BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Any problems with rattles, creaks, squeaks etc.... on F3X's?
      12-13-2012, 01:10 PM   #23
Mungogrubb
Mungogrubb's Avatar
Drives: X4 30D MSport, Carbon Black
Originally Posted by dopper99 View Post
Had exactly the same problem with my seat belt buckle. You think its the seat at first but if you put your hand next to the buckle and underneath it, you can feel it vibrate at the same time as the noise and on mine was coming from the rubber gaiter underneath the seat belt receiver buckle.
To fix, simple spray a load of WD40 into the top of the buckle and it will find its way right down and into the rubber gaiter at the bottom. No need to take anything apart.
Thanks Dopper thats exactly where mine is squeaking- will give the WD4o ago on the weekend and report back
      12-13-2012, 02:09 PM   #24
crowdedhouse
crowdedhouse's Avatar
Ireland
70
Drives: 2021 G20 330d mSport
Silicone spray would probably do the same job, less severe and certainly less pong that WD40 !
Seven Worlds Will Collide
