01-08-2014, 02:03 PM | #1 | ||
boomshakalaka
26
Rep 107
Drives: 435i xDrive MSport (F30)
bmw ppk
I'm ordering 435i M-Sport line and I'm thinking of getting PPK as well. I'm little bit confused on few things though, maybe someone has better understanding than me and can clear it up for me)
so, how would I know which one is better? and am I going end up with 2 now? or maybe it makes sense NOT to get those options w/ car and get them w/ PPK? anyone?
2014 BMW 4-Series (F32) 435i xDrive (silver/red) ///M Sport
2011 BMW 3-Series (E92) 335IS (black/red) 2010 BMW Z4 (E89) sDrive30i (red/black) |
01-08-2014, 04:18 PM | #2 | |
Rep 884
If you get the Dynamic Handling Package, the active dampers will replace the static dampers that come with the Sport/MSport suspension. So, the ride height will be 10MM lower than in a luxury package vehicle, and you'll also have the active dampers. If you opt for the Msport brakes, they will replace the standard brakes. You will not get two of anything.....an upgrade package always replaces the standard equipment. Also, to be clear...PPK typically refers to the (M) Performance Power Kit, which has nothing to do with the suspension or the brakes. the MPPK is a factory ecu tune that allows for additional boost and increased horsepower from stock. Good luck! |
01-08-2014, 04:29 PM | #4 |
Rep 2,210
Drives: '17 jackrabbit on crystal meth
I'd get the PPK to augment power since you're driving a 335is.
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
01-08-2014, 04:35 PM | #5 |
boomshakalaka
26
Rep 107
I apologize for not making myself clear, let me try it again)
I'm getting 435i M Sport line w/ M Sport Dynamic Handling Package and M Sport Brakes. I'm looking at PPK and it seems like PPK also offering upgrades for suspension & brakes, so my question is: Why would one get these options (while building car), if you get same (or better) by getting BMW PPK. ... in another words if my 435i M Sport was ordered w/ M Sport Brakes (+$650) and later on I decided to get PPK(+$???) that comes w/ "M Performance brakes", why not get PPK w/ either standard brakes (save $650). I hope I make some sense, if not please ask me again, i'll try it again) thanks)
01-08-2014, 04:38 PM | #6 |
Rep 1,831
Drives: 335i MSport + MPS/MPPK
PPK is performance power kit. How does that relate to suspension and brakes? Are speaking of the M Performance Edition F30?
01-08-2014, 04:45 PM | #7 |
Rep 1,728
It sounds like you are being offered some package that they may be doing.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
01-08-2014, 04:50 PM | #8 | |
Rep 884
01-08-2014, 04:52 PM | #9 |
Rep 2,210
PPK is a stand-alone option, one option of a laundry list of M performance parts that include, Limited slip differential, carbon fiber parts, etc. Some (if not most) are not available yet for the F32.
01-08-2014, 04:56 PM | #10 | |
Rep 10,509
Personally, I think the $650 M sport brake option is a GREAT deal |
01-08-2014, 05:05 PM | #11 |
Rep 884
This is correct. The reason its a lot less expensive than the M Performance Brake kit is because BMW effectively "subsidizes" the cost by offsetting the cost of the stock brakes against the Msport brakes.
01-08-2014, 05:25 PM | #12 | |
Rep 243
Drives: 2013 335i M-sport
DHP gives you active dampening on the suspension and steering which will give you a soft sporty feel passively automatic, or active sporty feel when engaged in Sport. It's also the only way to upgrade to an M-suspension if you get x-drive. The M-Suspension isn't adaptive, it's on all the time. It's also non-adaptive but, you get a 10mm suspension drop in exchange for you loss. It's not available for x-drive models. The M-performance suspension kit replaces the shock absorbers, wishbones and stabilizers, along with springs and gives an additional 10mm drop (20mm drop total). It also cost's a lot more if you're coming from standard suspension or DHP, but it is compatable with x-drive models. You will lose a lot of the adaptive suspension with DHP, but you will keep adaptive steering. The M-Sport brakes should be the same big brake kit as the M-performance big brake kit except the rotors aren't drilled (somebody plz correct me if I'm wrong). It will probably cost an additional $600-800 to upgrade the rotors later, considering the whole M-BBK on the F30 is $2200mrsp it will probably save you money to get the m-sport brakes from the factory. I read somewhere that it's actually a Brembo BBK. I will add that Motortrend tasted the M-BBK on an M-Performance loaded 335xi and it didn't stop the car any faster, it just prevented brake fade seen with the standard brakes. Last edited by v1k1ng01; 01-08-2014 at 05:55 PM.. |
01-09-2014, 10:32 AM | #13 | |
boomshakalaka
26
Rep 107
my apologies for being misinformed. I went to BMW's site: http://www.shopbmwusa.com/PRODUCT/27...ANCE-POWER-KIT
bmw, ppk |
