still doesn't work : default camera and black screen displayed instead of camera view
any help appreciated |
05-08-2021, 03:28 AM | #18 | |
Rep 2,302
But did you also VO code the TRSVC (module 6653 9282420)? Since you haven't written anything about it, I thought there was no problem with that. Last edited by atzebmw; 05-08-2021 at 03:38 AM.. |
05-08-2021, 12:51 PM | #20 |
Rep 536
This ecu is not compatible with your car. I check now there is 4 ecu for your car:
66539302256 66539350995 66539393953 66536994555
Shadar6.50 |
05-09-2021, 08:12 AM | #22 |
Rep 2,302
If the TRSVC wouldn't be compatible, you couldn't have coded it either.
The TRSVC are all the same from 1 -7 series. And that would not have caused any problems when coding the HU_NBT. https://www.realoem.com/bmw/null/partxref?q=66536994555 https://f30.bimmerpost.com/forums/sh...1&postcount=11 I think you should also code the FEM with the 3AG because there is a new connection.. My retrofit for the Rear view camera it's been a while, so I can't remember exactly which modules I had to code. |
Shadar6.50 |
3ag, coding 3 series, esys, rear view camera |
