BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Warning Triangle Mount
      03-20-2012, 03:06 PM   #1
Rick4345
Rick4345's Avatar
472
Drives: 2022 WRX World Rally Blue
Exclamation Warning Triangle Mount
Does anyone know how the warning triangle mounts in the trunk, such as the european delivery has. I have the assembly from my old car. I see the indentaiton on the trunk lid, but mine mounted on the left side. If I need the brackets for the trunk lid does anyone have the parts numbers. THANKS!!
      03-20-2012, 03:28 PM   #2
E90Fleet
South Africa
1312
BMW if you are reading, I need a job, Please.
      03-20-2012, 03:32 PM   #3
E90Fleet
South Africa
1312
The black plastic clamps are part number "51 49 7 167 548"
      03-20-2012, 04:03 PM   #4
wdlv
wdlv's Avatar
Drives: 2019 X5 40i M Sport
I gather they're easy to snap in (for installation) or out (to disassemble)? Can't tell if there are any screws on these clamps.
I ask since on an ED, you get a warning triangle and a first aid kit but after it ships they are taken out since they are not U.S. standard. In the brochure it mentions that they may be kept but must be taken out prior to drop-off.
      03-20-2012, 04:12 PM   #5
gator15
I am wondering the same thing. I will be picking up my F30 next month on ED and am curious about what tool(s) I need to bring to remove the brackets.
      03-20-2012, 05:09 PM   #6
Rick4345
Rick4345's Avatar
472
torx screws
I think they are held in place bya T20 or T25 torx screw. I have those, I just needed the brackets. E90 Fleet, THANKS A LOT!!! HUGHE HELP.
      03-20-2012, 05:29 PM   #7
E90Fleet
South Africa
1312
Sorry, forgot the screws
Each has 1 screw and a plastic nut they screw into
Dont know if USA cars have the nut in the trunk lid so you may have to add them
Part numbers ( You need 2 of everything )
Bracket "51 49 7 167 548"
Screw "07 11 9 906 876"
Plastic nut "51 71 7 154 520"
      03-20-2012, 05:50 PM   #8
Feanor
Drives: BMW F30 320d Luxury 6MT
So you can have a non-US standard warning triangle in your own car, and can be supplied with a non-standard triangle separately from your car, and presumably you can use a non-US standard triangle in an emergency, but you can't be supplied with a non-US standard triangle WITH your car?
Isn't any triangle better than non?
      03-21-2012, 05:41 AM   #9
E90Fleet
South Africa
1312
US has some strange laws.
They also cannot get the Euro First Aid kit
      04-02-2012, 05:53 PM   #10
Rick4345
Rick4345's Avatar
472
Update
Well, I received the mounts. Everything went great right up to the point of storing the triangle. Apparently the mounts are too small for the triangle that I have. I didn't think they would be a different size for the triangle.
      04-04-2012, 07:20 AM   #11
E90Fleet
South Africa
1312
F30 triangle is part number 71 60 6 770 487
What the part number on the one you have ? Is the cover red ?
      04-04-2012, 10:31 AM   #12
Rick4345
Rick4345's Avatar
472
Triangle
The part number I have is 1095457. The cover is blue. I tried ordering one using the part number you gave me. I couldn't find one through BMW channels. I looked on the ECS website and they have them in stock. Just ordered one. We'll see how it goes. As usual, I am greatful for the help.
      04-04-2012, 10:50 AM   #13
E90Fleet
South Africa
1312
Found this one:
E90 2009+ one is exactly the same as F30 one
I see there are some people got blue ones, but with the exact same size as the red.
The Blue you had is the larger blue one from the pre-facelift E90
http://leatherz.com/Merchant5/mercha...Code=E90Safety
      04-04-2012, 11:45 AM   #14
bcl0328
Drives: 2012 328i
does every car have a net like that? i don't have one.
      04-04-2012, 12:26 PM   #15
E90Fleet
South Africa
1312
No, its part of the Storage Compartment Package option.
There is a nicer larger net available from the dealers
      12-20-2012, 11:09 AM   #16
BMWFanatic2008
BMWFanatic2008's Avatar
Drives: 2023 M3 6MT
Do you know if a triangle from 2010 E92 (pre-LCI) will fit F30?
      12-20-2012, 10:44 PM   #17
neilk
Drives: 328i Sport
You don't need to remove the bracket, just bring the triangle and first aid kit back with you. That what I did on my ED. Brackets were still there when I got the car.
I think BMW's concern os that anything that is not bolted down in the car can be stolen...
      06-22-2017, 03:15 PM   #18
Tomo366
Drives: 2014 328D
2014 BMW 328D  [0.00]
I installed my warning triangle using these part numbers....I couldn't buy the warning triangle from the dealer ended up getting it from Great Britain on EBay fits and looks great!
      06-22-2017, 06:56 PM   #19
Arthurrs
Drives: 2017 430i xdrive Gran Coupe
You can buy the warning triangle and case from ECS Tuning:
https://www.ecstuning.com/b-original...1y0093055~oes/
And here's the bracket:
https://www.ecstuning.com/b-genuine-...h/51497167548/
2017 430ix Gran Coupe
      06-22-2017, 09:35 PM   #20
OneLastBMW
Sarcasm while you wait.
149
Drives: 2017 F33 B58 xDrive
I left the brackets attached and hid the triangle and first aid kit behind the wind deflector that stows behind the rear seat back in convertibles. Everything made it to the US just fine.
      06-24-2017, 08:31 AM   #21
Tomo366
Drives: 2014 328D
ECS prices stink paid less have overseas shipping
      12-13-2018, 04:26 PM   #22
kassey22000
Drives: 2019 F31, sport line/executive
I find it such a strange stance that BMW NA has chosen to delete the Emergency Triangle and First Aid Kits from the 1 to 7 series vehicles. These are SAFETY features that could save life and limb in an emergency. BMW NA CS claims that because these are NOT required by the US DOT that they have omitted them even though their locations are clearly marked in the trunk/storage area and referenced in the owner’s manuals. To cheapen out on a $50k to $200k car for probably less than $8 worth of plastic and supplies is short-sighted in the least and stupid in all cases.
Air conditioning is NOT required by the US DOT but it's obviously on most cars BMW ships to the US and it doesn't even enhance safety.
It seems like another example of the accounting department tail wagging the BMW brand dog.
It also blemishes the new car delivery experience IMHO. To take delivery of a shiny new (expensive) car bristling with the latest technology, luxury options, and safety features then discovering that the first aid compartment is empty (as well as the special compartment for the triangle also lacking any such item) cheapens the whole initial customer experience. Each time I've taken delivery the dealer rep just shakes his head at the missing items and says their feedback to HQ on this cheap decision goes nowhere.
Come ‘on BMW, stop this nonsense… it makes your corporate decision process look stupid and really these items could enhance safety.
Rant over, thanks!
