12-01-2015, 01:10 PM | #1 |
Rep 18
F30, Anybody with Bilstein B6 with stock spring?
Hi
This got to be the first time replacing shocks not because of failing part but because of the ride quality... mainly body roll and bouncy ride. There seems to be lots of discussions regarding B8 but not B6. Budget is tight and keeping ride height as stock(non M-sports) is crucial due to the road condition. So, trying to replace just 4 struts and use the stock spring. Does anybody have this set up and can share experience? Apologize for ignorance but if this set up meets the needs, all I have to buy is just struts or Do I have to purchase the additional parts like bump stop or et al..? Thanks |
12-07-2015, 03:24 PM | #2 |
Rep 12
I have just installed Bilstein B6 (HD) shocks on my F31. So far, I'm pretty happy with the result - much better ride quality. When going over imperfect surfaces, the ride is much more stable without being overly stiff. It's actually comparable to the KW V1 that I had on the same car. But with this setup, I can get stock ride height, same ride quality with much less cost.
And no extra parts is needed. |
12-07-2015, 06:52 PM | #3 |
Rep 2,036
VikNavy,
What are the specs on your wagon? ....wheel size/tire? .....DHP or base Xdrive suspension? I have a 2014 F31 with Xdrive and without DHP. I'm running staggered 18"s (Conti DWS06 All seasons) and I would like to know more about your setup. I like how you keep the stock ride height as I really don't want to drop any lower.
12-10-2015, 02:18 PM | #4 |
Rep 12
Hi,
I'm 2014 F31 xDrive without DHP. I have 17" all around with factory wheels. Tires: Hankook Ventus S1 noble2 - 225/50ZR17W. Springs are stock. Shocks are from Bilstein B6(HD). How do you like the staggered setup ? I might consider staggered setup once I have $$ for new wheels : ) |
12-12-2015, 08:41 AM | #5 |
Rep 2,036
VikNavy,
I'm running 225/45Zr18 front and 255/40Zr18 back. I'm happy with the setup. Ditching the run flats was very noticeable.
12-12-2015, 08:44 AM | #6 | |
Rep 2,036
Was that mainly to get stock ride height back?
12-12-2015, 01:57 PM | #7 | |
Rep 18
12-15-2015, 05:33 PM | #8 |
Rep 12
Yes, I had KW V1 first. My KW setup develops very loud thumping/clunk sound when going over bump or uneven surfaces. I've seen another person on this forum had the same issue.
02-10-2016, 08:26 AM | #11 |
Rep 18
My personal thought based on my own invented scale…
Extremely soft – *Very soft –Soft – 0 - Stiff – *Quite stiff – Very stiff – Extremely stiff Stock shock = Very Soft B6 = Quite stiff Went with B6 with stock spring setup to keep stock ride height due to road condition here. Ride is a bit firmer than I expected, much firmer than the stock shock. I expected the ride quality with my previous E60 with stock shock but this is a bit firmer side than my taste only when I am passing over uneven road surface which I have to trade off. I believe B8 which is considered to be even stiffer due to shorter stroke, might be TOO much for the ordinary people. I am generally satisfied with new shock except more rattling noises are heard around dash and steering column area when passing uneven road surface with 245-40-18 tires all around. Hope this helps. |
02-18-2016, 12:57 PM | #12 |
Rep 262
b6 OR b4?
thanks for this thread...I have a 2013 328 XDrive, (38000 miles) ....same issues....standard spring/shock combo is FAR too soft...almost wallows on New Yorks horrible roads.
Considering a B6...but I have B4s on my 1985 Saab Turbo which has firmer springs than the F30...and for sure probably not comparable...but I DO like the B4 ride on that car....it's just right. Given the softness of our std springs, is the B6 too stiff or just righht in your opinions???? Thanks |
02-19-2016, 09:39 AM | #13 | |
Rep 18
I changed wheels/tires at the same time when the shocks were replaced. I tackled tire pressure last week... wow... 40 psi front&rear All were reset at 35 psi and it is way better than before. I WAS generally satisfied and now I am very satisfied. |
05-29-2016, 01:00 PM | #14 | |
Rep 191
i'm thinking of getting b6's and stick with stock springs since i don't want to lower the car, only reduce bodyroll
2012 335 2016 435 2019 440 GC |
05-30-2016, 09:03 AM | #15 | |
Rep 18
Ride quality over imperfect surface or over the hole is sort of trade off but they are NOT too painful. |
05-30-2016, 10:11 AM | #16 | |
Rep 191
last question, was alignment needed?
05-30-2016, 10:14 AM | #17 | |
Rep 18
I saw them do alignment but the values seemed changed little to nothing. But you are better off having them do that for a peace of mind... Good luck.. |
05-31-2016, 08:55 AM | #18 | |
Rep 262
(2013 328 XDrive Sportline) |
05-31-2016, 11:56 AM | #19 | |
Rep 65
05-31-2016, 10:31 PM | #20 |
Rep 191
i hope not! i just ordered the b6's
06-01-2016, 08:47 AM | #21 |
Rep 262
06-01-2016, 08:54 AM | #22 |
Rep 262
