02-07-2014, 08:50 PM | #24 |
Rep 7
+1 for pics.
Just buy a tow rope (should be 10-12 bucks) and pull it out very slowly. do not jerk the rope or you could damage both cars. and keep the tow rope in your car. its the best thing to have in an emergency. |
02-08-2014, 01:17 AM | #26 | |
Rep 444
Hope the door mats weren't damaged!! Last edited by Feanor; 02-08-2014 at 02:19 AM.. |
02-08-2014, 05:28 PM | #27 |
Rep 476
Don't go for the kitty litter. You'll make a mess in your yard. Either buy a rope and pull the car out or get ready to pour many buckets of hot water to melt the snow under the car tracks.
+1 for pics. |
02-08-2014, 09:04 PM | #28 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
Get somebody really fat to sit in the boot. Or the "trunk" as you guys would call it
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
02-08-2014, 10:29 PM | #29 |
***** noob
1354
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
no way man, my lawn is way more valuable than my bimmer
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
02-08-2014, 11:15 PM | #30 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
Call AAA. It's really that simple. For the $50 a year, at most, they will help you in these situations.
02-09-2014, 02:17 AM | #32 |
Rep 329
Drives: BMW 520D Touring 2012
Never heard of anyone removing the snow in the tires and I dont think that will help.
Biggest fault is using summer tires in the winter. Its a huge difference when temperature drops. Is the car lifted up by snow under it? If that is the case you need to remove that so the rear wheels have contact again with the ground. You might use the jack to put sand under the rear wheels. |
02-09-2014, 02:14 PM | #36 | |
Too much is never enough
655
Rep 3,079
Again, if it's surrounded by snow and has already dug itself in, nothing will work without some external forces to get it started. The tires can't grab something that you shove against them unless it's very grippy. |
02-10-2014, 10:33 AM | #37 |
Rep 61
If for what ever reason you can't use road side assistance to winch you out of there. And you have completely removed any snow infront of it, I would have pulled it out. I've done this to mine several times.
Once the cars are hooked up, first try with the BMW in neutral and the Rav4 in Drive at idle. See if it can just pull you out like it was pulling a trailer. If not apply some gas until the car comes out. Don't use hard violent tugs, your typical strap from Home Depot is not meant for recovery but for towing, it won't stretch and all the forces get transfered to the cars and tow hooks. If that doesn't work, try the same thing but give some gas in the car too. Only give what is neccessary. On the Rav4 too, don't go faster that the car, you don't want to overrun any gears in car by pulling it faster than it is spinning. Make sure someone is in the car too, so they can apply the brakes and steer as needed. If the car is on flat ground, the Rav4 tows something like 3500# so you should be good. |
02-10-2014, 12:32 PM | #38 |
Rep 34
Thanks for all the advice and encouragement.
Tried the gravel method, but the holes in the lawn were so deep that i could not get the gravel beneath the tires. The minute I let out the clutch, the gravel was sent flying. So back to Home depot, purchased a 3200 lbs rated steel cable, and two 2600 lbs rated hooks. Pulled the car out with the RAV4. It has snowed again last night, so cannot take pics of the holes created by the tires. The cable and hooks have permanently found a place in the trunk for situations like these.... hope I never have to do it again. Once again all your help is very much appreciated. |
02-10-2014, 12:41 PM | #39 | |
Rep 34
I used the door mats from the porch, not the ones that came with the car and they will have to be trashed... pretty sorry state with mud caked in. |
02-10-2014, 12:57 PM | #40 | |
Rep 179
02-10-2014, 01:55 PM | #41 | |
Rep 61
none the less, never give real hard yanks on that cable and hooks. And if you ever find yourself away from home needing this kind of help, and you happen to find someone with a truck to help you.... make sure they understand this....no violent yanks. I know my 4Runner pulls my 6000# trailer on idle. Imagine the force a cowboy with a heavy gas foot in a cummins dodge will generate on the steel wire rope. They should be able to gently pull you out, barely any gas. |
02-11-2014, 08:12 AM | #43 | |
Rep 34
Put it into reverse and 4x4 lock and eased up on the gas.... Did not take much to pull the car out. Had my wife sit in the bimmer to apply the brake.... This should have been my first option... but you live and learn... |
02-11-2014, 10:06 AM | #44 | |
Rep 444
