01-12-2017, 01:04 PM | #1013 | |
Rep 224
01-12-2017, 02:27 PM | #1014 | |
Nemo banks
65
Rep 253
FBO N20, G-Plus Oil Cooler , Injen Cold Air Intake, MST turbo inlet, AFE Charge Pipe, BMS Oil Catch Can, Forged Motorsport Blow of Vavle, Wanger FMIC, Circuit Werkes Catless Downpipe, Full Straight 3inch exhuast. Stage 2 Active Auto Werke.
01-12-2017, 09:03 PM | #1015 | ||
Rep 32
01-12-2017, 09:07 PM | #1016 |
Rep 32
My beam pattern is odd. The top cut off steps down 2 times. Once over the passage side than again over the driver side. Strange.
I leveled the lights but that won't go away and I don't see what's causing it. I've believe I saw someone else post their light pattern which was the same. Anyone know why the step downs occur? Is it suppose to? |
01-13-2017, 08:42 AM | #1017 | |
Rep 144
Drives: 2023 M3 Competition xDrive
How are the Kensun bulbs? Are you happy with them? Would you do anything differently? |
01-13-2017, 06:37 PM | #1019 | |
Rep 102
If it ain't broke don't fix it
01-13-2017, 08:10 PM | #1020 | ||
Rep 32
I twisted out the extenders on the bottom bolts about 3/8 inch to line up the top of the light to the fender and hood better. There was too much gap at first. Then when I aligned the lights moving them up with the adjusters was without issue. I think I'm overall balanced now just the weird stepping. Looking around online it seems it is purposeful to light up the passenger side ditch and helping to not blind oncoming traffic on the driver side. |
01-14-2017, 12:57 AM | #1021 | |||
Rep 102
01-15-2017, 03:13 AM | #1022 |
Rep 70
Does anyone have GP Thunder chrome turn signals installed? I'm getting turn signal malfunction errors when I have them installed. At first I thought there was a problem with the bulbs so then I got new replacements. Now only 1 out of the 4 bulbs are working.
01-15-2017, 04:12 PM | #1023 | |
Rep 577
I wasn't sure either and read this: http://www.candlepowerforums.com/vb/...1156-7506-bulb In the end I wasn't sure the GP's were the same as the PY21W. So I forked out for the Osram ones. |
ill25015.00 |
01-19-2017, 03:12 PM | #1024 |
Rep 33
Massive problem
So i bought these on 7/6/16 right when they came out. i got them with the h7 upgrade. i was all happy with them till now. i came to conclusion they are not built as well as they should be. i wake up one morning and my left headlight is out. only after a couple months. so i take off the cover in the wheel weld and i see that there is corrosion. as you can see in picture. i shake the cables and the whole plastic cover comes off and exposes the h7. (on computer so post under will have pictures from phone) now i have a 2015 bmw with a head light out for the money i payed not happy with the product. i also cant find just replacement headlight easy. i have emailed customer support so waiting for response.
01-19-2017, 04:57 PM | #1026 |
BMWLad
1469
Rep 2,393
Drives: 320D M Sport
Got mine fitted yesterday
01-19-2017, 06:30 PM | #1027 |
Rep 32
01-19-2017, 06:31 PM | #1028 |
Rep 32
BrennanF301469.00 |
01-20-2017, 04:28 AM | #1029 |
BMWLad
1469
Rep 2,393
01-20-2017, 09:13 AM | #1030 |
Rep 279
BrennanF301469.00 |
01-20-2017, 04:05 PM | #1031 |
#gotboost
517
Rep 861
Looking good Brennan.
Sorry to hear that mateusz. Have you heard of anyone else with that upgrade having issues? I try to wait to purchase things until a v2 or when most of the kinks have been worked out :\ I swapped my turn signal housing for the OEM one yesterday and it's been working great since. Did any of you guys having issues with it also swap the passenger side just to be safe? I haven't but I'm thinking about doing it |
BrennanF301469.00 |
01-20-2017, 05:55 PM | #1032 | |
Rep 32
I haven't had any more condensation btw. I wrote USR and they sent a video explaining the connector issue. . I'll try it later. |
01-20-2017, 07:03 PM | #1033 | |
Rep 33
01-20-2017, 08:21 PM | #1034 |
BMWLad
1469
Rep 2,393
Thank you guys really happy to be the guy who has brought these DEPO headlights to the people of the UK and Ireland
