08-04-2014, 01:44 PM | #23 |
Rep 92
So there is a chance that I did the coding correctly? ;-)
Thanks again for your fast feedback. @ Alpine owners: Can you please check if there is an AMP (or similar) new ECU in the SVT? Thank you in advance! Greetings Roland Last edited by radair; 08-04-2014 at 02:11 PM.. |
10-13-2014, 02:27 PM | #24 |
Rep 931
No new ecu.
The Alpine retrofit kit for F3x is not connected to CAN or MOST ring.
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
10-31-2014, 02:17 AM | #26 |
Rep 1
Hi All,
I have installed the Alpine Retrofit Kit but I also cannot find the [8] Aftermaket_fitment in the vehicle profile. Is there any magic I have missed too? Thanks Sherman |
10-31-2014, 04:06 PM | #27 | |
Rep 40,752
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 10-31-2014 at 06:36 PM.. |
10-31-2014, 06:12 PM | #28 | |
Gettin It Figured Out
1820
Rep 2,669
10-17-2017, 07:12 AM | #29 | |
Rep 57
Hey Shawn, I'm not sure if you'd have the answer to this or not, but, do you know if it's possible to code the more advance Logic7/Harman equalizer onto the Head Unit...? The other day, I stumbled across the "Audio_System_Var" parameter whilst coding my vehicle, and changing the Var version from "Var 2", to "Var 1", improved the bass frequencies of my audio vastly. I was surprised this happened for 2 reasons. The first reason I was surprised was because I have the Base Audio setup (although I have just installed a pair of underseat subwoofers), so I wasn't expecting any difference in sound quality at all. The second reason I was surprised the Var parameter improved my sound quality is because, I thought the 2 band eq in the Idrive setting was the only way to eq the sound, but, it would seem that the Var version also contributes to the overall sound. This led me to the theory that it might be possible to unlock/code the more advance 7 band eq, also known as the Logic7/Harman eq. Thanks in advance |
10-17-2017, 07:29 AM | #30 | |
Rep 40,752
10-17-2017, 07:36 AM | #31 |
Rep 57
10-17-2017, 10:24 AM | #32 |
Rep 57
Not sure how many people know this, but, if you want to enable the 7 Band EQ which normally comes with the Logic7 Harman audio setup, you can code it in. To code it, go into;
HU_NBT/HU_CIC, Then search for "Amplifier_Variant", and then change the value. There will be three values to choose from (in my case anyway). Option 1 "Internal", Option 2 "External" and Option 3 "Most". Select "Most", and code FDL, and that's it. I couldn't use the 7 Band Logic/Harman EQ, as I only have the base audio setup unfortunately. But, I'm really curious to what happens if you use it with and external Amplifier. If any of you guys have success using the EQ with your aftermarket Amplifiers, then please report your findings/results. I wish BMW had included this 7 Band EQ as standard, a crappy 2 Band EQ is just not enough! ...One last thing, after experimenting further, I even managed to enable the "Bang & Olufsen" settings menu, although I couldn't use it at all, due to me only having the Base Audio setup. |
10-20-2017, 01:20 PM | #34 |
Rep 16,079
I doubt it's all that simple. You may be able to code to active the controller associated with the EQ DSP, but if your unit doesn't have the EQ DSP circuitry there's nothing there to control.
10-20-2017, 07:04 PM | #35 |
Rep 57
Yeah, that's true, I can testify to that as I tried the EQ on my Base Audio setup. But, since looking for a way to activate/enable the 7 Band EQ, I've come across a few threads online, where people have the Harman Kardon/Logic7 setup, but, bizarrely, no 7 Band EQ. I think that's such a disgrace, especially if you paid for the HK/L7 audio as an option.
01-21-2019, 01:14 PM | #36 |
Rep 23
Hi
today during the encoding of hi fi on hu entrynav lost access to the menus on screen 8.8. As the previous screen was 6.5 I think I lost the coding 3001 exbox> DISPLAY VARIANT> breites display of the current screen of 8.8. if I use the bmwai coder does not appear hu_entrynav to be able to re-encode the 8.8 screen. If I use e-Sys 3.27.1 with v63.4 Psdzdata lite I receive this message when read coding data: hu_entrynav[63] * CAFD_00000DED_003_015_039: Transactions-Report Hu_ENTRYNAV[63][K... readCPS O.K CAFD_00000DED_003_015_039 Fehler: NCD read from ECU"ECUId: HU_ENTRYNAV_0x63"for CAF "CAFD_00000ded-003_015_039"failed![C069] negative response error: Code: TIMEOUT P2/T2 ocurred Description : P2 TIMEOUT on service RDBI_PLAIN has error in result [Severity=2051][Errorcode=58640][ErrorCodeDescription=resouce not available][Vendorcode=2142][VendorCodeDescription=P2 timeout occurred]; Linkname: HU_ENTRYNAV_63_ETHERNET Severety; ERROR [2130765072] Other thing, when I intent to Edit FDL receive this message: No EST file chosen.[C155] if anyone can help me I will be very grateful Thanks Last edited by Anastomose; 01-21-2019 at 01:48 PM.. |
01-22-2019, 02:09 PM | #37 |
Rep 23
Hi
finally solved problem, with the help of a user from another forum. thanks a million @ aspamed82. this problem comes from trying to encode when we have installed a Chinese carplay module. Do not forget to remove the module before encoding. Thanks x3.bimmers.com and @aspamed82 |
04-11-2021, 09:00 PM | #38 |
Rep 73
amp
so we have to code a new amp if we change amps to a better bmw amp or aftermarket jl 600/6 ???
can i code the harman kardan hifi to my system if i have just basic hifi to get better sound ? |
10-02-2021, 12:32 AM | #39 |
Rep 6
Hi all,
I did whatever said in this thread but I am unable to get sound from my newly retrofited nbt id6 unit. My car has production year 2013/03 and it had entry HU. For triggering alpine hifi I also cut pin 13 and add it to pin 15. But still no sound. Any help appreciated.. |
10-26-2021, 10:52 AM | #40 | |
Rep 7
