06-22-2013, 08:48 AM | #3873 | |
Rep 40,756
This is beyond my capabilities.
06-22-2013, 08:59 AM | #3874 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
If you could also tell me if you need any adapters for the wiring, it would be much appreciated. Was your car built before 07/2012? I'm currently trying to see if it is possible to retrofit NBT by just replacing the head unit on a CIC equipped car. |
06-22-2013, 12:42 PM | #3876 |
Rep 40,756
Not with only 1 post. Either increase your Post count until you can receive PM's, or post an email address.
06-22-2013, 01:49 PM | #3877 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
I bought the used NBT (HU+CID+iDrive joystick+ GPS antenna). Additionaly I bought 2 microphones, 1 HUH-USB cable, AUX/USB connector. I changed the pinning at existing HU-CID cable instead of buying a new cable HUH-CID. I made 2 identical antennas of SMD connector, RG174 cable and WiFi stick antenna from any WiFi router. One for BT,one for WiFi. I found few bushing connectors and some cable to connect 2 microphones to HU. All installation procedures take about couple hours. Then I added 609, 6NK, 6NR, 614, 615, 616, 620 options to VO and VO coded the car with zeitkriterium 0712. Last edited by avgor123; 06-22-2013 at 02:59 PM.. |
06-22-2013, 08:10 PM | #3878 | |
Rep 3
06-22-2013, 08:20 PM | #3879 | |
Rep 40,756
06-22-2013, 08:49 PM | #3881 |
Rep 40,756
Email sent.
06-22-2013, 10:29 PM | #3883 |
Rep 40,756
Yes.
06-23-2013, 12:19 PM | #3884 |
Rep 18
Thanks Shawn for helping me out -- finally done my first coding :-)
Now the big problem is the M Performance brakes coding...any help or advice on what to do after adding the SPBR in the HO-WORT? Do I need to code the DSC ? The garage told me it's not necessary and it will "adapt" by itself, I don't believe that from what I have read it is necessary to code to get the full benefits. It is exciting and scary the first time coding , really afraid of screwing something up. |
06-23-2013, 12:25 PM | #3885 | |
Rep 40,756
06-23-2013, 12:52 PM | #3887 |
Rep 40,756
FYI. This will wipe out any custom FDL Coding, so you would need to go back after VO Coding SVT and redo any FDL Coding.
06-23-2013, 09:24 PM | #3888 |
Rep 18
06-23-2013, 09:34 PM | #3889 |
Rep 40,756
No. It is done in the standard Expert Mode => Coding module, where all other FDL and VO Coding is done.
06-23-2013, 09:37 PM | #3890 |
Rep 18
06-24-2013, 05:54 AM | #3891 | |
Rep 122
I have run SWID Reader on my car. That program show my car's VIN, donor car's VIN (at NBT) but doesn't show FSC code 1B (0 bytes) What does it mean - FSC 1B wasn't activated at donor car? Or SWID Reader can't read FSC from NBT? |
06-24-2013, 06:29 AM | #3892 |
Rep 40,756
NBT Does not have 1B FSC Code. It uses a DE FSC Code instead, and SWID Reader will not read it..
06-24-2013, 06:44 AM | #3893 |
Rep 122
06-24-2013, 06:54 AM | #3894 |
Rep 18
Damn, I did one step wrong during the KOMBI coding for "M Performance logo"- instead of pressing "Code FDL" in the coding panel. I right clicked the folder and "CODE". An error popped up and now two errors come up on the dash :
1) Drivertrain 2) Fuel Supply Asking me to drive moderately - I returned everything to default state but still there. Shawn - can you help or point me in the right direction? Thanks |
