BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Wagner Tuning FMIC Competition Intercooler Review
Studio RSR
      01-22-2014, 08:25 PM   #67
Cateye
Drives: M135i
I have install both IC and CP. It seems easy to remove both parts (unclip, remove some screws) by the workshop. Slide out in less than half hour. But installation takes longer time as need to adjust the angle of the CP. But for IC, there is a need to cut the front plastic ( only corners) a little to get it in. Anyway u can't see the cut from the front grill. Mine is F20 M135 so its a little diff to F30.
      01-22-2014, 08:53 PM   #68
ShlemonboostedM
ShlemonboostedM's Avatar
92
Drives: 335i F30
DO you guys feel any gains with fmic ? i mean like but dyno does it feel little stronger on top ? couse i remember Fmic on n54 i could deff feel my top end improved ..
      01-22-2014, 09:22 PM   #69
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
It's hard to say. Maybe marginally but it's hard to tell if there's more power bc the power that's there just seems smoother and a little more effortlessly. .. hope that makes sense, lol
      01-23-2014, 03:25 PM   #70
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
I wouldn't say I could feel any butt-dyno power difference. I did some 4th gear pulls and logged on the JB4 and there are improvements in spool time and boost doesn't drop off quite as much off the map2 14psi target as RPM increases. It was also 40 deg outside when I was doing it so the car was pulling like a freight train anyways, and likely would have pulled just as hard with the stock IC.
What I was looking for in the Comp IC was to get less flow resistance for better throttle response and lower turbo spool times as well as increased ability to shed heat when I'm tracking in the heat of Texas summers. So, primarily for me this was a reliability mod - I want the car to continue to perform on lap 20 like it did on lap 1 - with the stock IC, the car would heat soak like crazy and in some cases overheat completely and pull timing/boost/throttle - basically do nothing productive till it cooled down.
With any mod just make sure you know what your goals are and mod toward those goals - If you're looking for fastest drag times - your money's much better spent on a meth kit than an IC. I could have done meth for tracking as well, just to keep the temps down, but I liked the permanence of the IC over having to worry about filling a meth tank, maintain nozzles etc. Just run cooler, recover quicker (i.e. during a braking zone) and increased top end and throttle response wouldn't hurt.
      01-23-2014, 06:17 PM   #71
mikew2069
mikew2069's Avatar
413
Man I really wish I would have logged on JB4 with the stock IC when it was 80 degrees so I could overlay with the new IC to compare boost spool and drop off....
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      01-23-2014, 08:36 PM   #72
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Originally Posted by utenigma View Post
...What I was looking for in the Comp IC was to get less flow resistance for better throttle response and lower turbo spool times...
Did it accomplish this?
      01-24-2014, 05:16 PM   #73
ShlemonboostedM
92
Drives: 335i F30
I guess i'll go with Performance FMIC .. i'll do some logs for you guys 2 compare ..
      01-25-2014, 03:05 AM   #74
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25022
Drives: '22 Chalk Gray Porsche C2S
Excellent read. Well done!
      01-28-2014, 12:20 AM   #75
grimm7302
Drives: 2022 f30xi coupe
so what were your overall HP gain? i am considering this as my first initial mod to my 328i
      01-28-2014, 08:12 AM   #76
mikew2069
mikew2069's Avatar
413
I don't think you can expect too much gains in HP, maybe 5-10whp but its more to keep the air denser (cooler) longer and to reduce heat soak so you don't lose HP in between runs... I personally think its a must do mod for turboed engines...
BM3/H&R/Borla
      01-28-2014, 09:36 AM   #77
DVC
DVC's Avatar
Drives: 335i
Originally Posted by mikew2069 View Post
Sure, no problem. When I get home this afternoon, I'll weigh the stock cooler for ya.
Have you had a chance to weight the stock unit yet?
      01-28-2014, 10:30 AM   #78
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
is there any competitive other intercoolers ? what about Helix IC are they out yet ?
ActiveAutowerke is making one for 335i ?
I really need one with MiddleEast Sun it's too hot for turbo cars :'(
Docrace 6266
      01-28-2014, 12:45 PM   #79
mikew2069
mikew2069's Avatar
413
Just weighed it. Came in at 7.4lbs on the bathroom scale.
I'm sure a bunch of others are scrambling to release theirs... But you have all you need here!
BM3/H&R/Borla
      01-28-2014, 12:46 PM   #80
utenigma
3.29 Kg
      01-28-2014, 12:49 PM   #81
utenigma
3.29 Kg
Lol - so you can pick which one you like - bathroom or kitchen
and apparently both Mike and I work from home b/c we've got nothing better to do than go to our garages and weigh an intercooler at noon on a tuesday
      01-28-2014, 02:21 PM   #82
mikew2069
mikew2069's Avatar
413
Lol, yea I work from home most of the time. I was actually going to go into the office today but it got cold in Houston so the city freaked out and everything shutdown.. People from up north would laugh at us.
BM3/H&R/Borla
      01-28-2014, 03:22 PM   #83
DVC
DVC's Avatar
Drives: 335i
Lol - thanks guys!
      02-16-2014, 08:54 AM   #84
M-terkait
M-terkait's Avatar
Kuwait
209
I'm trying to log in so i can order from their website but it says that my account is inactive, emailed them but they didn't respond .
maybe because its weekend ?
Docrace 6266
      02-16-2014, 10:32 AM   #85
mikew2069
mikew2069's Avatar
413
Yea probably bc the weekend.
BM3/H&R/Borla
      03-07-2014, 01:18 PM   #86
TurboBullett@Ambient Thermal Management
TurboBullett@Ambient Thermal Management's Avatar
80
Drives: 2012 Abarth 500
Yes it is. Its listed as Ambient Thermal Management not Helix.
http://www.f30post.com/forums/showthread.php?t=950653
      03-07-2014, 08:47 PM   #87
mikew2069
mikew2069's Avatar
413
BM3/H&R/Borla
      03-08-2014, 08:03 AM   #88
80
Seemed appropriate seeing how they jacked our design and still didn't get it right.
