BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 Glass soft?
Studio RSR
      01-28-2013, 08:08 PM   #23
jamesh
Drives: 2011 X5
I guess we're straying too far from the point. The OP mentioned swirls and webs in the glass, which is a cosmetic issue. I just hope bmw's cost cutting efforts don't compromise the reputation that they've built up.
      01-28-2013, 11:21 PM   #24
BlauWeiss
Drives: F30 335i RWD
What irritates me is that my car with less than 500km / 1 month old has a scratched up driver side window. I can feel the scratches when I run my fingers across them. The kicker is that the car has only been driven in very fair weather (no winter conditions, mostly dry weather). Picture of Fuyao glass:
The worn-looking leather on all seats and the rust underneath the seat don't add to the confidence in quality. Having said all that, at least there have been no electrical/mechanical defects, and it's a blast to drive.
      01-30-2013, 04:34 AM   #25
jamesh
Drives: 2011 X5
So far just the f30. I hope it stays that way. Those pictures show inexcusable lack of quality.
      01-30-2013, 08:05 AM   #26
335BBS
Drives: 2009 335 coupe.
Attachment 813141
That glass is brutal and so is the underside of that chair. If you don't want your seats to look like that then you need to order vinyl......thats what leather does. In BMWs quest to stay at the top have they started cutting corners etc.? Lots of frustration/anger in the forum.
      01-30-2013, 10:45 AM   #27
Elk
Drives: 2012 335i
      01-30-2013, 11:07 AM   #28
335BBS
Originally Posted by Elk View Post
I think they look fine too.
      01-30-2013, 11:15 AM   #29
BavarianFanatic
Too much is never enough
Drives: Too Many
Attachment 813141
So what exactly did you do to the glass? Glass doesn't just get scratched up like that without someone doing something they shouldn't have. NO glass will hold up to rubbing something abrasive all over it.
      01-30-2013, 12:10 PM   #30
335BBS
Looks like it was cleaned with a Brillo pad!
      01-30-2013, 01:00 PM   #31
Jit_340i
South Africa
Drives: Glacier Silver F30 335i
Hi. I took delivery of my f30 335i this weekend and I'm shocked at the quality of the windscreen and glass in general. Lots of swirls and marks. My car finished production on 18/01/2013 at Rosslyn so it's definitely coming straight from the factory like that. It's dangerous to drive this car at night due to the poor visibility. My previous e92 made in Germany had a flawless windscreen for at least 4 years.
      01-30-2013, 04:06 PM   #32
steveL77
Drives: 2013 335i M-Sport
Yup this is the reason I made this thread. I have the same issue. It's fine during day time driving but as soon as oncoming traffic lights hit the glass at night visibility is horrible. Other than the glass problem the car is outstanding.
      01-30-2013, 04:26 PM   #33
BavarianFanatic
Drives: Too Many
Are you guys sure the glass is actually clean? Glass can be polished pretty easily. Return to your dealer and ask that it be polished to remove the marks. It sounds to me like someone wasn't careful when washing it either at the dealer or the VPC.
      01-31-2013, 03:05 AM   #34
Jit_340i
South Africa
I've clayed the glass and tried using BMW glass polish with poor results. The problem is definitely the glass and not the wipers. I suspect it needs a machine polish.
      01-31-2013, 12:06 PM   #35
BavarianFanatic
Drives: Too Many
I don't think using a claybar on glass is a very good idea. Glass isn't as hard and abrasion resistant as paint. For one, it's not intended to do anything for scratches. If anything, it'll CREATE them. It's sole purpose is to remove contaminants that are on the surface. It's also a first step prior to polishing for the sole purpose of removing contaminants in an effort to avoid grinding them into the paint as you polish. The damage caused by the clay is polished away. This isn't quite as easy with glass. There's a very high potential for doing more harm than good with clay unless you really know what you're doing.
The BMW glass polish (or any other consumer product) isn't intended to remove scratches. It's really only a cleaner. You can take care of very light scratches and haze with products like Bon Ami and Bar Keeper's Friend which are very mild cleansers. Anything deep enough to catch a fingernail will require more aggressive abrasives such as cerium oxide. But beware, you can quickly do far more harm than good if you're not experienced doing this. Glass isn't nearly as forgiving as paint.
      01-31-2013, 12:14 PM   #36
dude987
Drives: BMW 335i xDrive M-Sport DHP
I think you should set your car on fire in front of your local dealership in protest.
Lol +1
      01-31-2013, 01:29 PM   #37
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
A claybar is fine on glass with proper lubrication. Detailers use it all the time to remove water spots. I get great results with it all the time. Its very easy and anyone can do it.
Glass is much harder than paint. Hence why paint polish won't correct glass and the need for Cerium Oxide.
      01-31-2013, 02:52 PM   #38
BlauWeiss
Yea I wanted to see what happened if I used a Brillo pad on the glass :P
The only thing I've done to the glass since taking delivery at the dealer is lowering the windows (relatively frequently), and that's where the deep vertical scratches are most likely from. I will try to somehow clean the part the glass slides against to ensure there is nothing stuck in there..
If it gets worse, I'll certainly take it back to the dealer..
      01-31-2013, 04:09 PM   #39
BavarianFanatic
Drives: Too Many
This is something many folks fail to understand which is why I warn against it unless you really understand how to do it properly. Water spots are nothing more than a build-up of lime, calcium and other minerals on the surface of the glass. They're not defects or scratches in the glass itself that you're trying to "polish" out.
My point was that people automatically think of glass as being really hard and durable. They don't understand that something as simple as rubbing against glass coated with dirt, sand or anything abrasive can scratch and gouge the glass fairly easily. And it's not a simple matter to "buff it out".
      01-31-2013, 04:13 PM   #40
BavarianFanatic
Drives: Too Many
Ironically, Brillo (steel wool) won't necessarily hurt glass so long as there isn't a bunch of dirt and crap on the glass for the steel wool to grab and drag.
Vertical scratching is definitely the result of something lodged in the window felt/weatherstripping. Lower the window all the way and give the felts a good wipe to dislodge whatever is stuck in there. If you get scratches on the inside of the glass, there's probably something in the door that's out of alignment.
      01-31-2013, 06:05 PM   #41
buildbright
155
Drives: F80 M3 MG
Lube makes everything better
