BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Why won't my steering wheel stop shaking?
      08-08-2022, 08:02 PM   #1
AnimatedDriver
Driver
Drives: 2017 BMW 330i
I can't figure out why my steering wheel continues to tremble ever so slightly. I have...
  • had my wheels rebalanced 4 times
  • inspected rims for damage
  • checked tire pressure (32/36 psi)
  • aligned wheels (at dealership; alignment was fine/not necessary)
  • Rotated wheels
  • Checked wheel bearings / suspension / brake calipers
Only other thing I can think of to do is either have my brake rotors checked to see if they're out of round, which I haven't done because the tremble is speed based; roughly between 40 to 60 mph. My understanding is if the wheel isn't shaking persistently then more serious parts like steering rack, wheel bearings, brake rotors are not to blame; but I'm not a mechanic so I could be horribly wrong.
The ride itself is smooth. No persistent vibration or otherwise odd feeling rolling down the road. I only visually notice the steering wheel slightly rock left/right when I hold the wheel loosely. Holding the steering wheel a bit firmer stops the shake but then vibration is felt in hand. I can lock my wheels left and right with no issue. I am led to believe since I only notice this issue at a certain speed that it's just a matter of imbalanced wheels. But I have had them rebalanced multiple times by different techs — surely they can't all be doing it wrong??
'17 F30 Sedan // 57k mi // 18" Double-spoke wheels, style 397 // no runflats
      08-08-2022, 08:19 PM   #2
BMWILUVU
Drives: 340ix
  • Rotated wheels
Do you have a front splitter or other aero mods?
      08-08-2022, 09:21 PM   #3
AnimatedDriver
Driver
No, stock body trim.
      08-09-2022, 07:46 AM   #4
SuperLomi
Drives: 2013 335i M-Sport
Having ruled out everything else:
Check the condition of the bushings/ball joints for abnormal wear/play/damage. My first suspicion might be the big fluid filled bushing on the thrust arm has leaked - which may or may not be easily seen visually.
      08-09-2022, 03:52 PM   #5
AnimatedDriver
Driver
To be clear, you are referring to the front struts right?
      08-09-2022, 06:36 PM   #6
SuperLomi
No, the thrust arm, also sometimes referred to as the upper control arm.
      08-10-2022, 11:49 PM   #7
alohasurftoad
Have you checked for warped rotors or runout out of spec?
      08-10-2022, 11:51 PM   #8
AnimatedDriver
Driver
Negative. I have that as well as the upper thrust arms to check when I see my car next.
      12-12-2023, 09:46 PM   #9
AnimatedDriver
Driver
If anyone should stumble upon this thread, here's the conclusion:
I ended up replacing the control arms and upgrading the suspension at the same time. Haven't had the issue since!!
Many thanks to SuperLomi and alohasurftoad for the tips!
