05-01-2012, 11:06 AM | #3 |
Rep 4
05-01-2012, 11:19 PM | #6 | |
Rep 40
http://www.tirerack.com/wheels/tech/...jsp?techid=101 The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).* Zero Offset The hub mounting surface is even with the centerline of the wheel. Positive The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars. Negative The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset. If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle. |
09-11-2013, 04:12 PM | #10 |
Rep 1,436
07-01-2014, 12:10 AM | #12 |
Rep 5,140
07-01-2014, 03:12 AM | #14 | |
Rep 5,140
If you look for new wheels isn't it better to find a direct fit for F30? |
07-01-2014, 04:16 AM | #15 |
Rep 1,436
07-01-2014, 06:21 AM | #16 | |||
Rep 5,140
If you buy new aftermarket wheels you can look for wheels with aggressive offsets directly instead of buying wheels that need spacers to result in a wide stance on F30. An example of a staggered setup for F30 without need of spacers: F: 8.5x18" ET35 R: 9.5x18" ET40 1/2" wheel width corresponds to 6mm in offset, which means that a 8" ET29 wheel will look similar to a 8.5" ET35. |
07-01-2014, 06:42 AM | #17 | |
Rep 1,436
the most important thing that I can get 245 & 255 so for instance if i have 9.5 won't it be too much for 255 wide as the rims will be out ? & i don't want that, I want aggressive look while protecting the wheels from road as well |
07-01-2014, 07:17 AM | #18 | |
Rep 931
for your point of view is correctly fitted this setup ? : F: 8.5x19" ET35 R: 9.5x19" ET35 http://www.ebay.it/itm/111368685264?...84.m1436.l2649
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
07-01-2014, 07:29 AM | #19 | |
Rep 5,140
Lower offset results in wider stance. If you like 245 front and 255 rear tires the most narrow wheels you can choose are 8" front and 8.5" rear. With those wheel and tire widths you can search for wheels with front offset around 30 and rear around 35. F: 8x18" ET30, 245/40-19 (1% shorter than OEM) R: 8.5x18" ET35, 255/40-19 (OEM F30 tire size) If you find wheels you like with higher offset you may fit them with use of spacers. |
07-01-2014, 07:34 AM | #20 | |
Rep 5,140
Here is a member with very similar setup: f30.bimmerpost.com |
07-01-2014, 07:41 AM | #21 | |
Rep 931
I try to find a rear 9JX19 ET 35
07-01-2014, 10:23 AM | #22 | |
Rep 1,436
