11-02-2016, 06:16 PM | #1 |
Rep 272
Phone help
All of a sudden the phone in the car does not work I answer the call on steering wheel it answers I see number on screen but I can't hear them and they can't hear me, hit phone on wheel and call ends? Please help
11-02-2016, 06:49 PM | #2 |
Rep 61
It may be going to your phone, if you answered from it the previous phone call. Next time you answer a phone call check if the call is on the device itself and if it is be sure to change the source from the device to the vehicle and it should be okay.
11-02-2016, 06:52 PM | #3 |
Rep 14,115
Drives: G82 M4C X-Drive
Disconnect the Bluetooth, reconnect and try again. If it doesn't then reset you phone and try again. If that doesn't work then try another phone. If that works then it's your phone and probably not your car. It's a lot easier to fix a phone than it is to fix a car! Try your phone on another car/Bluetooth connection. If it works then your car is having problems with your phone. Delete the Bluetooth connection on your phone and delete the device from your car and reconnect from scratch.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
11-02-2016, 06:59 PM | #4 |
Rep 143
OP, by any chance do you have an iPhone that was updated to OS10?
I just witnessed this same or similar) behavior in a friends vehicle (non-BMW) that started immediately after the Os10 update. The call answers, but the phone is defaulting to "on phone audio" for incoming calls. Outgoing calls still work on the car audio. |
tex26702412.50 |
11-04-2016, 09:19 AM | #5 |
Rep 1,659
Drives: 2022 WRX World Rally Blue
This may be a strange thought.
Mine started doing that and I ended up discovering the volume setting was turned down. It was set fine for my Iphone 6 but had to be reset on my IPhone 7. |
tex26702412.50 |
11-05-2016, 12:41 AM | #6 |
2JZ-GTE
3038
Rep 3,992
Yeah ios10 doesn't work as well as the other versions. Lots of fun "features". Looks like apple is losing their way.
