      05-06-2013, 05:33 AM   #3565
legaleye3000
Drives: 2014 328i; 2015 X3
Thanks Frogman I'll give it a try
      05-06-2013, 07:24 AM   #3566
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
Originally Posted by npgatech View Post
Code:
REM > 3062 > MAPPING_TAGAHRL_H_L_OUTPUT = sl_l
REM > 3062 > MAPPING_TAGAHRL_H_R_OUTPUT = sl_r
REM > 3062 > MAPPING_TAGAHRL_H2_L_OUTPUT = sl_2_l
REM > 3062 > MAPPING_TAGAHRL_H2_R_OUTPUT = sl_2_r
REM > 3063 > MAPPING_UNIVERSAL_6_OUTPUT = off
REM > 3063 > MAPPING_UNIVERSAL_7_OUTPUT = off
REM > 3063 > MAPPING_UNIVERSAL_6_PWM_LEVEL_1 = werte=64
REM > 3063 > MAPPING_UNIVERSAL_7_PWM_LEVEL_1 = werte=64
So with this setup you have the front corona rings + real tail pipe completely turned on?
or are you still missing the inner tail pipe?
      05-06-2013, 01:10 PM   #3567
npgatech
npgatech's Avatar
Drives: 2012 BMW 335i
Talking
I have everything turned on. Front Coronas (no sidemarkers) + all tail pipes.
      05-06-2013, 01:18 PM   #3568
npgatech
npgatech's Avatar
So, not sure what happened, but after last night's coding (DRL stuff), I am getting this engine light:
I have the car VO coded from 6NH ---> 6NK for enhanced BT. It works fine. But, I am getting this engine symbol in my dashboard while driving...I checked the iDrive vehicle status for errors - nothing.
So, I think I am going to reset everything (still keep the 6NK). Can someone please confirm how to reset all the values to defaults? AFAIK, I just right click on the top folder with [VIN] and click code.
Please advise
      05-06-2013, 03:19 PM   #3569
ramonE90-NL
Netherlands
35
Drives: bmw F30 320iA
Everytime i put my car in reverse and the pdc is beeping it stays beeping, even when i put it in neutral or 1st gear. Is there an coding way to turn this off? So it only beeps in reverse and stop in N or 1st
      05-06-2013, 03:38 PM   #3570
4.8 E70
Montenegro
24
Drives: Alpina B7
npgatech, why not just revert to the default settings re: DRL and see if the check engine light goes away ?
      05-06-2013, 04:06 PM   #3571
Frogman
Drives: 2012 F30 328i
Please advise
That will VO code the whole car undoing all of your other changes too.
You might try just VO coding the REM module first. Right click on the REM CAFD (not the underlying one) and instead of selecting "Read Coding Data", select "Code".
That will reset the REM back to the factory settings.
if that doesn't fix it, they you may want to do them all to see if it clears your CEL.
      05-06-2013, 04:16 PM   #3572
demge01
demge01's Avatar
Drives: F30 320ed
Yeah I find this really annoying too.
Which CAF are the parking sensor folders in?
      05-06-2013, 05:31 PM   #3573
npgatech
npgatech's Avatar
Talking
I'll try this out tonight.
      05-06-2013, 06:49 PM   #3574
Frogman
There are a lot of PDC related things in the REM module. There are dozens and dozens of PDC variables.
In REM, there are 6 PDC sections, 3200, 3201, 3202, 3203, 3204, and 3205.
I looked around a bit and saw some potentials:
REM / 3203 PdcParkMasterVar :
V_SCHWELLE_1 & V_SCHWELLE_2 look to be speed thresholds.
D_SCHWELLE_1 & D_SCHWELLE_2 look to be distance thresholds.
If you are up to experimenting, please post your results!
      05-06-2013, 09:34 PM   #3575
npgatech
npgatech's Avatar
Angry
I did the full reset. The CEL still doesn't go away
Is there a way in Esys to clear errors? I hope I don't have to take it to the dealer
      05-06-2013, 10:10 PM   #3576
shawnsheridan
shawnsheridan's Avatar
No. E-Sys will not clear errors. Try Tool32:
Assuming the fault condition no longer exists, to clear the fault code.
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\F01.PRG
4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
Hopefully, Problem Solved.
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      05-06-2013, 11:01 PM   #3577
npgatech
npgatech's Avatar
2) Hit F3
5) Hit F5
I tried to do this but since I have reset the car, I cannot establish Ethernet connection! :-( Is it because I reset and it somehow disabled the Ethernet connectability? I am going to also check if the cable is good. Any ideas?
I have checked my pc. rebooted.
Ethernet card settings are ok. Automatic IP address assignment.
I turned on and off the car a few times.
Not sure what's wrong :-(((
      05-06-2013, 11:03 PM   #3578
shawnsheridan
I don't know what the connection issue is, but resetting the ECU's is not it, else you would not have been able to code it to begin with.
I would make sure the cable is good and making a good connection on both the OBDII and Ethernet sides.
      05-06-2013, 11:12 PM   #3579
npgatech
npgatech's Avatar
I did IPConfig in the command prompt,
shows me:
Autoconfiguration IPv4 address: 169.254.197.139
then I pinged that IP, it pings no issues. But I can't connect :-(
      05-06-2013, 11:19 PM   #3580
shawnsheridan
shows me:
Is that the IP for your LAN Adapter or the Car? If the LAN Adapter, then I still say you have a problem with your cable.
      05-07-2013, 01:17 AM   #3581
npgatech
npgatech's Avatar
We're back in business! I had to remake the cable (cable from April1 was not correctly wired. Not sure why it worked before the reset). After checking multiple times (and totally shocked) with my multimeter connectivity test, it was indeed inconsistent with the Cable guide posted on the first page.
After remaking the cable, I could connect and follow the tool32.exe procedure as you indicated. Worked like a charm! Engine checklight is off. Now, I just have to recode all the parameters and hope the CEL doesn't come on. Otherwise, Rinse & repeat until I find the parameter that causes a CEL.
Thanks Shawn!
      05-07-2013, 04:40 AM   #3582
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
So, now I am scratching my head .
now to add to the confusion, I changed the values as follows to get both front & back DRL to turn on (note that the parameters are different than the first time!):
Code:
So, what the hell is going on? Only conclusion I can come up with is that MAPPING_UNIVERSAL_6 or 7 doesn't matter. I have them OFF. With my default TFL_MODUS=drl_s, I just had to change MAPPING_TAGARHL_H/H2 to their respective values.
I am sure, some where in the dark offices of BMW software development team...there is a thick manual that tells ya all the dependencies & explanations. The "Comment or rather Kommenter" thing is a cruel joke...its not consistent and the whole thing is haphazardly put together IMHO. BMW software developers! get your act together...help us hackers out lol
or I could try to learn German
Yes, it's enough for inner and outer tail lights as DRL:
      05-07-2013, 09:30 AM   #3583
shawnsheridan
Thanks Shawn!
      05-07-2013, 09:59 AM   #3584
ad78
Yr1OfD1
ad78's Avatar
Drives: 2015 F34 M Sport
so i coded a few things and i activated live and internet but looks like im missing something. by the way i have bmw assist. how can i bypass this?
      05-07-2013, 10:49 AM   #3585
ramonE90-NL
Netherlands
35
For some strange reason i cant connect via VIN anymore. The last time ive coded something was last week. And today the vin box in esys is greyed out.
The other connections are available exept VIN. Where the VIN should be it now says no ZGW available
When i try ZGW_SEARCH it says MSWINSCK.ocx is missing or invalid. But the file is in the same folder
      05-07-2013, 11:38 AM   #3586
Frogman
I don't think live/internet can co-exist with BMW Assist, it's either or.
To keep live/internet, you will have to remove BMW Assist from the VO.
