06-09-2014, 02:07 AM | #1 |
Rep 808
335i LED Conversion (work in progress)
I've switched out the front blinkers, reverse lights, and all door/footwell lights. I'm not sure if I like the footwell lights being so white so I left the passenger stock - the color difference between the reading lights and footwell lights kills it for me I think. I was going to swap the trunk light but the light is a different size. The door lights are noticeably brighter (for a brightness comparison, the footwell lights are the same as the door lights)
I'll add pics of the front blinkers in the housing tomorrow. I'm waiting on the rear blinkers from Bimmian still but I'll make sure I get those pictures up as well. I apologize for the low quality photos but an iphone in low light isn't the best... don't have my DSLR 6/11/14: Coded out all the flickering. The reverse bulbs definitely flickered, I coded the others before I installed anyways. Front left and right LED turn signals to remove flicker Module Section Function New Value Default FEM_BODY 3061 FRA_V_L_KALTUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 FRA_V_L_WARMUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 FRA_V_L_IS_LED aktiv nicht_aktiv FEM_BODY 3061 FRA_V_R_KALTUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 FRA_V_R_WARMUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 FRA_V_R_IS_LED aktiv nicht_aktiv Rear left and right LED turn signals to remove flicker Module Section Function New Value Default REM 3061 FRA_H_L_KALTUEBERWACHUNG nicht_aktiv aktiv REM 3061 FRA_H_L_WARMUEBERWACHUNG nicht_aktiv aktiv REM 3061 FRA_H_L_IS_LED aktiv nicht_aktiv REM 3061 FRA_H_R_KALTUEBERWACHUNG nicht_aktiv aktiv REM 3061 FRA_H_R_WARMUEBERWACHUNG nicht_aktiv aktiv REM 3061 FRA_H_R_IS_LED aktiv nicht_aktiv Reverse LED lights to remove flicker Module Section Function New Value Default REM 3061 RFS_L_KALTUEBERWACHUNG nicht_aktiv aktiv REM 3061 RFS_L_WARMUEBERWACHUNG nicht_aktiv aktiv REM 3061 RFS_L_IS_LED aktiv nicht_aktiv REM 3061 RFS_R_KALTUEBERWACHUNG nicht_aktiv aktiv REM 3061 RFS_R_WARMUEBERWACHUNG nicht_aktiv aktiv REM 3061 RFS_R_IS_LED aktiv nicht_aktiv Last edited by Steve33; 06-11-2014 at 03:19 AM.. |
06-10-2014, 10:51 PM | #2 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
PN for the rear backup lights please!
06-11-2014, 03:10 AM | #3 |
Rep 808
Turn signals
**Reverse bulbs Interior foot-well and door lights - here is for all 6 lights. (two in footwells, 1 on each door). FYI on the reverse bulbs, Bimmian has one set of reverse bulbs listed under the turn signals page. Get those and not the ones from the blinkers page Last edited by Steve33; 06-14-2014 at 09:58 PM.. |
06-14-2014, 09:17 PM | #6 |
Rep 34
Drives: 2014 328i
Thanks for the writeup.
06-15-2014, 01:32 AM | #7 |
Rep 808
E-mailed and asked if the blinkers will also work as brake lights (not sure if there will be a heat issue or not). I can pull the bulb from the brake light and see if it's the same kind of bulb as the reverse lights, or if it's the same as the blinkers. If it's the same as the blinkers, I'll put both of them into the brake lights and snap a quick video
No problem - I'll keep updating as I make some progress |
06-15-2014, 06:08 PM | #10 |
Rep 32,881
Yea i just managed to get the cover of one, the standard lights are LED, but they're warm (yellowish) light. I don't really understand why BMW didn't make them the same white light as the under exterior handle lights!
06-15-2014, 06:21 PM | #11 | |
Rep 808
Aren't the M lighted door sills the same bright white color? that makes triple no sense |
06-16-2014, 01:53 PM | #13 | |
Rep 32,881
It's a P21W which is the same as the reverse light |
06-16-2014, 06:12 PM | #14 | |
Rep 808
The whole thing is supposed to come out, not just the cover? And the bulbs are the same, just not sure if there would be a heat issue or whatnot |
06-23-2014, 02:10 PM | #16 |
Rep 4,976
Could this type of coding also code out the flickering headlights (HID) on a non projector (halogen) headlights for a 320?
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
06-23-2014, 03:30 PM | #17 | |
Rep 1,892
Left side: FEM_BODY 3061 XXX_L_KALTUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 XXX_L_WARMUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 XXX_L_IS_LED aktiv nicht_aktiv Right side: FEM_BODY 3061 XXX_R_KALTUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 XXX_R_WARMUEBERWACHUNG nicht_aktiv aktiv FEM_BODY 3061 XXX_R_IS_LED aktiv nicht_aktiv XXX can be (thanks to Shawn...): NSW is for the front fog lights FRA_V is for the front turn signals FRA_Z is for the mirror turn signals POL is for the parking lights (non-xenon I think) AL is for the low beams (not tested) FL is for the high beams (not tested) TFL is for the Corona Rings (not tested) BIX is for the BiXenon bulbs? (not tested) SML ??? LCI_[0..8] ??? In REM, they are: SL ??? SL_2 ??? BL_ (Outer Brake light?) (not tested) BFD_ (Inner Brake light?) (not tested) NSL_??? RFS is for the reverse lights FRA_H is for the rear turn signals KZL (no left/right, so this may be the license play light) (not tested) BL_M (no left/right, so this may be the center brake light in the rear window) (not tested) If anyone knows what the ? (unknown) are, please post what you know! |
06-23-2014, 05:59 PM | #18 | ||
Rep 808
The trunk - the bulbs don't fit properly in, so I haven't switched them. |
06-23-2014, 06:06 PM | #19 | |
Rep 808
BL_M should be IS_LED aktiv already? I think all F30's have the LED middle brake light? I'm not sure what the horizontal red bars are coding wise, but those are LED too I believe. So if SL and SL_2 are IS_LED aktiv already, I'm going to assume those are them |
06-26-2014, 11:12 AM | #20 | |
Rep 1,479
Drives: 2020 M340Xi (G20)
Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
06-26-2014, 12:23 PM | #21 |
Rep 1,892
06-26-2014, 02:10 PM | #22 |
Rep 1,479
You know I just realized that my owner's manual is incorrect; I do not have parking light (item 1 in attached)
Thanks
Al
