BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 TPMS Facts!
      09-05-2013, 05:17 PM   #45
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
Originally Posted by EvenKeel View Post
Does one have to "program" the vehicle to recognize a new set of TPMS.
Lets say you remove your summer wheels and mount a new set of winter wheels that are already equipped with TPMS, how does one get the vehicle to recognize the correct sensors?
there is an option within iDrive
      09-06-2013, 05:29 PM   #46
Brian@bavarianx
Drives: E36 M3
Its an auto-relearn so it will detect then new set on its own.
http://www.thetpmsforum.com/forum.php
      11-21-2013, 12:15 PM   #47
Philipangoo
Philipangoo's Avatar
36
Drives: F30 335
Why are the TPMS replacement units for this car so pricey ? They were like 27$ each for my C63
13 335i Msport
89 E30 325is 5spd
      11-21-2013, 12:57 PM   #48
Dippydo
Drives: 2023 M8 Comp
2012 BMW  [1.00]
Is it me or does it not tell you which tire is low? I have the tech/nav package and when the light comes on it just lights up all 4 wheels. I read about the coding to tell you what the actual pressure is, but shouldnt it tell you which tire is low??
      07-27-2014, 08:11 PM   #49
DC X3M40i
DC X3M40i's Avatar
663
Drives: 2023 X3 M40i
I need help. I bought a 2014 335i xdrive that I have had for a week. I bought a set of gently used bmw 397 sport line wheels with tires and tpms. I tried to reset the tpms system within idrive however it says tpms system malfunction. It got to 49% the first time then crapped out. I think the wheels came off of a 2012 f30. Would the tpms sensors be different?
      07-27-2014, 09:00 PM   #50
cwazy1
Drives: MG F80 ZCP
I believe that tpms prior to the march 2014 manufacture date are different than post march 2014 manufacture date.
      07-27-2014, 09:34 PM   #51
DC X3M40i
DC X3M40i's Avatar
663
awesome....NOT.... so either i just learn to live w/o functioning sensors...or i go out and buy a new set of them to put on the car. i have working sensors on my stock wheels but i dont want to swap them back and forth.. and back and forth..
      07-27-2014, 09:57 PM   #52
cwazy1
Drives: MG F80 ZCP
I'm sort of in the same situation. I've got my working sensors in my 17" wheels, but after getting my 20", I have been running the car without sensors.
Depending on what wheels you're planning to swap, and the weather in ny, if you do not plan to get new sensors just put the old ones in the wheel set you will be driving in the majority of the time. I'd imagine that you have one set of more winter tires and one set of summers. Thats 3 months on winter and 9 months on summer? (correct me if weather in ny is not like this). Put the sensors in summers and call it a day.
      07-28-2014, 03:01 AM   #53
moonshine
moonshine's Avatar
Scotland
849
Drives: 718 Boxster S
A set of Continental VDO TPMS for my Wk 10 2014 build 335d (March 14) ordered from my dealer with chassis no. P/n 36 10 6 856 209
      07-28-2014, 05:48 AM   #54
DC X3M40i
DC X3M40i's Avatar
663
I might just bite the bullet and order some new sensors. Seeing the stupid toms light turn on..and getting the I drive warnings every time I start the car will get annoying over time. Can I get these anywhere other than ordering via my bmw dealership? Or do I need to get the factory ones?
Thx again everyone
      07-28-2014, 06:00 AM   #55
moonshine
moonshine's Avatar
Scotland
849
I understand there is a world wide supply issue and BMW are struggling to fulfil orders at the moment, therefore it may be difficult to get the Continental ones out with the dealer network at the moment / for some time until supply issues are addressed.
I bit the bullet and got mine from a dealer.
      07-28-2014, 10:42 AM   #56
DC X3M40i
DC X3M40i's Avatar
663
thx moonshine for the update
well... the more that i think abt it... i can probably live with it for a few months. when i slap my stock wheels back on in the winter... i can readdress the issue next spring.
that should hopefully allow time for the shortage to correct itself
thanks again for the information.. much appreciated!
      08-02-2014, 02:46 AM   #57
Mattt1
Drives: 335d xDrive
How much was the full set Moonshine?
      08-02-2014, 08:23 AM   #58
moonshine
moonshine's Avatar
Scotland
849
4 of these for £235.20 inc vat and delivery from Cotswold BMW -
http://www.babybmw.net/viewtopic.php?p=794022#p794022
      08-14-2014, 05:10 PM   #59
inspired626
Drives: A slow one
Found these pictures showing the difference between the2 new sensors depending on your build date.
Part #36106798872 by Huf (top picture)
Part #36106856209 by VDO (bottom picture)
http://www.thetpmsforum.com/showthre...the-difference
      08-14-2014, 09:15 PM   #60
bmwauug
Drives: 2023 X5MC
Same thing just happened to me (today) - I swapped the 401M wheels with a set of 442M summer wheels (OEM with TPMS); I am going to the dealership and discount tire tomorrow. Any updates?
2023 X5MC | Donington Grey | Black
      08-14-2014, 09:17 PM   #61
bmwauug
Drives: 2023 X5MC
Just looked at mine - the 401s have the VDO - the 442s have the Huf - the huf are causing the issue.
      08-15-2014, 08:52 AM   #62
bmwauug
Drives: 2023 X5MC
Confirmed with the dealer and discount tire - I need the new TPMS units. Current are showing 20psi when they are properly inflated. The most interesting part...
Dealer quote$550
Discount Tire quote$500
$50 well worth it to have the dealer handle it!
      10-17-2015, 10:45 AM   #63
gsplover
Drives: 2013 328ix
what to use?
I have a 2013 328i xdrive. Apparently there are two sensors that were used with this F30 chassis. I purchased some new wheels to use for winter tires but they need to outfitted with TPMs. Can I use any brand of TPMs as a set that are compatible with the 433Mhz transmission signal or do the TPMs and sensor need to match by manufacturer?
I tried to find out what part no was appropriate for my car through the dealer, but they would not give out the part no. The last 6 digits of my VIN are 535591, which apparently is enough to identity the appropriate TPM. Would someone clarify for me what I need to use with the new wheels to have the TPMS continue to function when the new wheels are mounted?
Thanks
      10-17-2015, 01:34 PM   #64
instalher
25cent millionaire
instalher's Avatar
Drives: 2020 m4 comp vert
2020 bmw  [0.00]
  [9.00]
  [0.00]
  [9.50]
2018 bmw 230i xdrive  [8.50]
i bought these and never put them in as selling car 150 bucks and someone gets new oem tpms.
      10-17-2015, 02:02 PM   #65
Yobyot
Yobyot's Avatar
493
Drives: MY19 X3 M40i
Thanks
Whatever you do, you need a new dealer. Anyone that won't give you the part number is simply trying to prevent you from shopping the part number around. Imagine what else they'd do to your car -- or your pocketbook if you let them.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
MY19 X3 M40i:
Produced: 2018-08-15; Delivered 2018-08-22
      07-09-2016, 12:02 PM   #66
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
Originally Posted by tiltmode43 View Post
I would guess that a TPMS light will come on in the dash, but nothing more. I haven't heard of a car that is equipped with TPMS and by removing the TPMS, causes any sort of real problems. Never hurts to confirm though!
Let's hear it from someone who has put wheels on with no TPMS
Didn't read the whole thread but I just drove a week with no TPMS, only issues I had were the TPMS light and you can drive in Sport or Sport+, you can still kick the shifter over into sport mode but that's as close as you can get.
