02-13-2014, 12:48 PM | #45 | |
Rep 260
On a different forum I saw someone did the same and BMW refused to sell it as it was a safety warning. I am dreading that might be the case At least we have given this one a proper go Thank you for all the help so far @shawnsheridan One thing I find interesting dont know if its a 2014 thing *my car was built 24th Jan is that when I turned on LDW it moans about Pedestrian Warning system as well |
02-13-2014, 12:54 PM | #46 | |
Rep 260
So something to ask: I have added: 5AC High-beam assistant <--- Had this already from factory 5AD Lane departure warning <--------- Added this via VO and coded 5AS DRIVING ASSISTANT <----------- Recently added this as well 5AT DRIVING ASSISTANT PLUS <------ I am assuming this is for ACC? Is the night camera something COMPLETELY DIFFERENT or uses same kit? I also saw some info on LDW and FCW being linked to keys interesting: I still (on my key) dont get the LDW lights showing in the Kombi when I boot up the car. I used my spare key the LDW and FCW car showed..... Here are the errors I have been getting: |
02-13-2014, 12:57 PM | #47 |
Rep 40,774
Night Vison is an entirely different animal. It has its own Camera mounted in the Grill and a NIVI ECU, and it has its own FSC Enabling Code.
02-13-2014, 01:05 PM | #48 |
Rep 260
02-13-2014, 01:10 PM | #49 |
Rep 40,774
Everything is retrofittable if you are willing to pay for it. Camera / ECU and FSC Code is very expensive. Cost to Retrofit is probably $3.5k to $4k.
02-13-2014, 01:15 PM | #50 |
Rep 260
02-13-2014, 01:17 PM | #51 |
Rep 40,774
I have no idea on ACC cost.
02-14-2014, 01:27 AM | #52 |
Rep 260
Ok looks like you need FSC codes for FDW and FCW regardless of if you have SLI or not. I have pinged my sources for these codes and will wait and see what they have to say.
I have it all coded but get: 1. Lane departure Warning Deactivated (Not an error message rather a info message) 2. Collision Warning Disabled (Error / Warning) 3. Pedestrian Warning Disabled (Error / Warning) --- I have no idea where this came from...... With other research it may seem (might be fruitless if I can't get the FSC codes) that one needs the button panel as well to make it work. I am not or don't have access to the parts section so I don't know where or what part number is needed for the buttons panel. I have HUD but still not panel to activate or deactivate the HUD this in my car is done via the NBT. @fenster could you take a pic of your button panel just want to see if its retrofittable or if its part of the entire dash |
02-14-2014, 01:52 AM | #53 | |
Rep 260
AppID 126 (7E) - Speed Limit Information (SLI) (S8THA) AppID 190 (BE) - DRIVING ASSISTANT PLUS (S5ATA) aka Front Collision Warning (FCW) AppID 191 (BF) - Active cruise control+Stop&Go function (S5DFA) Apparently BMW AG says that's not LCW ... and for my region its not available (which makes not sense cause you can buy it on the car). Maybe there is a LDW FSC |
02-14-2014, 01:57 AM | #54 |
Rep 26
I think this is the small buttons you are looking for from realoem
http://www.realoem.com/bmw/showparts...27&hg=61&fg=35 But doesn't seem like 318d can have them so why do they show up in the list? |
02-14-2014, 03:42 AM | #55 | |
Rep 260
02-14-2014, 11:31 AM | #56 | |
Rep 67
Left to right: Blind-Spot Detection Frontal Collision Warning Lane Departure Warning HUD is turned on/off in iDrive: View post on imgur.com Hope that helps.
2014 335xi | Luxury | Technology | Imperial Blue Metallic | Saddle Brown Dakota | Driver Assist Plus | Cold Weather | Active Cruise Control | Harman Kardon
02-15-2014, 06:12 AM | #57 |
Rep 40,774
PIA is Personalization, Individualization and Adaption, and is normally associated with settings that are exportable to thumb drive as a profile.
02-15-2014, 12:55 PM | #58 |
Rep 260
Right, so took it to the dealer to fit some M Performance Parts. The parts guy is a good chap and a bottle of good scotch goes a long way
There were some MOST communication errors which were reset using the ICOM8 tool, however he said the FCW and the Pedestrian warning were permanent warnings. He would have to reprogram the car on Monday (so it's booked in). When I looked at the fault both of the warnings / errors were related to ACC (advanced cruise control), which is interesting as I didn't turn any of it (ACC) on I added the option to VO and VO coded KAFAS (first as read on another forum) then KOMBI. Both of them are referring to a short to the ACC system (which makes sense as there is no ACC system). I am wondering two things: 1. If I find where there is a reference to the ACC and disable it will the errors go away? 2. Maybe the VO option we added Shawn was for the advanced FCW and LDW that uses ACC instead of using the KAFAS camera? Maybe the key sits with a different VO option.... The other interesting error was the FCW was trying to change something in the DSC ECU and it was getting a deny error since the function it was calling did not exisit... so maybe along with the KAFAS2, KOMBI the DSC ECU needs to be coded. The puzzle carries on. Shawn is there no tool out there to reset the "permanent errors" or is it find the code fault and fix it not a reset issue? incidentally he said to me SLI requires a FSC but he never heard of LDW or FCW requiring on as the FSC code for SLI unlocks the KAFAS2 ECU to allow its functions. @Fenster - Thank you for the pics and file I really do appreciate it |
02-15-2014, 01:07 PM | #59 |
Rep 40,774
I don't know what VO Code(s) you added; however, 5AD should have nothing to do with ACC. 5AS is questionable, and 5AT definitely involves ACC.
As for the FSC Codes, besides 7E for SLI, KAFAS has BE & BF Enabling codes. They are unlocking something camera based that 7E SLI isn't. There are tools out there like Autologic for clearing fault codes, but they are expensive. You can get ISTA/D VM and clear them too.
02-16-2014, 06:24 AM | #60 | |
Rep 26
I find it strange the SLI code unlocks the kafas 2 ecu since there are many cars Equipped with LDW but don't have SLI here in Europe they are booth separate options. |
02-16-2014, 06:48 AM | #61 |
Rep 40,774
The 7E FSC Code unlocks SLI only. LDW did not used to require an FSC Code, and still might not as 5AD, but might when part of 5AS and /or 5AT. The new BE / BF FSC Codes, one of them for sure is for 5AS Driving Assistant Plus. I will get confirmation on these two FSC Codes.
02-17-2014, 04:06 AM | #62 | |
Rep 260
@Fenster confirmed on his car he gets no audio or visual warning from LDW only warning he gets is vibration. I seriously think LDW would work. Now the nut to crack and I would really appreciate the help Shawn is FCW. There are two one with ACC which is what seems like to have thrown a million errors on my car (for obvious reasons), then there is one that is camera based FCW with the LDW. That one I assume we can get to work. I wouldn't mind retrofitting ACC but I have searched high and low to try figure out how to retrofit but haven't seen anything so if anyone knows I would love to hear from you. From Drive Assist Plus FSC BMW AG is very sticky on these codes. Four of my usual channels have been blocked by BMW AG for these codes.... |
02-19-2014, 08:34 AM | #63 |
Internet Ninja
53
Rep 626
not true because I have lane departure and no top view. it uses the camera mounted in the rearview mirror.
02-19-2014, 02:38 PM | #64 |
Rep 40,774
I know for certain now that the BE FSC Code is for Collision Warning and the BF FSC Code if for Pedestrian Detection.
Every new car I have seen stateside with these has them as part of 5AT Driving Assistant Plus.
02-19-2014, 11:08 PM | #65 | |
Rep 260
1. You can turn on the feature via FDL coding 2. You require (no way around it) BE and BF FSC coding which is part of option 5AT Driving Assistant Plus. So until one of the FSC providers manages to find a way to access these FSC codes, we all dead in the water for these features. My car is at the dealer they busy reprogramming it back to VO, since trying to turn on FCW turned on some permanent errors which I couldn't clear. |
03-20-2014, 04:13 AM | #66 |
Rep 1,772
If I understood this thread correctly all I need to do to get HbA is to do the VO coding for it?
I have LDW as part of 5AS. So do I just add 5AC then VO code KAFAS2? Is this just the on/off or is it the variable high beam assist? How do I keep it turned on as obviously I will not have the button on the stalk to turn it on. |
