BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Transmission performance and Carly for BMW
proTUNING Freaks
      06-17-2019, 02:14 PM   #1
JayZee72
Drives: F31 03/2017 320D
I'm currently looking at an issue on a friend's F30 (2018) 320d Auto.
This may be entirely coincidental, but after he performed a reset of the transmission to learn his driving behaviour, the car has suffered from a stutter which is quite bad on occasions and more often at low speed.
To me, it almost feels like the stutter you would get if an EGR valve needed a good clean, but bearing in mind this car is only 18 months old I would doubt that anything like this would be an issue.
Has anybody out there ever used this function in Carly and suffered a similar problem. It just sounds like too much of a coincidence to me.
      06-17-2019, 06:22 PM   #2
Kraftwerk
Kraftwerk's Avatar
Drives: 2015 335i M Sport
So after performing a reset:
1. With the scan tool, clear any DTCs that may be set.
2. Drive the vehicle until the vehicle temperature is greater than 30˚C (86˚F).
3. After the vehicle has reached normal operating temperature, and with the scan tool, monitor actual gear state. Drive the vehicle normally with the accelerator pedal between 10% and 20% until 7th gear has been achieved, approximately 76 km/h (47 mph). After 7th gear has been achieved, coast down to 30 mph with no application of the brake or accelerator to allow a 6-5 shift. Brake the vehicle to a stop. Repeat this procedure 5 times.
He may also have to reset throttle adaptions:
* Press the start button once to turn on power (Don't start the engine)
* Press the accelerator down to the floor for at least 5 sec.
* Hit start button once to turn off power
* Remove foot from accelerator
* Wait for min. 2 minutes
* Start the engine and drive
2015 335i ///M-Sport 8AT | M Performance Exhaust/Brakes/Suspension | BMS CP | BM3 Stage 2 | VRSF FMIC | AR Design DP | AFE Filter | RES Delete | BavAuto Coils | P3 Gauge | xHP Stage 3 |
      06-18-2019, 05:48 PM   #3
JayZee72
Thanks for the advice Kraftwerk.
Will give this a go at the weekend and post back the results.
      06-19-2019, 08:49 PM   #4
jaddie
jaddie's Avatar
Drives: San Marino Blue M4 Comp
Would be curious to hear how this goes for you
Current: F82 M4 Comp '19
Previous: F36 440i M Sport '18
Previous: F32 430d xDrive M Sport '15
Previous: F30 320d M Sport '14 & E81 118d M Sport '09
      07-17-2019, 06:24 PM   #5
JayZee72
Well I finally got round to doing this and, although it made a little difference, my suspicions were correct and it turned out to be a dodgy EGR valve.
Replaced under warranty thankfully and now she's purring along as if nothing ever happened.
carly, f30, reset, transmission
