08-24-2015, 07:16 PM | #1 |
Rep 524
Strange seat belt warning
So I just picked up my car over the weekend and so far I've experienced a few problems with it just driving it for the past 2 days.
For some reason every once in a while, with nothing in the passenger seat but my phone and a roll of toilet paper, the seat belt warning goes off. After a while it turned off but sometimes it just continues until I belt the passenger seat. Also my idrive has restarted several times while driving using the navigation. I've seen a few threads about this so I guess that is just normal? Oh also I thought my car should have launch control if it has the sports automatic transmission? Do on x35i engines come with launch control? I put the car in sport+, put the shifter in S mode and held the brake and gas at the same time but that just revs the engine until the brakes aren't strong enough to hold the car and it creeps forward. EDIT: Oh there is also a crazy rattle behind the dashboard/instrument cluster. I don't have the HUD and most of the boards with people reporting similar rattles said it was an issue with the HUD so I'm not sure what that might be... Any insight would be super appreciated, otherwise I guess I'll just call my local dealer and see if they have anything they can do... Oh btw the car is a 428i gran coupe if any of the issues are related to that vehicle. Last edited by kadify; 08-25-2015 at 08:49 AM.. |
08-25-2015, 03:55 AM | #2 |
Rep 378
Drives: M135i, becoming an X3!
WRT the seat belt warning..... there's a pressure pad in the passenger seat. The weight of what you have put on it is probably just on the cusp of triggering it. So, sometimes it sets it off, sometimes it doesn't....
I had a faulty pressure pad in the seat, and of note, the airbag won't deploy on the passenger side if it doesn't think anyone is sitting in it. Easy way to test. Get a person to sit in the seat and drive. Somewhere very safe, and slow, get them to remove the belt. The warning (dashboard not audio) should stay on, not be intermittent. My fault had the warning intermittent, so sometimes the car thought someone was in the seat, sometimes not. But, I suspect yours is just down to the light weight you have on the seat. As for Nav restarting and LC, I can't help with that. But hopefully I've helped with the first. Enjoy the car! |
08-25-2015, 08:51 AM | #3 | |
Rep 524
Thanks though, I am enjoying it! |
08-25-2015, 02:39 PM | #4 | |
Rep 740
08-25-2015, 02:47 PM | #5 | |
Rep 1,502
Oh, and yeah pressure pad as others have said. But take care of that TP. |
08-26-2015, 11:55 AM | #6 |
Rep 524
