04-19-2016, 12:33 PM | #1 |
Rep 7
Change to HID Headlights
How expensive did everything cost for you to make the transition? What are the best websites to gather the parts at the best prices?
Post up people |
04-19-2016, 02:30 PM | #3 |
Rep 1,071
Have you considered replacing all four of the car’s 55 watt, 1,400 lumen OEM H7 bulbs with 65 watt, 2,100 lumen Osram H7 bulbs? They’re 50% brighter than OEM and they make a huge difference at night. Buying four bulbs is also a lot cheaper than converting to Xenons or LEDs. It's definitely worth considering.
04-19-2016, 03:49 PM | #4 | |
Rep 7
04-19-2016, 04:21 PM | #5 |
Rep 1,071
They have the "look and appeal" of halogen bulbs that sufficiently illuminate the road in front of your car at night (unlike the OEM halogen bulbs).
04-19-2016, 04:31 PM | #6 | |
Rep 995
04-19-2016, 04:43 PM | #7 |
Rep 364
HID kits themselves are relatively cheap. IIRC you want to be looking around the £80 mark for a good quality kit from a reputable supplier. You can get them cheaper but they will often come with cheaper ballasts etc which in the long run don't last as well and with some cars play havoc with the canbus. (Not sure if this is an issue with BMW)
If your keeping your standard halogen headlight units make sure you but H7r bulbs which cut down the glare a bit for oncoming cars. The expense comes when you start changing the headlight for a projector style unit. I had a HID kit in my old car before buying OEM projectors, the difference in beam pattern and visibility at night is unbelievable. The light output as you can imagine was still the same but the projectors focused the light much better into places where it was needed. |
04-19-2016, 04:44 PM | #8 | |
Rep 7
04-19-2016, 04:47 PM | #9 | |
Rep 261
04-19-2016, 04:50 PM | #10 | |
Rep 364
I've not fitted one to a BMW, however I would of though it would be the same. Most HID kits come as a complete kit and will include 2x bulbs, 2x ballasts and the required wiring to fit it your existing wiring loom. They don't always include bulb holders which you will need. Other than that you really only need the tools to strip the front of the car and some tie wraps to secure the ballasts in place in the engine bay. |
04-19-2016, 08:56 PM | #11 |
Rep 700
Working on this right now, after its ask said and done, I'll be about $2,000USD total in parts, that's only because I'm having a hard time tracking down a used set of Driver modules.
04-20-2016, 06:11 AM | #12 | |
Rep 46
I'm not going to tell you not to fit them because that's your decision but read up first - and I don't know where in the engine bay you should mount your ballasts but make sure they will have plenty airflow if possible. |
