11-06-2016, 07:41 AM | #353 | |
Moon Parasite
654
Rep 1,336
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
11-06-2016, 12:45 PM | #354 | |
46
Rep 29
[IMG] View post on imgur.com [/IMG][IMG] View post on imgur.com [/IMG]Would be interested to see what your logs look like with your Enzo tune and if your AFRs are also still on the stock map. Also if Enzo installed plugs for you I'd be curious if they also made the choice to use the same copper core motorcycle plugs. |
Jadar1752.50 |
11-06-2016, 03:04 PM | #355 | ||
Rep 893
the N20s for a while and the S55s while on the stock turbo, all of which were installed by Enzo, so not sure what that's about. Either way new plugs are an easy fix, glad you guys got it sorted! Concerning the AFRs I know the Enzo tune targets low 12s at WOT so maybe OP's stock fuel system couldn't keep up with the boost? Either way sounds like something was off! Did you redyno with your tune? Wondering how much power you put down? Curious what the limit of the stock fuel system is. Glad the car is running well!
2019 SG M5C
2015 SO M3 6MT 2015 BSM M235xi |
FSociety3812.50 |
11-06-2016, 04:54 PM | #356 | |
46
Rep 29
11-06-2016, 07:49 PM | #357 | ||
Rep 893
So I take it you didn't redyno?
2019 SG M5C
FSociety3812.50 |
11-06-2016, 08:06 PM | #358 | |
Gettin It Figured Out
1820
Rep 2,669
No sir...was unable to secure one on short notice (SEMA had everyone's attention) mike@x-ph.com (Extreme Power House) tried to help me track one down .
Luminous742.00 |
11-06-2016, 08:29 PM | #359 | |
Rep 1,931
AFR's are set to 12.5 with Enzo. Not saying anyone is better than someone else, but for my car and reliability, Enzo is solid. Flash only with no jb4 I run a 12.013 @ 114.xx and lap lime rock @ 1:05.3. Sorry for the hijack.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic Last edited by bryan_G01; 11-06-2016 at 08:34 PM.. |
FSociety3812.50 |
11-07-2016, 04:57 AM | #360 |
Moon Parasite
654
Rep 1,336
Glad they posted the link to the cable in the other thread. I've been needing to get one. Just been forgetting 3) BMW ENET (OBD) cable - available on Amazon, one of them available here: https://www.amazon.com/BMW-ENET-Ethe...rds=enet+cable Prime FTW
11-07-2016, 07:02 AM | #361 | |
IG @bmwF9xG80
3813
Rep 7,592
60-130mph 6.5s X4M #HCP
11-07-2016, 12:27 PM | #362 | |
Rep 4
When you do a flashtune you can dial the target AFR map and also the DI injection map to help achieve such result, those 2 tables have to be really correlated. In some cases you can set the target to 12ish and leave the DI injection alone then use other fueling method to help the DI to reach its target. If you are running the same backend flash as Ronanz was (it`s an error since both setups are a lot different fuelingwise), there might be not many problems for you, because your fueling is being fed using the PI so you can leave the DI table alone and throw huge amounts of fuel (until it zero the fuel trim without being able to reach the targeted 13.5ish) and end up with 12ish. But since Ronanz didn`t had any other fueling method on his car, only relying on the stock fueling system, leaving the DI table untouched, it`s just a flaw. And in his case, lead to a 15ish AFR vehicle with some mild boost in his PS2... Glad that this engine is strong as it is ... Doing this mistake into any MPFI vehicle would mean melted internals, in Ronanz case was only the plugs acting like a fuse, and the fuse was blown... So about ACF`s position, we can be as technical as you would like but will not enter in keyboard fights and endless discussions about who is better than who, we won`t polute Ronanz thread anymore so if you would like to get more info just PM me and i would be glad to answer everyones technical doubts or just use the topic created by Alex in this board that should be used for that purpose). And just answering your other question, i don`t think that we have pickedup a lot of horsepower since at 18 psi level the PS2 is just starting to show it`s airflow capabilities. We have dynoed other car with just a PS2, colombian finest 85 oct fuel (simulating the 91 Oct), and a kittyless downpipe and it gave us 410whp... 440whp when fuel was mixed with torco aditives to raise from 85 to 93 Oct theoretically. Here are the following graphs: And should be really close to what Ron should been runing now. The stock fueling will be maxed out around the 430-460whp depending on how much Ethanol you have mixxed and the quality of your fuel. Any other question, you already know! PM me (or alex) or go to the flashtune troubleshoot topic. Other than that i`m just happy that we could achieve Ronanz expectation and that i had the oportunity to meet such a great guy. So far the most incredible looking BMW i`ve ever seen. Best, Ricardo Freitas ACFPerformance |
11-07-2016, 12:54 PM | #363 | ||
Rep 893
Yes I agree, it's definitely best to let the numbers do the talking And yes Ronanz's car certainly is stunning! I've had the pleasure to see it in person and those blue cf pieces are gorgeous
2019 SG M5C
11-07-2016, 05:22 PM | #364 | |
1820
Rep 2,669
Thanks! . Looks nicer now with the new front lip and CF Steering wheel tho .
11-07-2016, 05:40 PM | #365 | |
1820
Rep 2,669
. Thanks stud.... I'm sure you've seen nicer.... .
11-08-2016, 09:08 AM | #366 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
lol yeah, hopefully I hear some good news from ABR here soon on my car.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
11-08-2016, 02:54 PM | #367 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Any clue which module yet?
FBO-PS1 and stuff
11-08-2016, 03:13 PM | #368 |
515
Rep 1,063
Nope, waiting for him to reply to my email. She's running now, but all i know is I need a new fuel rail pressure sensor. I could call but I don't want to bother them. its not like I can pick her up today anyways.
11-08-2016, 06:29 PM | #369 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
11-09-2016, 09:07 PM | #370 |
Rep 1,127
hey guys the N55 likes to run lean :-D
FSociety3812.50 Alex@VNV-Speed46.00 |
11-10-2016, 05:10 AM | #371 |
Moon Parasite
654
Rep 1,336
Well that's good to hear it might be down to a sensor now. (fingers crossed)
11-10-2016, 09:18 AM | #372 |
Dejan
1753
Rep 4,197
Yes on a stock map that runs 8psi. But the man is running a stage 2 turbo and a custom flash. You tune for a big turbo you need that a/f 12.5.
FBO-PS1 and stuff
