12-06-2013, 11:24 PM | #1 |
Rep 1,397
[90% complete] [USB AND STEREO BT WORKING!] DIY HU_NBT Retrofit
UPDATE! we got armrest USB and A2DP wroking. Will update this thread soon, still trying to put evrything back in one piece
Don't think there has been a full documented DIY for HU_NBT yet so im posting one here. This is a project Aritaurus and I are working on, it is still a WIP, some functions are not working. I didn't get pictures for parts of the process but feel free to PM me to clarify some details if needed, I'll try to write down everything I remember. We have install this NBT unit into 2 cars, one with CIC and one with ENTRY HU's so I'll do it write up for both. Phase One. Physical Step One Take off your dash trim (pictures are from my old AMP+sub install DIY) Start from the right side of the trip to the left. pry from under the silver trim and when you get enough out you will be able to pull out the entire piece. Once you get the piece out, unplug the door lock and vent control buttons. just tug on them and they will come out. Step Two Pry off the trim piece under the HVAC controls. just use your fingers and gently pull down from under the HVAC controls. takes little to no strength at all to get this piece out. Step Three There are Four (4) Torx 20 screws holding the control unit in place, one in each corner. Unscrew it and unplug the connector on the back. (this takes a lot of force the first time pulling it out. felt like i was about to break mine) Step Four There are 2 Torx 20 screws holding the head unit in. one on each side, unscrew and pull the head unit out. There are numerous connections on the back unplug them. 1) big block of wires there's a latch. unlatch and pull. This one is the shortest so unhooking it first lets you pull the unit out more so you have more room to work with. 2) disconnect the HSD connectors, one for the screen (pink/purple) and one for USB (white/beige). Pretty straight forward there's a latch, push it with your thumb and pull. Pink/Purple : Screen connector white : armrest USB/AUX (HU_Entry only) beige : glove box USB (HU_CIC only) 3) The rest of the cables...complete PITA... They have a white tab on them. Pull the white tab away form the connection and use your thumb to press the white tab against the actual cable and pull the connector out. Black : FM radio antenna (AM antenna as well for HU_CIC) White : AM radio antenna (HU_Entry only) Pink : Aerial GPS receiver probably for Sirius Satelite radio Blue : GPS receiver The back of HU_Entry is not marked which color goes where so mark it yourself somewhere. Step Five Remove the Fakra connection heads (plastic pieces) for Blue, Black, Pink, White. Take a set of vice grips and clamp down on the head and pliers holding the metal cable at the back and pull straight up and the plastic piece will pop off (watch the surrounding area so you don't hit anything. i smacked my mirror pretty hard with the vice grip. Reason for doing so, look at the following picture: Blue (left) is the connector that goes into HU_NBT. Black (right) is the connector in your car. They don't match and will not fit into the slot for HU_NBT. Middle is how the connector will look after you remove the plastic piece. I guess a way around this is to buy an adapter cable. I'm not sure if they make that type of cable but I assume they do somewhere. Step Six Remove the Screen. ontop of the vents in the center dashboard there are 2 Torx 20 screws, unscrew them. Be careful doing this because it can easily fall into the vents and my assumption is you're very screwed if it damages the lower in there. After these two screws are out you just pull the screen straight up and it will come out. Step Seven On the back of the NBT the fakra connections. trim them off or else it will not make full contact with the port. Do it for Black , White , Pink , Blue You only need to do it for blue if you're coming from CIC. If you're coming from Entry then you can buy a fakra GPS receiver from ebay. that will save you time and effort form dragging a wire form the rood down to the HU. These connectors: Note: if you buy adapters you can skip thus step Step Eight Plug everything back in. make sure you have the canbus filter or else navigation will not work. can filter looks like this: http://bimmerretrofit.com/store/imag...wm-500x500.jpg Note: tape the fakra connections down to the head unit to ensure it does not pop off while driving. cause they are a bit loose and there's no way to secure it unless you buy and adapter. Step Nine Put everything back together and you will have a somewhat functioning head unit. GPS, Radio, music library (if the previous car came with some stored) will work, all the menus/functions and sound will work. Enjoy! Note: We are still trying to figure out how to get USB/AUX and Bluetooth to work. stay tuned Step Ten ONLY REQUIRED FOR THOSE WITH HiFi SOUND SYSTEMS If you don't get any sound coming out of the unit you will need to do this. Go to the trunk, find the amp. Left side underneath the black cover. Unplug the plug there. find the thinnest BLACK wire on that bunch of cables. This is your trigger wire. For those unfamiliar with amps, this wire receives a signal form your head unit to tell the amp to turn on. if your amp is not on, you won't get any sound. Cut this wire. tap into the end that goes to the amp. and wire it straight to the fuse box in the trunk. The fuse box in the trunk only turns on when your doors are unlocks and shuts off after a period of time so don;t worry about battery draining. To plug it into your fuse box you have 2 options: 1) jam it into a free fuse slot 2) buy something called add-a-circuit. Looks like this: I recommend option 2 Step Eleven Bring the USB connector from the combox to the head unit. 1) unplug the USB HSD connector. 2) unscrew the hooks for trunk net with a T40 3) Take your bottom part of your seats out. Just grab the seats and pull straight up. same thing with the driver side shoulder rest part of the seats. (don't know the exact term but the part in between the door and the actual seats) 4) Find the thickest black cable or trace the USB HSD cable from the combox and start unwrapping it form the bunch of wires. it goes from combox -> shoulder piece -> front of the seats -> middle lump in middle rear seats -> armrest slot. Once you get as close to the arm rest as you can. stop Step Twelve Take apart unplug the HSD USB connection from the arm rest. 1) if you look inside your arm rest there's the USB port is on its own plastic piece and you can just lift it out of place with little to no force. unplug the usb connector. (its white on this end) 2) take apart the rear vents. Start from the top left corner, pry, then go top right corner and down to left and right corners. 3) at this point when you look inside you'll notice there's a plastic vent piece, just pull it out. its long and goes all the way to the front, don;t worry its very easy to put this back. 4) Drag the cable from inside the arm rest as close to marked location (2) as possible. the lines show you how the cable is routed. goes into the arm rest at position 1, goes to position 3 and then to position A. When you get the cable to position 2, fold the carpet down to position A and find the other end of the cable. Grab the cable from position A and pull as hard as you can. The carpet is too tight for you to break the clip holding the cable down so pultting it will break it and free the cable completely. 5) Drag the cable up through the left side of the center console, you can tuck it in underneath the plastic. in the area underneath your steering wheel there is a hole you can feed the cable through to the back of the head unit. Step Thirteen Zip tie the cables so they arent loose and dangling everywhere and put everything back together. Thats it for now, I will update this post once we figure out more. Last edited by Chris@codemybimmer; 01-03-2014 at 08:13 PM.. |
12-06-2013, 11:24 PM | #2 |
Rep 1,397
Coding section
Phase Two. Coding
Change your car's build date to 11/12 under FA Those coming from HU_Entry Add VO: 609 - Professional Navigation Change VO: 6NH to 6NS - It's like 6NK but for NBT VO code HU_NBT and Kombi Done Those coming from HU_CIC Remove VO: 633, 6FL, and 6VC Change VO: 6NK/6NR/6MH/6N(whatever you have) to 6NS VO code HU_NBT and Kombi Last edited by Chris@codemybimmer; 12-07-2013 at 10:24 AM.. |
12-06-2013, 11:25 PM | #3 |
Rep 1,397
What works and what doesnt for the time being
WORKS
almost everything Almost everything! only bluetooth calling and optical wiring left to be done DOESN'T WORK 1) Bluetooth phone calling doesnt work because the mic is still wired to the combox Last edited by Chris@codemybimmer; 01-04-2014 at 09:49 AM.. |
whatnot22.50 |
12-07-2013, 05:51 AM | #4 |
Rep 458
You forgot to mention installing the screen, but I guess this is just drop in replacement.
Could this be further complicated by region? For example I am in the UK and my basic head unit has DAB radio. Could this change connections between units? |
12-07-2013, 07:59 AM | #5 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
http://www.bmwpartsupply.com/OEMPart...119251703.html I'm still not sure what else the AUX cable in the combox does because when I disconnected my combox completely, I was no longer able to see the song titles on my KOMBI so I hope there's no other internal connections going to it. There's only two connections going into the combox - beige USB and black AUX cable. I might also need to get an aftermarket Bluetooth antenna because there is no Bluetooth Aerial Antenna on the combox or on the CIC so my gut feeling is that it might be just integrated to the combox. |
12-07-2013, 08:58 AM | #6 | |
Rep 1,397
can't believe I missed that out lol I'll fix the post later |
12-07-2013, 09:57 AM | #7 | |
Rep 1,976
12-07-2013, 01:55 PM | #9 |
Rep 1,976
Looks like we have some problems. I'm not sure how I can part the combox because as soon as I disconnect the combox, the following items will stop working.
1) BMW startup/warning chime 2) Instrument cluster no longer displays my entertainment list but pressing on the buttons will change music tracks 3) Trip computer no longer works 4) Efficient dynamics no longer works 5) Service info no longer displayed I had another look at the can-bus cable and it looks like some of the Pinouts are going going straight into the combox. Aside from running the AUX and the Armrest USB, I might have to change the pinouts again for the can-bus cable for the cluster to communicate with the NBT without having to go through the combox. This might explain why for those of you who went from HU_ENTRY to HU_NBT, all your gauges and service info will not work. As for the USB, if you're going from CIC to NBT, you will have a beige connector anyways which goes into the NBT just fine but even with that, I still don't get any connectivity on the glovebox USB port. I'm going to try and take apart my glovebox and armrest, use the armrest USB with the cable that's going into the glovebox and see if that works. If I can at least get USB working, that means I'll be able to get my navigation and I'll finally be able to load some music to the system. |
12-07-2013, 02:00 PM | #10 |
Rep 1,976
Bluetooth now works! But for telephone audio only. I took the FAKRA connector for the satellite radio and connected it to the beige FAKRA on the NBT and I can now pair a phone to it. Of course though, the other end will not be able to hear me since the bluetooth mic still goes into the combox.
12-07-2013, 04:57 PM | #11 |
Rep 1,397
12-07-2013, 09:06 PM | #12 |
Rep 40,648
Nice write up! Thanks for sharing.
I told you already though, the old Combox needs to be completely disconnected, the Fiber Loop Terminated, and the USB, Aux, Bluetooth and Microphone (for CIC only) need to be rerouted to the back of NBT Head Unit. Also, the Pinout on USB Port wiring is different, and needs to be rewired. And as I think you have already discovered, the main CAN Bus Pinout is different too and needs to be rewired.
12-07-2013, 10:20 PM | #13 | |
Rep 1,397
12-08-2013, 12:44 AM | #14 | |
Rep 1,976
I don't think I'm going to go for a full perfect retrofit but if I can just get the nav, bmw apps and the usb working, I'll be happy with that. Of course, I'll lose all the bluetooth functionality but I guess it's a good trade off to be able to watch movies right off a external HDD. Instead of running the beige HSD back to the head unit, I think I'm going to try and change the pinout for my glove box cable and use that as USB1. I'm kind of hesitant to rewire/run too many cables because I still want to be able to fit the CIC back in without much effort when I take the car in for service. This vehicle is also a lease so I don't want too much work to uninstall the system and put the old one back in. Last edited by steve@codemybimmer; 12-08-2013 at 12:51 AM.. |
12-08-2013, 06:47 PM | #15 |
Rep 1,397
12-08-2013, 08:59 PM | #16 | |
Rep 40,648
12-09-2013, 12:05 AM | #17 | |
Rep 1,976
Before I start striping the cable and changing out the pinout, is there any possibility that the glove box USB is configured differently to the armrest USB? I thought about just taking out the back plating of the armrest USB then connect the glove box HSD cable to the armrest USB to see if that works. |
12-09-2013, 12:17 AM | #18 |
Rep 1,976
By the way, this NBT unit has the Sirrius XM sticker on it and it also has the pink FAKRA connection for the Sat Radio antenna. Maybe all Euro and NA NBT head units have Sirrius XP integrated.
My NBT has FM1 and FM2 connections and my CIC was able to do this with just one antenna connector. I think I might just buy the FSC code for the satellite radio for the donor vehicle and just use that on the NBT for radio. Last edited by steve@codemybimmer; 12-09-2013 at 11:24 AM.. |
12-09-2013, 03:08 AM | #19 |
Rep 458
A UK one wouldn't. The UK NBT is a DAB unit to match the UK radio standard. Think the Euro ones are just FM only from what one of the eBay sellers told me.
12-09-2013, 09:04 AM | #20 | |
Rep 1,976
It's kind of weird how I have the pink antenna port and all the stickers for the XM radio though. Last edited by steve@codemybimmer; 12-09-2013 at 09:14 AM.. |
12-09-2013, 11:26 AM | #21 | |
Rep 1,976
Are you able to use your armrest USB and glove box USB port interchangably with that same beige cable? Before touching the pinouts, I'm going to try and connect my armrest usb plate to the glovebox usb and see if it works with that beige cable. Last edited by steve@codemybimmer; 12-09-2013 at 11:46 AM.. |
