11-07-2017, 04:58 AM | #89 |
Rep 2,157
Drives: X3M Competition
Is it normal to get a warning while coding?
I tried to do the door lights on reverse, came up with front light sensor failure the engine management light. A few seconds later it was all cleared no lights or errors.
CURRENT
X3M Competition- Toronto Red [url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Car[/url] |
11-07-2017, 05:00 AM | #90 |
Supreme Being
1806
Rep 5,425
When coding FEM (Front Electronic Module) yes, because the ECU restarts, disconnecting a load of monitored signals.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
11-07-2017, 05:04 AM | #91 | |
Rep 2,157
Is it only the FEM coding that needs ECU restarting?
CURRENT
11-07-2017, 05:28 AM | #92 | |
Supreme Being
1806
Rep 5,425
Best to just close your eyes or walk away I've found
11-07-2017, 05:41 AM | #93 | |
Rep 2,157
Why did I choose FEM as the first thing to code? I’m going to go code crazy when I’m back from my travels.
CURRENT
11-07-2017, 07:04 AM | #94 |
Supreme Being
1806
Rep 5,425
Because it's first on the list
We've all done it... don't worry - exactly the question I asked myself first time I coded!
RustyBitz1573.50 |
11-08-2017, 02:51 PM | #95 |
Rep 153
Where is expert mode on Bimmercode app found?
Hoping to code enhanced BT.
Current 2020 F40 M135i Misano blue
Previous2017 F32 420d xdrive M sport [COLOR="Gray"]Previous 2014 F30 320d M sport[/COLOR] [FONT="Verdana"]Previous 2009 E60 520d M sport[/FONT] |
11-08-2017, 03:06 PM | #96 | |
Supreme Being
1806
Rep 5,425
Even so it's still only FDL coding; for VO coding you'd need eSys or a list of all the FDL changes needed to enable enhanced Bluetooth (don't know what these are!)
11-09-2017, 02:29 PM | #98 |
Rep 2,280
Ordered an adapter last night after reading all these posts on here!
I'm picking up my F30 in just over a week so I thought in the meantime I'd practice on the car I'm part exchanging (F10 2012). Being my first attempt at coding, it was a little scary initially but once you get over that it's fine I've only coded 2 things so far (Fold mirrors on lock & Digital Speedo) I noticed that the list that come up is different to the demo version and also from what some of the guys on here have said. I didn't have a FEM ECU option come up. I was able to find the folding mirrors option here: Car Access System (CAS4_2) Expert Mode 3003 FH_Master KMFRT_SCHILIESSEN Looking forward to doing more coding in the new car soon! Kit used: Vgate iCar 3 Wi-Fi OBD F10 520d iPhone 6
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
11-09-2017, 03:55 PM | #99 |
Rep 503
I just managed to brick my ASD module with Bimmercode. I've coded lots with the app previously and it has worked really well, much less hassle than using the laptop. BUT after making a few separate changes to ASD I got an error and it failed to write the change to the ECU. The ASD module then vanished completely and ASD stopped working - nothing would bring it back. In the end I needed to physically disconnect/reconnect the ASD module in the boot and it finally returned. It does make me much more wary of it though as if the same had happened when coding one of the other modules things could have been far worse.
11-09-2017, 04:09 PM | #100 | |
Supreme Being
1806
Rep 5,425
This happens with eSys sometimes too.
11-09-2017, 04:33 PM | #102 | ||
Rep 503
Never had that with esys |
11-10-2017, 04:51 AM | #103 |
Rep 710
Tried coding the wife's cooper s but it turned its self off and refused to start until I restored all the original files. Didn't think it worked with the engine off but thankfully it did
11-10-2017, 10:01 AM | #104 | |
Rep 451
11-11-2017, 11:43 AM | #105 |
Rep 2,157
More coding today Rolls Royce bigs and bongs
Is they anything worth coding in Expert Mode?
CURRENT
11-14-2017, 08:06 AM | #106 |
Rep 153
I see expert mode is available via android now as well, anyone any idea how to code enhanced bt with bimmercode now.
Tia |
11-14-2017, 02:07 PM | #108 |
Rep 922
I'm going to explore the Expert Mode in Bimmercode (Android) this week at some point also, shall see if I can find a way to do the Enhanced BT.
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
11-14-2017, 03:53 PM | #110 | |
Rep 15
Do you just use the "update data" option on your current app or do you have to download the latest version of Bimmercode app? Thanks in advance Stampy. |
