BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Drivetrain malfunction!!!!!
      04-07-2015, 09:26 AM   #133
Burnt C6
Burnt C6's Avatar
Drives: 2014 Melbourne Red 328i Sport
It happened to me the day after I got the Dinan Tune installed. I had hit a good size pot hole and it cam on. I thought that might have caused it. I got home turned it off and restarted it and the message was gone was gone. That was back in September it came back on last night right as I was pulling into the garage. It won't go off this time. It also came up with the Chassis Malfunction notification at the same time. Time to take it in and see what the hell is going on.
2014 328i Melbourne Red Sport Line
Dinan Exhaust, Dinan Suspension, H&R Sway bars, Apex ARC-8 18x9 with 255/35 18 Dunlop ZII, AFE CAI, BMW M Performance Brakes.
      04-07-2015, 10:44 AM   #134
435ivan
Drives: Bmw f32
Originally Posted by NAV8TT View Post
I was driving to work in Eco pro mode and once i entered the highway, i tried to catch up on speed so I moved the gear to DS from D position and all of a sudden the car jammed up, started shaking and a signal came up in the iDrive saying Drivetrain malfunction, drive moderately, and the car wouldn't allow me to exceed 50 mls/h. The car kept shaking till I took the next exit. It was very dangerous as I entered the highway with that speed and there was a bunch of cars going at least 75 mls/hr that had to leave the lane I'm on. Darn it. The engine light is on now. I parked the car and I'm at work now. WTF!!
I have a 435i that I just got in November. I haven't had a problem with it till a couple weeks ago that I have gotten a down pipe and the jb4 installed. That night I was doing some highway pulls and once I reached top of 6th that I shift to 7th I got the drivetrain malfunction. It pretty much just cut all power It wouldn't rev or accelerate it got down to 60mph and so I pulled over to the side turned off the engine and turned it back on and I was fine. But it has happened a few times already. I asked around and someone had told me that wen it gets too hot or reaches a certain temperature the call will pretty much put itself into a safe mode and it starts giving those malfunctions. I don't know what to do to prevent it from happening besides no more highway pulls. Has anyone found a solution?
      05-07-2015, 10:27 AM   #135
JVBFTW
Drives: 2013 320i
Originally Posted by mocohead View Post
OP what gas (brand and octane) do you use?
Have you noticed the car cranking a long time before starting in the morning?
I've noticed the cranking issue in the am, and got a drivetrain malfunction warning on Sunday. I shut the car off, then turned it back on and had no issue.
What does the cranking + this problem point to?
Car is a 2013 320i 6MT, with about 20k on it.
John V
2013 320i 6MT
      05-11-2015, 12:01 PM   #136
gobears81
Drives: 2013 328i
This morning my 2013 328i F30 gave me the following error:
"Drivetrain malfunction: Drive moderately. Maximum drivetrain output not available. Consult service center."
Looking through this forum, it sounds like there could be multiple trips to the service center needed. I'm not looking forward to this!
Forum Jump
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
