BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > F15 10.2" Monitor installed to F30 car
      01-18-2016, 08:30 PM   #67
MSportTune2
Aland Islands
80
Drives: F30 MSport
My installer tried a few times on CIC using my friend's car. So far it does not seem to work and require nbt.
      01-20-2016, 11:26 PM   #68
cedchung
Mauritius
64
Drives: 2011 F25, 2014 F30
Is coding required when swapping from 8.8 to 10.25?
      01-22-2016, 05:31 AM   #69
MSportTune2
Aland Islands
80
Drives: F30 MSport
Coding comments are on page3 but I did not code and it is working fine.
      01-22-2016, 07:18 AM   #70
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
Originally Posted by Alex@Alpine View Post
I managed to get the screen in without touching the dash. A lot of crazy work, you'll need to carefully remove the plastic casing, then take the screen and lens apart, have a glass cutter trim the glass a little. Shave edges on the metal, and shave some plastic front & rear.
How does the plastic casing detach?
What holds the screen/lens together??
      02-02-2016, 04:10 PM   #71
omorzo
Always on track!
omorzo's Avatar
Italy
Drives: 328i
Anyone think to do a DIY guide?
      02-09-2016, 10:17 AM   #72
Alex@Alpine
Drives: E90 M3
You just unclip it, small clips all around on the inside, you have to be very careful. The glass is glued to the LCD.
      02-09-2016, 10:55 AM   #73
steelerfan
steelerfan's Avatar
163
Drives: 2017 X5 Silver
Hey Alex,
Why did you have to trim the glass? i think that is the most intimidating piece of this puzzle. Would the glass has stuck out beyond the outer casing your trimmed? When i was test fitting mine, it was really close to being a direct fit meaning i could almost push the screen down just enough where i could have bolted it back in place (after i trimmed off the 2 middle back pieces)
      02-09-2016, 11:01 AM   #74
Alex@Alpine
Drives: E90 M3
Originally Posted by steelerfan View Post
Hey Alex,
I did not go straight to glass cutting, that was costly part. If you have the unit in hand you can measure the glass on the bottom and see it is wider then the opening on the vehicle. You can push the unit down with force, but even the smallest pressure will break the plastic holders the two screws go into after about a week or so. You can cut a small piece of the dash out with a razor blade, save it and glue it back in if you decide to go back to stock. I doubt anyone will ever notice.
      02-09-2016, 11:52 AM   #75
david51
david51's Avatar
France
538
Drives: bmw M3 F80
No need to cut glass
      02-09-2016, 08:45 PM   #76
steelerfan
steelerfan's Avatar
163
Please explain what you did?
      02-10-2016, 08:03 AM   #77
jojo7
Drives: F320i
Subbed
      02-10-2016, 01:43 PM   #78
Alex@Alpine
Drives: E90 M3
That is what I thought also, the second you cut the back to fit it in, then push down, the clips will break from the pressure of pushing it down after a week. You also have a leather dash that soft, much easier to push down on.
      02-10-2016, 03:04 PM   #79
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Yes Alex@Alpine
Here is a photo editing
      02-10-2016, 03:23 PM   #80
steelerfan
steelerfan's Avatar
163
Yes Alex@Alpine
Thanks for posting.. the 1st three photos make perfect sense... But starting with photo # 4... you lost me just a bit...
What is the purpose that white piece of paper.. were you making a new fiberglass mold or something? I notice the texture completely changes in your final photos... can you explain that?
Could you have not just done the 1st 3 steps stopped there?
      02-10-2016, 03:38 PM   #81
david51
david51's Avatar
France
538
Drives: bmw M3 F80
I made a mold with a plastic material and I put a sticky woman to cover all
      02-12-2016, 11:57 AM   #82
kenhoteh
kenhoteh's Avatar
Macau
70
Drives: F30 M-Sport 320i
Sorry. may I know your F30 is which line? why your instrument custom light are white color?:
KenHo Macao S.A.R.
      02-12-2016, 11:59 AM   #83
kenhoteh
kenhoteh's Avatar
Macau
70
Also with the blue light
KenHo Macao S.A.R.
      02-25-2016, 12:25 PM   #84
Alex@Alpine
Drives: E90 M3
Yes Alex@Alpine
Very nice!
      02-25-2016, 12:40 PM   #85
david51
david51's Avatar
France
538
Drives: bmw M3 F80
I myself even change the LED meter in white and all other LEDs in white and blue
      02-25-2016, 11:29 PM   #86
MSportTune2
Aland Islands
80
Drives: F30 MSport
It's very clever how you wrapped the rear screen to mask all the cuts to the rear plastic cover. Can you share in more detail what material was used and how you attached it?
Your leather dashboard is beautiful.
      02-26-2016, 05:47 AM   #87
rezadue
Two turbos are better than one!
rezadue's Avatar
Drives: 2017 BMW M4 ZCP
I would love to see a DIY for the LED change including the dash and the leather dash!!!! Looks great.
Sapphire Black M4 Competition
      02-26-2016, 06:34 AM   #88
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thank you
After cutting and stuck the white plastic part has the right distance
must unclip the back of the screen cover and wrap the woman tights over
