07-21-2014, 04:44 AM | #1 |
Rep 942
Retrofit additional USB in lieu of armrest cradle?
Hi, 4/14 F31 w/Pro nav.
The car has the armrest USB but not the phone cradle prep. I have activated enhanced bluetooth, which is great, and the phone cradle shows in the system as an external option, but shaded out as nothing is connected. I believe that if I wanted to retrofit the cradle prep then this would just be by way of a HSD cable plugged into the back of the NBT. I don't want this as I don't want to have to remove my iphone from its case. Can I retrofit a second USB socket instead? Would this retain the functionality of the cradle + snap in adaptor? Any pointers greatly appreciated. TIA!
2016 F80 M3
07-21-2014, 05:23 PM | #2 |
Rep 32,881
I can't see that being possible tbh.
What you could do is retrofit the cradle prep, and get the snap in adapter, and then use a male to female extension cable to go from the snap in adapters plug to your phone. If it's an iphone 5/s then one of these should do it: http://www.appradioworld.com/2013/09...extension.html |
07-22-2014, 03:04 AM | #3 |
Rep 942
Cheers, disappointing! I guess I was hoping just to be able to plug a similar USB HSD cable into the back of the NBT but in the socket for the cradle. Retrofitting the housing, then the iPhone 5S cradle and then using an extension would almost certainly work, but sounds like a v.v. expensive way of doing it.
I've got a not dissimilar lightning extension cable in our CR-V with a Pioneer AppRadio3, those cables are quite expensive for what they are, useful though!
2016 F80 M3
07-22-2014, 04:38 AM | #4 |
Rep 230
My car is on order but has the mobile prep and I also don't want the cradle - apparently the universal adapter has (2) USB ... unconfirmed...
http://f30.bimmerpost.com/forums/sho....php?t=1013570 |
07-22-2014, 12:55 PM | #5 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
You won't get all the functionality of the cradle but it can still be used as a USB port to play music off a USB key. You won't be able to play videos using the iPod interface though.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 07-22-2014 at 01:03 PM.. |
07-22-2014, 04:35 PM | #6 |
Rep 942
Epic, thats what I'm after! Thank you!
I've looked on RealOEM but have struggled to identify the HSD USB or cradle cables, don't suppose you have any idea of the p/n?
2016 F80 M3
07-22-2014, 10:28 PM | #7 | |
Rep 1,976
This will work. I bought a few things off this seller and his aftermarket cables are pretty good quality.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
07-29-2014, 04:45 PM | #9 |
Rep 942
Aritaurus - spot on call, thank you very much!
Bought one of those cables from that eBay seller, took a few days to arrive, installed this evening and bingo, exactly what I was after.
2016 F80 M3
07-30-2014, 06:33 AM | #10 |
Coding ECU's remotely
445
Rep 1,176
I can also confirm that this works. I bought an emulator from that guy & his aftersales service was spot on.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
07-30-2014, 07:29 AM | #11 |
Rep 1,976
