09-28-2016, 07:20 PM | #89 |
Rep 1,782
SO my buddies theory would be plausible?
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
09-29-2016, 12:56 PM | #90 |
Rep 459
Mine failed last 2 weeks ago at 32k miles. 2013 335i msport. Replacement was done by the dealer and it was pretty much painless. I hope they replacing with reinforced or reingeniered part.
09-29-2016, 01:03 PM | #91 |
Rep 2,957
09-29-2016, 01:57 PM | #92 | |
3441
Rep 79,211
They are cheap enough to them to just replace as needed. If you want the real fix you need to go with an aftermarket aluminum. |
09-30-2016, 12:27 AM | #93 |
Rep 236
Anyone know the status of the VRSF CP for the F30 335i xDrives? Tiago said that they're revising it. I see a VRSF one listed on Extreme Power House (www.x-ph.com) still but it doesn't specify "XDrives". I know Mike doesn't carry it at N54tuning, or I'd have bought it from his Cdn warehouse! Any idea where if I can get one that's not as pricy as the ER one to fit my '13 335i xDrive?
Thanks! Fred |
09-30-2016, 01:26 PM | #94 | |
Rep 190,750
VRSF CP fits the RWD only at this time.
10-01-2016, 05:13 PM | #95 |
Rep 22
Yes, this is normal. To give you more peace of mind, take a look at the installation instructions. It says there should be a small gap like yours because of the expansion of the stock plastic charge pipe. I just installed mine and have the exact same give. If you have an xdrive and are having low boost, I would bet it's the lower tclamp not tightened enough or properly...that step was the worst of the entire install on an xdrive. Hope this helps.
10-01-2016, 05:14 PM | #96 | |
Rep 2,957
10-01-2016, 05:29 PM | #97 |
Rep 60
Just out of curiosity, what does changing the chargepipe do for emissions? I noticed that a lot of them are cat-less. Since I am in a state that follows CA rules, wanted to make sure I am not causing myself unnecessary drama. Thanks.
10-01-2016, 08:43 PM | #98 | |
Rep 2,957
10-02-2016, 04:24 AM | #99 | ||
Rep 60
10-02-2016, 05:50 AM | #100 |
Rep 22
10-02-2016, 05:54 AM | #101 |
Rep 22
What state do you live in? In CA, you aren't allowed to modify your downpipe at all. In fact, you're mostly restricted to a CARB approved intake and cat back exhaust to have a street legal car (but a lot of mechanics turn their head). If your state does emissions testing, don't do a downpipe. If they don't, but say downpipes are illegal, you can probably get away with a HFC downpipe or a cat less if you know your shop well enough. I have the Wagner HFC downpipe and love it.
10-02-2016, 09:22 PM | #102 |
335i F30
68
Rep 252
Mine just blew today, same spot.
13' F30 335i Mineral White Metallic
Sport Package | 19" Rotiform SPF | BC Coilovers Coral Red Interior | H/K Package Active Autowerke Flash Tune, FMIC, Exhaust | BMS Intake | VRSF DP | VRSF CP |
10-03-2016, 10:13 PM | #103 |
Rep 122
2014 435i (47,700 miles) - My stock cp failed Saturday after two enjoyable pulls at 85% throttle. I was able to ductape it back and took it to dealership this morning. I had my car back by lunch time. I live in Houston so the heat and humidity is extreme. Regardless, the cp will fail. Make sure you have a roll of ductape with you at all times.
10-04-2016, 03:36 PM | #104 | |
Rep 190,750
10-04-2016, 04:10 PM | #105 |
Rep 122
10-04-2016, 04:11 PM | #106 |
Rep 190,750
I'm a different Mike
mbanks211267.50 |
10-04-2016, 04:13 PM | #107 |
Rep 122
10-04-2016, 04:14 PM | #108 |
Rep 190,750
HAHA none taken
Bestia64.50 |
10-05-2016, 07:26 PM | #110 |
Rep 190,750
Bestia64.50 |
