BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 18" wheel fitment question
      04-18-2020, 04:10 AM   #1
s55jesus
M Enthusiast
s55jesus's Avatar
438
Drives: 2018 F80 M3 ZCP
  [0.00]
Hoping someone out there knows the answer to this.
Found a set of new 18" TE37's meant for the Honda Civic Type R but the bolt pattern is the same at 5x120
18x9.5 +38 all around
Will that fit on a F30 with a 255/40 square set up? I know the rears will fit but concerned about the front.
My car is currently lowered on ST coilovers.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC
2017 F30 340i (SOLD)
2015 F82 M4 (SOLD)
      04-18-2020, 05:37 AM   #2
s55jesus
M Enthusiast
s55jesus's Avatar
438
  [0.00]
Another thought just popped in my head. Bore size. Civic Type R has a 64.1mm bore size and F30's from what I've found have 72.56
Seems that I cannot run a hubcentric ring since the F30's bore size is larger than the Type R's instead of smaller.
So does that mean I will have to get it machined to the proper size?
2021 F97 X3MC
2015 F82 M4 (SOLD)
      04-18-2020, 10:56 AM   #3
alohasurftoad
Drives: 440i gran coupe w/mppsk
9.5" +35 fits. I believe 9.5" +38 will fit(by a hair) but I could be wrong and you'd need a 3mm spacer up front
Yes, you'd have to rebore the centerbore.
Better to get wheels with 72.56mm cb and width and offset that fit without issue.
      04-18-2020, 11:18 AM   #4
theEZV
Russia
178
Drives: F30 335i; Looking for F80
From what I've seen the "FK8 spec" TE37s are BMW 72.6 hub bore, the CTR guys all run hubcentric rings.
      04-18-2020, 11:42 AM   #5
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Spec wise you need to check the wheel itself...I haven't seen a TE37 made with 64.1mm bore size.... I suggest if this used wheel, go bring a caliper to measure the bore size before buying.
      04-18-2020, 02:46 PM   #6
s55jesus
M Enthusiast
s55jesus's Avatar
438
  [0.00]
Yeah my mistake. Seller stated bore size is indeed 72.6 and that the Type R folks need the hubcentric ring.
2021 F97 X3MC
2015 F82 M4 (SOLD)
      01-08-2024, 12:59 PM   #7
TomFord514
TomFord514's Avatar
Drives: 2018 Bmw 330i xdrive M Package
Hello, was wondering if anyone would have any information on this. I have a 2018
Bmw 330i xdrive and currently run 20” staggered set up 405m mags. With our road conditions I keep blowing tires with pot holes and need a higher profile. I’m looking to downsize to 18” and was wondering if 245/45/18 will fit. I found replica mags that are 18” 8.5 width and offset of 25. Not too familiar with these things so any help would be greatly appreciated!
