BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 with 437Ms
proTUNING Freaks
      11-28-2016, 11:39 AM   #23
pkancel
pkancel's Avatar
Drives: BMWs
No rubbing issues at all, front nor rear and its been fully tested with 4 people in the car. In fact, just installed Bilstein B14 Coilovers and dropped it further and still no rubbing.
Tires are Hankook Ventus V12 EVO2
Originally Posted by Kabrich View Post
No rub or issues on front after some time has passed?
What brand are you using?
Kabrich354.00
      11-28-2016, 03:34 PM   #24
lo_xyooj
lo_xyooj's Avatar
57
Drives: Alpine 335i
That is pretty slick to run 255 up front lowered with no rubbing...
      12-05-2016, 03:17 PM   #25
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
I wonder if the front M replica has slightly more room for 255 than OEM
      12-05-2016, 03:42 PM   #26
yoandry
yoandry's Avatar
676
Drives: G80 M3CX & X5 M50i
I dont get your question? OEM are 9s and reps are 8.5, so 9 has more room for 255 tires. I have the reps with 235/40 and is perfect.
      12-05-2016, 05:58 PM   #27
Kabrich
His Bumper is not OEM. NOT THE WHEELS.
      12-06-2016, 09:33 AM   #28
pkancel
pkancel's Avatar
Drives: BMWs
No the M bumper isnt changing anything as far as room for the tires. I just spent a lot of time looking at diameter and width of tires and the 255s seemed far more likely to work and look right. As I sent to Kabrich...I cant stand stretched tires where there is any wheel poke. No offense to anyone here but that looks so odd to me plus does anyone here really want to expose the wheel further to curb rash... Second is tire diameter, which you dont see as much but a tire too tall for the car, wheel, etc and that looks odd as well. Like my grandpa in the 80s who would want as much tire sidewall as possible for a cushy ride on his Cadillac. doesnt look right on these cars or really any cars these days. To me, lower profile is always better as long as the wheel/tire fender gap can be reduced by lowering. And assuming you dont have to drive on crappy roads like up in LA where you would bend wheel with too low a profile.
      12-06-2016, 05:25 PM   #29
Kabrich
What I am trying to grasp from your post and pm is why 245 in the front would have more poke than the 255
      12-06-2016, 07:31 PM   #30
pkancel
pkancel's Avatar
Drives: BMWs
Anyone reading now wont see the information I sent him privately but to add...the 245/40 19 has a diameter that in my opinion is too tall vs stock, which is going to cause a misreading on your spedo also. The 255/35 is very very close 661mm vs 662mm stock, whereas the 245/40 is 678mm. Tire experts say no more than 3% variance recommended. The 245/40 is pretty close to that recommended limit whereas the 255/35 is less about 1/4%
The width for a 245/40 19 is 9.65 inches vs 255/35 is 10.04. So you can see the 255 is a slightly wider tire providing more coverage, less poke. Not as tall but wider than the 245/40...but nearly spot on with diameter from stock and of course, no one minds having wider tires unless they rub, which they dont.
      12-07-2016, 04:18 AM   #31
Kabrich
FML.
Originally Posted by mbanks21 View Post
245/35 and 275/30 here. H&R sports, no issues at all
I went with OEM 437M Fronts 19x9 et29 with 255/35-19, Rears 19x10 et40 with 265/35-19
Originally Posted by tim3less2 View Post
I'm running Michelin Pilot Super Sports 235/35/19 265/30/19.
Love the 437Ms for sure! Looks amazing on our F30s.
Originally Posted by steelerfan View Post
If your buying tires, i would suggest running 235/35/19 265/30/19
Originally Posted by .BMW. View Post
Has anyone tried 245/35 front and 265/35 rear on OEM 437 wheels? I.e. reduce the front and rear tire widths by 10mm, compared to M3/M4 tire sizes, but keep the 35-profile.I think this setup might be the perfect compromise! Reduce the front poke as 255/35 results in but still fairly wide tires to avoid stretch as much as possible.
Was leaning towards 245/35 and 265/35 but now reconsidering that for 235/35 265/30.
EDIT: Done. Putting on the Continental SportsContact 6 235/35 265/30. Too late to change now.
      12-07-2016, 07:27 AM   #32
chicagoshark
chicagoshark's Avatar
Drives: 2018 M3
FML.
Isn't 235 quite a stretch on 9" wheels?
      12-07-2016, 12:44 PM   #33
pkancel
pkancel's Avatar
Drives: BMWs
Tire size comparsion...taking a life of its own:)
Yes, 235-35 is a bit of a stretch for 9 inch wheel. Recommended is 8.5 maximum. Anyone unsure, I say this respectfully because we have some that have done this over and over and others that are newer and learning by asking these questions. Just know there are a lot of variations that will work, some trying different options and some personal preferences. What I did by going with 255-35 fronts and 265-35 rears was trying to stay close to the OE diameter to keep my spedo reading accurate but also I wanted it to look great and be proportionate relative to the fender gap when I lowered the car so there wasnt any rubbing. And as I mentioned previously, no wheel poke where the wheel sticks out further than the tire.
To note, I think I saw someone mention something about a 245 vs a 255 and that a 245/35 would reduce poke over a 255/35. If I misread that, my apologies. But thats not accurate...A 255/35 is wider than a 245/35 by almost a half inch, so the 245/35 would be stretching tire more and have more wheel poke than the 255.
      12-07-2016, 02:15 PM   #34
chicagoshark
Drives: 2018 M3
I think the poke he is referring to is the tire/wheel sticking out beyond the fender, not the wheel sticking beyond the tire. I think that's what Kabrich is referring to.
      12-07-2016, 06:54 PM   #35
Kabrich
Why did you not do 255/35 and 265/30 are the -5 on rears seem to be pretty much BMW Standard for staggered?
      12-07-2016, 06:59 PM   #36
Kabrich
Could be, but as someone with 255 on front recommended it (Steelerfan) I had to give that a lot of weight, especially as I am using a tire that has not been tested on this setup. Would rather be safe on what would work.
      12-12-2016, 09:52 AM   #37
pkancel
pkancel's Avatar
Drives: BMWs
These pics are with the M5 wheels. resizing the M4 wheel pics now
Update: 10 days ago I removed the B8 Sport shocks and Eibachs, (incorrectely said B6s before) and installed the Bilstein B14 covers at Supreme Power. Going to post in classifieds the B8s for $150.00 great deal and they were only on for about 3,000 miles.
Also now going to be posting in classifieds the car too because over the wend I bought a 2015 M4 Cab. Anyone looking for a great car, check it out as I just did the coil overs and about 2 to 3 months before that just had Irvine BMW install the Limited Slip Diff. The car is a 2012 with 48,500 miles, CPO until 2018 or 100k miles and Extended Maintenance Plan until 2018. Will be asking $26,900.
[QUOTE=pkancel;19804449]Update with new photos after having it dropped. Just installed Pro Kit Eibachs and Bilstein B8 Sport Struts and Shocks. These photos are the same day it was done, it has since settled even more slightly. No gap at all front or rear and has a little rake from front to rear still. There is no poke at all. To remind, 255-35-19 on OE 437M 19x9 et 29 on front and 265-35-19 19x10 et 40 rears. No rubbing in front or rear. See pics, sorry not better quality but click on the picture and it should open a larger view.
      02-15-2018, 01:55 PM   #38
R99
Drives: 2016 330d F31 Touring
Sorry to be a pain but Photobucket has shafted the thread & I’d love to see the pics!
I know you’ve sold the car, but if you wouldn’t mind putting a few pics up that would be great!
      04-23-2018, 06:57 PM   #39
f30_Imperial
Drives: f30 Imperial Blue
Bump would love to see this setup too.
      05-13-2018, 07:18 PM   #40
pkancel
pkancel's Avatar
Drives: BMWs
M437s
Here you go: 255-35-19 on OE 437M 19x9 et 29 on front and 265-35-19 19x10 et 40 rears. No rubbing in front or rear with the car lowered and I had my BMW dealer add the limited slip which made the car even more fun to drive with the Sprint Booster as well.
      05-18-2018, 06:26 PM   #41
Californiaeurocars
Drives: 13 328i
Here are some from our f30 at bimmerfest west 2016 with copper plated 437m
